PowerFLARM firmware v3.00 released (feature complete)
Old May 17th 13, 09:31 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default PowerFLARM firmware v3.00 released (feature complete)
Andrzej Kobus wrote, On 5/16/2013 4:59 PM:
On May 16, 1:58 pm, Dave Nadler wrote:
On Thursday, May 16, 2013 12:11:24 PM UTC-4, wrote:
A friend has proposed the idea of using a fiber-optic cable to bring the
Core's LED out to the panel. I don't know whether or not that will work,
but it is an interesting idea. He's looking into it.
Paul, I've done this. You need to get good quality fiber optic
multi-strand and it works pretty well. There is some loss but under
a shadowed part of the panel, you can see it just fine. The trick is
to make a coupling for the fiber at the LED end.
Darren
Guys, you really don't need the LEDs.
Any display device *should* echo the relevant status messages.
The designers of PowerFlarm must have intended to put this LED on a
Christmas tree but they confused it with PowerFlarm brick and now we
have LED there that is not needed. Great!
My guess: one reason it's there is to give the pilot indication when
he's using a flight computer for the display, as they may not bother to
show update messages.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
  #42
Old May 17th 13, 11:24 PM posted to rec.aviation.soaring
Craig Funston[_2_]
On Friday, May 17, 2013 1:58:35 AM UTC-7, kirk.stant wrote:
It's too bad the PowerFLARM display doesn't have an attitude indicator on it and a direct link to an online glider-for-sale site - then we could have a really good thread going!
Seriously, it can be frustrating, but if you ensure you have the correct files for updating the PF and display - making SURE you check the file name because Windows 7 WILL try to stick a .txt on it - the install is easy.
And if you have a Butterfly External display (the one that comes standard with the PF Core), you will no longer have to power cycle the PF to download.
And for Mike Stringfellow - With an Oudie, it is literally plug and play. The hardest part of installing the Flarm system is finding a place for all the antennas!
Let's all go flying!
Kirik
66
RAS seems to serving perfectly well as an "Attitude Indicator". Happy Friday, let's go fly now.
Craig
  #43
Old July 24th 14, 09:24 PM posted to rec.aviation.soaring
swinkelj
Op donderdag 16 mei 2013 16:52:43 UTC+2 schreef Dan Daly:
I use this panel pass-through, and it works well: "NEUTRIK - USB A/B Pass Thru Black D-Type". I have a usb stick with a flashing LED to indicate it is accessing.
I would be nice if there were a menu item, perhaps below the one where you set it to download IGC files, where you could end recording and then download IGC files to the USB stick without cycling power. I have to turn off everything, then boot my 7007 (provides power to the Core) in order to get the IGC file out.
I am happy that I can transfer declarations from my Dell Streak/XC Soar via IOIO to the Core - very handy.
Hi Dan,
Did you buy your IOIO adapter, or did you make this yourself?
Thanks,
Joop
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
PowerFLARM Portable - Firmware Update Available - Mode C Traffic Now Supported Paul Remde Soaring 24 January 22nd 12 01:50 AM
New ILEC SN-10 Firmware Paul Remde Soaring 5 August 25th 05 08:11 PM
v3.20 Firmware now out for Garmin 296 {nt} Cockpit Colin Piloting 0 March 8th 05 01:12 AM
Garmin 196 firmware update v3.1 released Aloft Piloting 0 August 13th 03 12:50 AM
