See You Mobile Declared Task Pilot Name
Old May 7th 13, 06:58 AM posted to rec.aviation.soaring
Wade
Default See You Mobile Declared Task Pilot Name
If see you mobile was registered to someone else and they are letting you borrow their PDA for a badge flight, the name attached to the registration is what gets declared to any other devices linked up (Cambridge 302 for example).
I can enter a separate pilot in the Cambridge 302/303 but I don't want a task declared through to the 302/303 with a different name from see you mobile. Does anyone know a good solution to this one?
Thanks
Wade
Old May 7th 13, 10:09 AM posted to rec.aviation.soaring
Dickie Feakes
Buy your own copy of See You Mobile!
registration
example).
Thanks
Wade
Old May 7th 13, 10:53 AM posted to rec.aviation.soaring
Wojciech Scigala
Use ConnectMe.
WojtuÅ›
Old May 7th 13, 03:39 PM posted to rec.aviation.soaring
Pete Startup[_2_]
For the flights that matter? - hand written declaration every time. Would
you trust your diamonds to gadgets?
registration
example).
Thanks
Wade
Old May 7th 13, 04:48 PM posted to rec.aviation.soaring
Paul Remde
Hi Pete,
I don't use written declarations. I've never had a problem in 15 years with
electronic declarations for many badge and record flights. If it is done
correctly it is extremely reliable.
Best Regards,
Paul Remde
________________________________
"Pete Startup" wrote in message
registration
example).
Thanks
Wade
Old May 7th 13, 05:20 PM posted to rec.aviation.soaring
John Galloway[_1_]
are letting you
registration
(Cambridge 302 for
example).
don't want a
from see you
Thanks
Wade
I'm going to stick my neck out and say that your initial premise
that it is the registered SYM name that is sent to the logger with
the declaration is wrong. Copied and pasted from the SYM
manual section on task declaration:
"After the communication is established, the following data is
transferred automatically
to the flight recorder:
Declared task in SeeYou Mobile which you have entered in
Menu Task
Glider information which is entered in Menu Settings Polar
(glider type) and Menu Settings Log
(glider registration)
Pilot name as entered in Menu Settings Log"
So, if the manual is correct, all you should have to do is alter
the pilot details to your own in Menu/Settings/Log for your
badge flight and remember to change them back to the owner's
when you return the PDA.
John Galloway
Old May 7th 13, 07:32 PM posted to rec.aviation.soaring
John Galloway[_1_]
are letting you
registration
(Cambridge 302 for
example).
don't want a
from see you
Thanks
Wade
My previous posting got truncated as it crossed the Atlantic so
here is the complete version.
transfered automatically
Menu/Task
Glider information which is entered in Menu/Settings/Polar
(glider type) and Menu/Settings/Log (glider registration)
So all you should need to do is enter your own information as
described before declaring the task and remember to change it
back to the owner's before returning the PDA to him.
John Galloway
Old May 8th 13, 03:09 AM posted to rec.aviation.soaring
GC[_2_]
On 8/05/2013 01:48, Paul Remde wrote:
Hi Pete,
with electronic declarations for many badge and record flights. If it
is done correctly it is extremely reliable.
But how reliable is it if NOT 'done correctly'? How easy is it to know
it's been 'done correctly' electronically compared to a written
declaration?. Written ones are inherently 'extremely reliable' for
those of us who aren't software gurus.
If software was reliable, straightforward and predictable, the number of
posts on r.a.s. would be halved.
GC
Best Regards,
Paul Remde
registration
example).
Thanks
Wade
Old May 8th 13, 05:34 AM posted to rec.aviation.soaring
Roy Clark, \B6\
On June 16, 2004, this happened to me - only time since 1996.
I was not aware of any problem until my OO opened the trace.
Then, learned:
Declaration is NOT VALID!
Task: Triangle - (305.9km)
Task distance: 305.9km
1) Ephrata
2) Waterville
3) Davenport
4) Ephrata
All reached turn points rounded ok. Task Completed.
Distance: 305.9km, Duration: 04:16:53, Speed: 38.55kts
Sent to The Badge Lady anyway.
She asked if OO had verified a written declaration before take-off.
If done, Badge leg done ok; if not, sorry.
Flew for fun on June 20 and 21, then flew another 300+km triangle on the 22nd.
Oh, yeah, did a verified written declaration before that flight – and every Badge leg fight attempt since, including my next ones.
Old May 9th 13, 04:56 AM posted to rec.aviation.soaring
Paul Remde
Hi Roy,
Did you do the failed electronic task declaration before or after take-off?
Paul
"Roy Clark, "B6"" wrote in message
Then, learned:
1) Ephrata
2) Waterville
3) Davenport
4) Ephrata
22nd.
Declared first emergency last week EventHorizon Piloting 39 October 28th 09 05:04 PM
New iphone Mobile Nokia Mobile [email protected] Soaring 0 January 14th 09 06:29 AM
More Evidence Bush Was Actually Declared a Deserter WalterM140 Military Aviation 9 August 23rd 04 11:36 PM
Declared "minimum fuel" O. Sami Saydjari Instrument Flight Rules 14 April 4th 04 02:43 AM
A record: 1 in 73 US households declared bankruptcy in '03 Krztalizer Military Aviation 7 March 15th 04 09:27 PM
