Flanker vs F-15
Old March 27th 04, 07:02 PM
Mary Shafer
On Fri, 26 Mar 2004 22:04:59 -0000, "Ken Duffey"
"Mary Shafer" wrote in message
I read this in one of the British aircraft magazines a few years back,
in an article comparing the F-18 with the similar Russian airplane.
At least once and a half as much fuel internal to the Hornet and the
author made the comment that the US had, historically, always carried
more internal fuel in its fighters, citing WW II aircraft numbers as
well.
Mary, you are WAY out on this one.
Yes, but only because I believed a seemingly reliable source.
As I was typing the remark about big countries it did cross my mind
that the USSR wasn't exactly small. And that using ground controllers
might not work in the more remote areas.
Oh, well. There's half my quota for the year.
Yes, the Flanker has a lot of internal fuel, more than the F-18 or
F-15. Reports to the contrary are wrong.
Mary
Mary Shafer Retired aerospace research engineer
Old March 27th 04, 07:07 PM
Tarver Engineering
well.
Was it some kook troll posting over a fraudulent sig file?
Really?
LOL
De Nile is not just a river in Egypt.
Old March 27th 04, 08:57 PM
Yep...and sometimes a cigar *IS* just a cigar!...
-Gord.
Old March 28th 04, 02:05 AM
monkey
"Tarver Engineering" wrote in message ...
"Steve" wrote in message
On Thu, 25 Mar 2004 02:44:04 -0600, "Boomer" wrote:
yes Flankers have a switch which over rides the FBW limits, that's the
only
way they can do the "Cobra" manuever.
Or you can simply apply an extra 33lb of stick force.
That is a lot, the F/A-18 breaks out at 20 lbs.
Not true - you are confusing this with aoa feedback in the stick above
20 alpha -to get more g than the programmed limiter (usually 7.5) you
must engage the paddle switch, which will then give you 33% more g.
Old March 28th 04, 02:34 AM
Tarver Engineering
"monkey" wrote in message
om...
only
I am refering to the force required to move the stick. My F-18 (AV6) had a
swich on the left panel to cut out the FCS much like the MiG.
  #28
Old March 28th 04, 04:46 AM
Boomer
excellent point about the LEF I hadent thought of that.
Does anyone know if these devices help more at high or low altitude?
Curiosity killed the cat, and I'm gonna find out why!
"Guy Alcala" wrote in message
Boomer wrote:
I'm no aerodynamicist but I've been running some numbers and noticed
some
interesting things.
The SU-27 is credited with being more manueverable than F-15 and yet
F-15
has a higher TTW number (except at gross) and a lower wing loading by a
large margin (again except at gross). The SU should develope more body
lift
than Eagle, but at best it looks like a wash at low altitudes, with
Eagle
turning better than SU at altitude.
Any thoughts? Am I missing something large here? The Su's lerx's and
higher
aspect wing should make a positive differance at low level and low
speeds
but I dont think it would make up for the other numbers. Eagle should
have a
20% better wing loading and about a 14% better TTW number.
My guess would be that in addition to the LERX it's the auto LEF, vs. a
fixed
LE, high-camber wing. The latter is lighter, but you'll note that every
maneuverable fighter designed after the F-15 has gone with LEF. McAir's
designers considered LEF, but decided against them on cost/weight grounds,
and
maybe on performance grounds in a certain part of the envelope. I've
always
wanted to ask whoever made the decision if, given the benefit of
hindsight,
they'd have gone the other way.
Guy
  #29
Old March 28th 04, 08:43 PM
monkey
om...
only
move the stick for what?
  #30
Old March 28th 04, 08:56 PM
Tarver Engineering
m...
om...
that's
only
had a
The stick moves to operate the cable actuated system control system.
Do you know the airplane at all, monkey sock?
OT-ish Su27 Flanker fans *might* enjoy... Andrew MacPherson Military Aviation 0 February 1st 04 11:33 AM
F-22 Comparison robert arndt Military Aviation 39 December 4th 03 04:25 PM
[New WebSite] Su-27 Flanker Benoit Military Aviation 0 November 11th 03 04:54 PM
Su-27SK(Upgraded), Su-27KUB & new Flanker book Thomas J. Paladino Jr. Military Aviation 6 July 28th 03 07:53 PM
RIAT Fairford Reviews John Cook Military Aviation 4 July 21st 03 07:36 PM
