Following suggestions in Soaring, I am trying to use the Logitech Extreme 3D Pro joystick with Condor 1.1.5 and Win 7. The control of sensitivity is not sufficient for success with the Flight Training turning exercise.
Is there a Logitech driver needed, or is there a way of setting Condor Inputs to allow for a usable scenario? Is the older sidewinder preferable from a fine control standpoint? Thanks for any advice. rkh986 |
Hi,
I suspect that you do not have Condor setup correctly in regard to the Joystick. Make sure you go to Setup Input Assign Controls and assign the controls correctly as described in my Condor Tips document he http://www.cumulus-soaring.com/condor.htm#Tips If you can't get it working, give me a call and I can help you. But please follow the directions first. Best Regards, Paul Remde Cumulus Soaring, Inc. _______________________________ "rkh986" wrote in message ... Following suggestions in Soaring, I am trying to use the Logitech Extreme 3D Pro joystick with Condor 1.1.5 and Win 7. The control of sensitivity is not sufficient for success with the Flight Training turning exercise. Is there a Logitech driver needed, or is there a way of setting Condor Inputs to allow for a usable scenario? Is the older sidewinder preferable from a fine control standpoint? Thanks for any advice. rkh986 |
On Wednesday, May 22, 2013 1:06:13 PM UTC-7, rkh986 wrote:
Following suggestions in Soaring, I am trying to use the Logitech Extreme 3D Pro joystick with Condor 1.1.5 and Win 7. The control of sensitivity is not sufficient for success with the Flight Training turning exercise. Is there a Logitech driver needed, or is there a way of setting Condor Inputs to allow for a usable scenario? Is the older sidewinder preferable from a fine control standpoint? Thanks for any advice. rkh986 I use that same joystick without issue. windows 7, latest condor |
I use that same joystick without issue. *windows 7, latest condor
Me too. Has the original poster calibrated his/her joystick using the included software? Calibration does drift. From the logitech forum: HOW TO CALIBRATE THE LOGITECH EXTREME 3D PRO JOYSTICK I just figured out how to calibrate this joystick. I am using Windows XP. I assume it will work with all Windows operarting systems though. Go to Control Panel, click on "Game Controllers", or however you get to your joystick settings. Hold down the "Ctrl" (control key) and the "Shift" key together - at the same time, THEN click your mouse on the "Properties". This should take you to a different calibration screen that you would get to without holding the two keys together. IMPORTANT - Click on the "Test" tab first. If you go to the settings tab first, it likely will not work. Without doing anything else after clicking on the "Test" tab, next click on the "Settings" tab. Then click on the "Calibrate" button below. Click "next". Click the thumb button on the left side of the joystick which should bring you to another screen. Then follow the prompts...... * On the "axis calibration", move your joystick in full circles, making sure the "+" symbol moves around the far margins of the square. After a few complete circles, click the "next" button with your mouse. * On the next screen, click the left button on the joystick again, which should bring you to the next screen. Move the throttle lever back and forth a few times. Then click "next" again. * On the "Z rotation screen", move the joystick to the left and right (rotate it) a few times. Then click "next" and then "finish" then "ok". Thats it. It should be calibrated now. Hope this helps everyone with problems. For Windows 7... Go to Devices & Printers Right Click on Extreme 3D Joystick Click on Game Controller Settings Ctrl+Shift Click on Properties Here to get to Calibration ================================================== ============ If it's not working quite right, plug the joystick into a different USB port and try the directions above again (I had to do this - worked like a charm!!). |
Following suggestions in Soaring, I am trying to use the Logitech Extreme 3D Pro joystick with Condor 1.1.5 and Win 7. The control of sensitivity is not sufficient for success with the Flight Training turning exercise. Is there a Logitech driver needed, or is there a way of setting Condor Inputs to allow for a usable scenario? Is the older sidewinder preferable from a fine control standpoint? Thanks for any advice. rkh986 Thanks Paul, for this reply and your excellent set of Condor Tips! Yes, I have followed your tips with limited success. Although using the non-linearity setting to decrease the stick sensitivity for ailerons and elevator, the flying is highly unstable, not allowing straight and level flight.. The simulation is far different from flying real fiberglass sailplanes. I will try the limits for flattening of the lower part of the curves (almost there now), as I am seeking more realistic simulation. (I am a CFIG and former sailplane owner). I appreciate the invitation to call. Thanks Dan, for the helpful advice on setting up this joystick! I plan to try the suggestions. Cheers, Kent rkh986 |
| Thread Tools | |
| Display Modes | |
| Condor Thanksgiving and Condor Christmas Contests | [email protected] | Soaring | 0 | October 22nd 12 04:33 PM |
| Adding rudders to Logitech Wingman (can it be done)? | Flight Sim newbie | Simulators | 20 | October 19th 11 05:56 AM |
| Nav radio settings in FMC | Mxsmanic | Piloting | 5 | January 10th 07 09:39 PM |
| Logitech Extreme 3D Pro & FS2004 | Leonard M. Wapner | Simulators | 1 | December 2nd 04 07:12 PM |
| L-nav Settings Ventus 2ct-18 | Oliver Peters | Soaring | 4 | July 18th 03 05:14 AM |
