#21
On Wednesday, May 8, 2013 8:53:23 AM UTC-6, Waveguru wrote:
I replaced the electric retrieve motor with a 6hp Honda. The electric just didn't have enough poop to pull the chute back well. We've been using this payout winch for years now, and it works very well. It is simple and safe. We are continuing to improve our technique tho. We used to start with the brake set, and accelerate the truck and glider together. But we changed that to accelerating the truck with the brake off, and the line paying out, and after the truck is up to speed, we then set the brake to the proper tension. This worked much better. The glider gets up to flying speed, and off the ground, much quicker, and therefor has control sooner, and gets higher. The payout winch has several advantages over a conventional winch or auto tow in that when the glider hits lift, the line simply pays out faster. We almost never have any rope breaks because the tension on the brake is never supposed to be set above the breaking strength of the weak link. It's too bad that some people, that have no idea what we are doing, immediately label it as bad and dangerous. It must be nice to be such a know it all, eh? I figured that it would bring out some of the idiots here when I posted the video. It's just so easy to be a dick online these days, isn't it? Boggs Gary, How are you measuring rope tension? |
All we have is a pressure gauge on the hydraulics of the disc brake. A tentiometer would be better, but we are trying to KISS. Boggs |
Don, I can respect that you have reservations about the method in
question. But it would be a lot more constructive if you'd provide specific examples of why the method in question is inadvisable, and are prepared to tell us how it can go wrong. Otherwise, when you call people "foolhardy" and tell them flat out to "stop it," you mostly just come across as a disagreeable curmudgeon. Furthermore, I think that anybody who has used a winch but decries the "complexity" of other ground launch methods does not really understand how complex a good winch is, and how many points of failure there really are. Thanks, Bob K. On May 7, 9:02*am, Don Johnstone wrote: I think that is the most complicated and potentially dangerous method of winch launching that I have ever seen. I am completely sold on winching, having made over 10000 launches on many types of winch over the years. I have to say that some of the winches I have used, including a converted Rover car have been less than ideal, and perhaps a little unwise, but this has to be the most foolhardy version I have ever come across. I would be the first to admit that there are several potential hazards in winch launching but a system as complex as that is an accident just waiting to happen. Please stop it guys, get a proper conventional winch if that is the way you want to go, or go to a straight forward auto tow. |
#24
At 02:45 10 May 2013, Bob Kuykendall wrote:
Don, I can respect that you have reservations about the method in question. But it would be a lot more constructive if you'd provide specific examples of why the method in question is inadvisable, and are prepared to tell us how it can go wrong. Otherwise, when you call people "foolhardy" and tell them flat out to "stop it," you mostly just come across as a disagreeable curmudgeon. Furthermore, I think that anybody who has used a winch but decries the "complexity" of other ground launch methods does not really understand how complex a good winch is, and how many points of failure there really are. Thanks, Bob K. Fair point Bob If we consider the simplest winch where the engine is connected to a transmission via a gearbox of some kind. In this type of winch the driver is seated and controls the throttle to control the speed of cable retrieval. What can go wrong? Three basic things as regards the operation of the winch. 1. A break in the cable 2. A mechanical failure of the winch 3. Winch driver error or incapitation. All of these eventualities are dealt with by practising launch failures or launch abandonment. As far as mechanical failure of the winch is concerned there are only two main components to fail, the engine (Uncommon but not unknown) and the transmission. In all cases the winch driver is seated with a good view of what is going on and can react to problems as they arise, in particular using the guillotine if required in a timely manner. The first winch I drove was of this time, a 3 litre petrol engine driving a winch drum through a conventional 4 speed gearbox. The most complex winch I have driven was a Munster Van Gelder winch with a ginormous turbo diesel engine providing power for 6 seperate drums through a torque converter. The engine control, transmission and drum select functions were complex but once the transmission was connected to the power module the principle was the same as for the simple Eagle winch described above. Failure of either winch by mechanical failure of the engine/transmission during launching was very rare. The MVG winch was however less reliable in that faults within the more complex system meant that it was U/s far more often than the simple winch, and took longer to fix. Having said that the components making up the MVG winch were of top quality and specifcally designed or adapted to provide the proper function, it was just that there were more components to go wrong. In both cases the winch was fixed, the driver had control and could see the glider at all times and take the appropriate action. The payout winch provides an additional level of complexity and reduces the ability of the operator to control the launch. Some aspects of the launch rely totally on unsupervised mechanical/electrical operations, the payout part of the operation. The system is really a combination of two launch methods, an auto tow and a winch launch and is just one level of complexity too much when the proven technology already exists to provide a good launch without introducing more complex procedures, especially ones which rely totally on a mechanical/electrical function with no human input or control. During an auto tow the driver is facing the wrong way or is peering over his shoulder so his ability to offer proper control or reaction to an emergency is compromised, add to that the fact that cable payout is taking place while the vehicle is moving in the opposite direction and while the glider is on the cable and the things that can go wrong increases exponentially. Winch launching has hazards, no denying that, some of them completely outside the control of the winch operator. A fixed winch with the operator in a good position to observe the launch provides the best and safest solution. I have of course assumed that the launch is contolled by one person, the implications of having two people controlling a launch (or not) are too horrible to consider. I cannot see that anyone would be daft enough to do that. I can see that the payout winch launch is dangerous, I have said so. I may or may not be believed. Like all human activity it will continue until something goes wrong. If god forbid someone is killed then many people will pipe up saying they knew it was dangerous, I am just saying it in the vain hope that people will look at what they are doing and see that however attractive it might seem it is not woth the risks, before it ends in tears. Bottom line, a vehicle driving down a runway with a glider on tow and a winch paying out cable while the launch is taking place is not something that I would ever be involved in. Been gliding and winching for 50 years and would like to continue for a few more years. |
#25
On Friday, May 10, 2013 8:11:07 AM UTC-4, Don Johnstone wrote:
The system is really a combination of two launch methods, an auto tow and a winch launch and is just one level of complexity too much when the proven technology already exists to provide a good launch without introducing more complex procedures, especially ones which rely totally on a mechanical/electrical function with no human input or control. The opposite of Don, I have ZERO experience with winch launches, so I look at the approach with a completely naive perspective. If you think that my inexperience means that I should not comment on what I see, then stop reading now. I have no opinion, but I have a few questions. The system is really a combination of two launch methods, an auto tow and a winch launch... From my naive point of view, this launch starts out as an autotow. How is this phase of the launch different than a traditional autotow? Waveguru depends on the clutch on the payout winch to modulate the tension on the line.. What are the failure modes for this clutch and what are the consequences? Would it be safer to lock the clutch and start the tow with the line under tension (rather than the truck taking the "running start"? Is a traditional autotow more failure prone and/or dangerous than a winch launch? Once the autotow phase of the launch is completed, the glider is several hundred feet in the air. All of the bad things that can happen with a winch launch close to the ground have been sidestepped. (waveguru's method introduces) more complex procedures, especially ones which rely totally on a mechanical/electrical function with no human input or control. Again, naively, in a rapidly developing situation, whenever "time is of the essence" and extremely short, I would generally trust a properly designed and constructed mechanical or electrical mechanism to effect the correct response much more than I would trust a human operator. Is there a reason why a human operator would be more trustworthy in this situation? Okay. I do have a few observations/opinions: 1)That the payout winch payouts more line and keeps line tension constant when the glider hits lift seems an inherent advantage of this approach when compared to a traditional winch launch. 2)Don's suggestion that traditional winch launching is proven and that there is therefore no reason to experiment with payout winching misses the point. In a country where beefy pickup trucks are common, the start-up costs for payout winching are much lower than traditional winching. Secondly, far fewer humans need to be deployed and coordinated to run a payout winch. The relevant question is "Which is better to use on a dry lake bed, 1)autotow with payout winch or 2)traditional autotow? What are the tradeoffs? |
#26
On Friday, May 10, 2013 7:11:07 AM UTC-5, Don Johnstone wrote:
At 02:45 10 May 2013, Bob Kuykendall wrote: Don, I can respect that you have reservations about the method in question. But it would be a lot more constructive if you'd provide specific examples of why the method in question is inadvisable, and are prepared to tell us how it can go wrong. Otherwise, when you call people "foolhardy" and tell them flat out to "stop it," you mostly just come across as a disagreeable curmudgeon. Furthermore, I think that anybody who has used a winch but decries the "complexity" of other ground launch methods does not really understand how complex a good winch is, and how many points of failure there really are. Thanks, Bob K. Fair point Bob If we consider the simplest winch where the engine is connected to a transmission via a gearbox of some kind. In this type of winch the driver is seated and controls the throttle to control the speed of cable retrieval. What can go wrong? Three basic things as regards the operation of the winch. 1. A break in the cable 2. A mechanical failure of the winch 3. Winch driver error or incapitation. All of these eventualities are dealt with by practising launch failures or launch abandonment. As far as mechanical failure of the winch is concerned there are only two main components to fail, the engine (Uncommon but not unknown) and the transmission. In all cases the winch driver is seated with a good view of what is going on and can react to problems as they arise, in particular using the guillotine if required in a timely manner. The first winch I drove was of this time, a 3 litre petrol engine driving a winch drum through a conventional 4 speed gearbox. The most complex winch I have driven was a Munster Van Gelder winch with a ginormous turbo diesel engine providing power for 6 seperate drums through a torque converter. The engine control, transmission and drum select functions were complex but once the transmission was connected to the power module the principle was the same as for the simple Eagle winch described above. Failure of either winch by mechanical failure of the engine/transmission during launching was very rare. The MVG winch was however less reliable in that faults within the more complex system meant that it was U/s far more often than the simple winch, and took longer to fix. Having said that the components making up the MVG winch were of top quality and specifcally designed or adapted to provide the proper function, it was just that there were more components to go wrong. In both cases the winch was fixed, the driver had control and could see the glider at all times and take the appropriate action. The payout winch provides an additional level of complexity and reduces the ability of the operator to control the launch. Some aspects of the launch rely totally on unsupervised mechanical/electrical operations, the payout part of the operation. The system is really a combination of two launch methods, an auto tow and a winch launch and is just one level of complexity too much when the proven technology already exists to provide a good launch without introducing more complex procedures, especially ones which rely totally on a mechanical/electrical function with no human input or control. During an auto tow the driver is facing the wrong way or is peering over his shoulder so his ability to offer proper control or reaction to an emergency is compromised, add to that the fact that cable payout is taking place while the vehicle is moving in the opposite direction and while the glider is on the cable and the things that can go wrong increases exponentially. Winch launching has hazards, no denying that, some of them completely outside the control of the winch operator. A fixed winch with the operator in a good position to observe the launch provides the best and safest solution. I have of course assumed that the launch is contolled by one person, the implications of having two people controlling a launch (or not) are too horrible to consider. I cannot see that anyone would be daft enough to do that. I can see that the payout winch launch is dangerous, I have said so. I may or may not be believed. Like all human activity it will continue until something goes wrong. If god forbid someone is killed then many people will pipe up saying they knew it was dangerous, I am just saying it in the vain hope that people will look at what they are doing and see that however attractive it might seem it is not woth the risks, before it ends in tears. Bottom line, a vehicle driving down a runway with a glider on tow and a winch paying out cable while the launch is taking place is not something that I would ever be involved in. Been gliding and winching for 50 years and would like to continue for a few more years. Interesting dichotomy between the European and American viewpoint. Being trained on the winch learning to soar and having 3,000 winch launches done from the winch driver seat I tend to agree with Don. To add to his points: A winch launch (1 km cable length) gets you to 1,300 - 1,600' altitude safely and cheaply. You learn to climb away from that altitude even in poor weather, or you land and do it again. I just don't see the need for winching to 2-3k feet in a glider and if you disagree you probably have some thermaling to learn. I witnessed a hang glider accident with a payout winch on a pick-up truck and it was not pretty. We asked the hang glider group to not fly from our site any more... Herb |
#27
On Friday, May 10, 2013 7:21:55 AM UTC-6, wrote:
I just don't see the need for winching to 2-3k feet in a glider and if you disagree you probably have some thermaling to learn. Herb Depends on the purpose of the flight. Early morning or late evening student training flights can benefit from higher launches. |
#28
On Friday, May 10, 2013 7:19:27 AM UTC-6, son_of_flubber wrote:
Okay. I do have a few observations/opinions: 1)That the payout winch payouts more line and keeps line tension constant when the glider hits lift seems an inherent advantage of this approach when compared to a traditional winch launch. If a glider can hit at thermal, it can also hit sink. A conventional winch can call on huge reserves of power to pull the glider through sink but the payout winch is more limited in this ability. 2)Don's suggestion that traditional winch launching is proven and that there is therefore no reason to experiment with payout winching misses the point. In a country where beefy pickup trucks are common, the start-up costs for payout winching are much lower than traditional winching. Secondly, far fewer humans need to be deployed and coordinated to run a payout winch. The relevant question is "Which is better to use on a dry lake bed, 1)autotow with payout winch or 2)traditional autotow? What are the tradeoffs? If space is essentially unlimited, as is sometimes the case on dry lakes, a traditional auto-tow is both simpler and safer. When space is limited, as on a runway, conventional winches will prove more efficient and, I think, safer. I've run the numbers several times and a conventional winch will always get you higher than a payout winch given a limited runway length. Don's point that a conventional winch is simpler is valid. In the extreme it only requires as many people as aero tow. The conventional winch is a very mature technology with an enormous body of safety data. In the 7 or 8 decades of its history, the potentially dangerous aspects have been found and procedures developed to minimize them. Germans manage 180,000 winch launches or so between accidents where we have an aero tow accident roughly every 26,000 tows. Unfortunately, the Brits suffer a winch accident every 16,000 launches which calls their methods into question. No one knows what the accident rate with payout winches would be, but until everyone climbs the learning curve, I suspect it won't be stellar. |
#29
Don is right in thinking that there should be one person in charge of the
launch. Unfortunately the person he thinks should be in charge is at the wrong end of the cable. With high powered winches driving through auto transmission (Skylaunch) the pilot has little control over the speed of launch, he just has to accept what the winch driver gives him. With a launch system that provides cable tension, by whatever control system is used, the speed is under control of the pilot. Ease off on the stick speed increases, ease back speed reduces, just like in normal flight. I've launched on both in the UK & I know which I prefer PF At 13:52 10 May 2013, Bill D wrote: On Friday, May 10, 2013 7:21:55 AM UTC-6, wrote: I just don't see the need for winching to 2-3k feet in a glider and if you disagree you probably have some thermaling to learn. Herb Depends on the purpose of the flight. Early morning or late evening student training flights can benefit from higher launches. |
#30
On Friday, May 10, 2013 8:42:39 AM UTC-6, Peter F wrote:
Don is right in thinking that there should be one person in charge of the launch. Unfortunately the person he thinks should be in charge is at the wrong end of the cable. You are correct, it's much better to have the pilot control airspeed with pitch. However, for this to happen, the winch has to control rope tension accurately as a percentage of glider weight. Control is divided where pilot controls airspeed and winch controls tension. This means Gary is right to control rope tension with his payout winch. |
Ground launch payout winch systems...Are they suitable for gliders? | [email protected] | Soaring | 13 | August 13th 14 04:30 PM |
Winch Launch Fatality | Ed Gaddy[_2_] | Soaring | 3 | June 23rd 09 11:15 PM |
Pay out winch launch to 2500ft agl.. | WAVEGURU | Soaring | 8 | June 5th 07 07:06 AM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
Winch launch | M B | Soaring | 0 | October 30th 03 07:33 PM |
