PDA for Volkslogger
Old April 23rd 13, 12:53 AM posted to rec.aviation.soaring
Default PDA for Volkslogger
I'm quite happy with using just a Volkslogger in flight. At a local FBO I used to use a FBO Compaq iPAQ 3835 with Winpilot just to put turnpoints into the FBO VL then fly the VL. Unfortunately over the winter someone managed to delete the Winpilot program from the iPAQ. Trying to update the old iPAQ to re-accept Winpilot is a real pain and impractical. Surely there must be some decently inexpensive and relatively modern way to put turnpoints into a VL - heck, I'm happy to just do this myself via lat/long (although the SSA might not accept this for my gold...?). And yes, I do carry (and use) a small handleld GPS strapped to my leg for safety purposes...
All suggestions greatly appreciated.
Old April 23rd 13, 01:48 AM posted to rec.aviation.soaring
Peter von Tresckow
I have my VL hooked up to my Oudie. In the past I've used seeyou on the pc
to upload tasks to the VL which works in a pinch as well.
You could always try connect me on the ipaq.
Pete
Old April 23rd 13, 10:07 AM posted to rec.aviation.soaring
You can use the free "Connect me" software from Naviter to upload existing waypoint lists and tasks to your Volkslogger. You can also use it to download your Volkslogger igc file to you iPaq.: http://www.naviter.com/products/connectme/
Old April 23rd 13, 01:08 PM posted to rec.aviation.soaring
Chris Nicholas[_2_]
On the VL website, there is a utility called VL manager. In theory,
it appears that one can use this to load in a selection of BGA
turnpoints to that software, and then use the utility, and a lead from
PC to VL, to upload them into the VL.
Unfortunately, I have been unable to easily see how to selct a
suitable number from the BGA list (the VL can only accept 500 I
believe) and to replace the existing old turnpoints loaded into the
VL.
Does anyone have instructions, in English, which can be followed by
somebody who is not a computer expert?
Chris N
Old April 23rd 13, 02:42 PM posted to rec.aviation.soaring
Peter von Tresckow
VL.
Chris N
VL manager never properly worked for me. SeeYou PC with a USB adapter works
great though.
Pete
Old April 23rd 13, 07:44 PM posted to rec.aviation.soaring
Thanks, folks! As it turns out I have a serial port/USB connector that I use on an old B&W printer to save color ink. I'll give this a try and post what happens. THANKS!
Old April 23rd 13, 10:20 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
On Tue, 23 Apr 2013 11:08:28 +0000, Chris Nicholas wrote:
On the VL website, there is a utility called VL manager. In theory, it
appears that one can use this to load in a selection of BGA turnpoints
to that software, and then use the utility, and a lead from PC to VL, to
Unfortunately, I have been unable to easily see how to selct a suitable
number from the BGA list (the VL can only accept 500 I believe) and to
replace the existing old turnpoints loaded into the VL.
Would creating the list of turnpoints with TPSelect and then using VL
manager to load them into the VL be a sensible solution?
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old April 24th 13, 01:37 AM posted to rec.aviation.soaring
Chris Nicholas[_2_]
Yes, but that is like telling a non-chef that to make this dish you simply make a white sauce, add forcing, and gratinate it until cooked.
TPSelect seems an unwieldy way to get 500 TPs, but if I spent long enough I suppose I could do it. (Has anybody in East Anglia already done a suitable selection of say 300, to which I could add a few favourites such as around Aboyne?)
But I don’t know how to get such an amended list into VL manager, or how to use that to get it into the VL. The VL manager instructions, such as they are, are in German.
It is quite a triumph for me to get TaskNav to “see” the VL when I want it to – it never seems to be the correct com part, never the same as the last time, and I have to find one by trial and error to do even that, for downloading IGC files. [“never” = sometimes not, at random.]
Chris N
Volkslogger help need Nick Kennedy Soaring 8 March 17th 09 05:48 PM
Looking for a Volkslogger Ron Gleason Soaring 1 December 14th 06 05:09 AM
Volkslogger + Mac Wouter Wessels Soaring 14 April 14th 05 11:05 PM
Looking for a Volkslogger Del Ogren Soaring 0 August 20th 04 04:00 AM
Volkslogger Going fer it Soaring 1 February 17th 04 05:43 AM
