The Force will take over the F-35B?
Old March 26th 04, 04:42 AM
Henry J Cobb
Default The Force will take over the F-35B?
http://www.af.mil/news/story.asp?storyID=123007285
Lockheed Martin originally contracted with the U.S. Marine Corps to
build the STOVL variant of the F-35 to replace the aging AV-8B
Harrier. The Air Force will take over the program in June, as part of
the service’s commitment to improving close-air support.
Who ya gonna FARP with?
Will there be AF units attached to Army "flying columns" to setup ad hoc
Foward Area Refueling Points for Air Force F-35Bs alongside the Apaches?
Doesn't it make more sense to transfer Tac Air back to the Army so the
Generals can shuffle funds between helicopters and fixed wing CAS as needed?
-HJC
Old March 26th 04, 05:07 AM
Kevin Brooks
"Henry J Cobb" wrote in message
news
FARPs are not your specialty, are they? If they want to do a FARP, they have
a number of options, just like those in the Army aviation community have a
number of options. Use of helos is one option, or use of helos in
combination with assets sent forward by ground transport, or indeed by
ground assets only. They could in some cases eben use C-130's operating from
a designated FLS. What, you think the USAF has nobody capable of driving a
truck? In most cases, though, you could expect them to set up a FOB (forward
operating base) instead of a FARP. The USMC manages to do this kind of
thing--why do you think it beyond the ability of the USAF and Army?
needed?
No, it does not make sense, much less *more* sense. Which means that you are
shooting par, as usual. Think "joint", Henry.
Brooks
-HJC
Old March 26th 04, 05:11 AM
Henry J Cobb
news
If you have to lay out a full landing strip for the C-130's why would
the AF need F-35Bs, couldn't they just use F-35As?
-HJC
Old March 26th 04, 05:21 AM
Kevin Brooks
news
have
a
from
a
(forward
Holy crap, Henry--*FLS* does NOT mean "full landing strip". It is a
*forward* landing strip, using what is called the MOS (minimum operating
strip length) for that type of aircraft. care to hazard a guess as to the
difference between a MOS for a C-130 and one for a CTOL tactical fighter? A
section of straight road can be used for a C-130 FLS, or engineers can carve
one out in rather quick fashion (then usually termed an "assault strip",
usually with a dirt surface or at most a geotextile/geogrid--and no, you are
not operating F-35A's off of that, either).
You see what happens when you start second guessing and belittling what you
have absolutely no grasp of? When are you going to get off this kick that
you know more than the guys who wear the blue and green suits?
Brooks
-HJC
Old March 26th 04, 09:17 AM
Keith Willshaw
news
The doctrine of forward operating bases moving with the army
is scarcely new, all the air forces of WW2 did it. I'm not surprised
the USAF are interested in F-35B since the RAF were a customer from
the start.
Keith
Old March 26th 04, 09:46 PM
John S. Shinal
a number of options
No expert I, but you should be able to use a LAPES style drop
(or rather, a bunch of them) to move a bunch of stuff in when setting
up a FARP. I imagine moving munitions that way is pretty hairy, but
it's probably workable in some fashion.
----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeed.com The #1 Newsgroup Service in the World! 100,000 Newsgroups
---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =---
Old March 27th 04, 04:33 AM
Les Matheson
Did lots of FARPS for 160th and the Air Force Spec Ops community in the MC.
Never did a LAPES drop, in fact we never did LAPES, period. I don't think
anyone in the TAC Lift community is even qualified anymore. Even back in
1991 in the U.A.E. waiting the first Gulf War I worked in the ALCC and we
were asked about airdrop quals, but nobody was qualified to do LAPES then,
at least in the wings I was controlling. We moved lots of MK-82's from
Masirah to points all around the peninsula.
Landing to offload munitions is the safest way.
Les
F-4C(WW),D,E,G(WW)/AC-130A/MC-130E EWO (ret)
"John S. Shinal" wrote in message
a number of options
News==----
Newsgroups
Old March 30th 04, 02:49 PM
John S. Shinal
"Les Matheson" wrote:
Interesting stuff, Les. I recall someone bouncing a Herk doing
a LAPES drop near Ft. Bragg some years ago - I think during a CAPEX.
It made the evening news, and perhaps there was a shift away from it
after that.
Old March 30th 04, 08:21 PM
Ron
after that.
Early to mid 80s, and I think the vehicle it was dropping got stuck in the
back. I remember seeing footage of it..Was it possibly at an airshow too??
Ron
Tanker 65, C-54E (DC-4)
Old March 30th 04, 10:30 PM
Kevin Brooks
"Ron" wrote in message
after that.
too??
No, it was during a CAPEX; the USAF used to do a LAPES demonstration every
summer during the Advanced ROTC Camp held at Bragg as part of the
joint/combined arms CAPEX (included CAS from A-10's using Mk 82's and 30mm,
attack helos firing about everything they could lug, heavy and troop
paradrops, 155mm and 105mm arty (with the latter brought in as slung loads
under UH-60's), tank and IFV engagement of targets downrange, mortar and
Dragon (now Javelin, I guess) engagements, and a light infantry LFX
culminating in sappers breaching an obstacle and demo'ing a bunker. I don't
recall anything about the load getting stuck--it was apparently and
unfortunately a case of pilot/crew error due to misreading their descent and
flare altitude. If you watch the video of the crash you can see they
pancaked in quite hard (flexure of the aircraft structure allows you to see
daylight through the upper fuselage as it strikes), bounced back up as if it
was going to make it back up, and then comes back down and fireballs.
Brooks
Ron
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 02:39 AM
Highest-Ranking Black Air Force General Credits Success to Hard Work Otis Willie Military Aviation 0 February 10th 04 11:06 PM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 04:24 AM
Air Force announces acquisition management reorganization Otis Willie Military Aviation 0 August 21st 03 09:16 PM
