On balance, are Moving Map PNAs better than Cambridge 302/303 styleLCD navigation?
Old May 26th 13, 03:56 AM posted to rec.aviation.soaring
Morgan[_2_]
Default On balance, are Moving Map PNAs better than Cambridge 302/303style LCD navigation?
I have used the SoarTronics BT Adapter to connect my Streak to my Powerflarm. It worked great. I suspect you could use it to connect to a 302 as well, though I can't remember for sure. It has a couple of standard 8ping network cable type connectors. I know people who have used the k6-BT for 302 connection though.
Unfortunately the XCSoar team hasn't had anyone jump in and write the appropriate drivers for the LNAV to get data from it. It is apparently different than the output of the 302. I don't know if it can provide air data or not, but it's not really the end of the world. It's pretty simple to set the wind manually if needed in XCSoar and I'll occasionally do that when I know I've got winds to deal with that XCSoar doesn't know about. Convergence flying is often a case where it can't discern winds or the winds it knows about will not match a final glide away from the convergence.
On Saturday, May 25, 2013 7:35:36 AM UTC-7, cernauta wrote:
I'd like to know what BT interface/adapter you are using,
or, if you had experience with different adapters, then could you
recommend the best between them...
thank you very much
aldo cernezzi
www.voloavela.it
On Thu, 23 May 2013 17:45:22 -0600, "Dan Marotta"
dcmarottat wrote:
My Dell Streak receives air data via Bluetooth from my CAI-302.
Old May 26th 13, 09:31 AM posted to rec.aviation.soaring
Max Kellermann[_2_]
A driver for the L-Nav written by Alan Walls has been merged just a few days ago:
http://git.xcsoar.org/cgit/master/xc...t/?id=89582dab
It will appear in XCSoar-testing very soon: https://play.google.com/store/apps/d...xcsoar.testing
Old May 26th 13, 02:00 PM posted to rec.aviation.soaring
cernauta
Default On balance, are Moving Map PNAs better than Cambridge 302/303 style LCD navigation?
On Sat, 25 May 2013 19:56:19 -0700 (PDT), Morgan
thanks!
aldo
Old May 26th 13, 06:56 PM posted to rec.aviation.soaring
Dan Marotta
I use the K6BT. It plugs directly into my CAI302 and pairs with my Streak.
"cernauta" wrote in message
thank you very much
aldo cernezzi
www.voloavela.it
Sunlight readable PNAs sold with faulty GPS for flight PCool Soaring 0 March 26th 12 05:04 PM
Sunlight readable PNAs reviewed PCool Soaring 6 January 8th 12 02:10 AM
Cambridge 302 needle stops moving intermittently Eric Greenwell[_4_] Soaring 4 October 24th 11 12:36 PM
Flight navigation/moving map software for Android System Stephen Michalik Soaring 19 January 11th 11 05:02 AM
Cambridge GPS_NAV Model 20 with LCD Navigation Display for Sale Paul Cordell Soaring 4 March 5th 09 05:20 AM
