For those of you who haven't seen it, try my B-58 Hustler home page link
below. Make sure you click on the ANNEX link. That's 3 pages of pictures and data on the Hustler. Don't forget to sign the new Guest Book. -- B-58 Hustler History: http://members.cox.net/dschmidt1/ - |
In article jin9c.9912$wl1.8157@fed1read06, Darrell
wrote: For those of you who haven't seen it, try my B-58 Hustler home page link below. Make sure you click on the ANNEX link. That's 3 pages of pictures and data on the Hustler. Don't forget to sign the new Guest Book. I have been keeping track of all of the retired B-58's that are still in existance. http://www.johnweeks.com/b58. -john- -- ================================================== ================== John A. Weeks III 952-432-2708 Newave Communications http://www.johnweeks.com ================================================== ================== |
Nice links, John,
I'll mark that site for use. -- B-58 Hustler History: http://members.cox.net/dschmidt1/ - "John A. Weeks III" wrote in message ... In article jin9c.9912$wl1.8157@fed1read06, Darrell wrote: For those of you who haven't seen it, try my B-58 Hustler home page link below. Make sure you click on the ANNEX link. That's 3 pages of pictures and data on the Hustler. Don't forget to sign the new Guest Book. I have been keeping track of all of the retired B-58's that are still in existance. http://www.johnweeks.com/b58. -john- -- ================================================== ================== John A. Weeks III 952-432-2708 Newave Communications http://www.johnweeks.com ================================================== ================== |
Low level flight. Back then, in the early 60s, there were no
restrictions on VFR low level, other than stay out of airport control zones, towns, and obey the general altitude restrictions. We used to fly cross country low level - lead doing the nav and wing watching for traffic. Down at 500 AGL and (usually) 360KIAS (for time - miles per gallon was pretty much the same at 360/420) there was very seldom anybody to be seen. We used to go into base ops, look at the weather map for a nice big H, grab a stack of ONC charts, tear off a four inch wide strip along the route, tape them together, draw the course line, put time and mileage marks on them and off we'd go. BTW a clean 104A could go 400 nm on the deck with plenty of fuel left. Later on the USAF made us file IFR and that did away (mostly) with the informal low levels. Walt BJ |
Poker Deck routes were low level VFR routes while Oil Burner (later Olive
Branch) routes were the IFR ones. Even the OB routes had VFR segments for terrain avoidance radar practice. I flew those in the B-52H. In the B-58 we also had high speed segments which we flew at 600 KIAS. -- B-58 Hustler History: http://members.cox.net/dschmidt1/ - "WaltBJ" wrote in message m... Low level flight. Back then, in the early 60s, there were no restrictions on VFR low level, other than stay out of airport control zones, towns, and obey the general altitude restrictions. We used to fly cross country low level - lead doing the nav and wing watching for traffic. Down at 500 AGL and (usually) 360KIAS (for time - miles per gallon was pretty much the same at 360/420) there was very seldom anybody to be seen. We used to go into base ops, look at the weather map for a nice big H, grab a stack of ONC charts, tear off a four inch wide strip along the route, tape them together, draw the course line, put time and mileage marks on them and off we'd go. BTW a clean 104A could go 400 nm on the deck with plenty of fuel left. Later on the USAF made us file IFR and that did away (mostly) with the informal low levels. Walt BJ |
Darrell wrote:
B-58 we also had high speed segments which we flew at 600 KIAS. Darrell, how did the B-58 ride at 600KIAS down low? The B-57 would crack your head on the canopy bouncing along at 360 on a hot day, near 500' AGL At least we were going slow enough to read the names of the towns as we went by............. Rick Clark MFE |
Darrell wrote: B-58 we also had high speed segments which we flew at 600 KIAS. Darrell, how did the B-58 ride at 600KIAS down low? The B-57 would crack your head on the canopy bouncing along at 360 on a hot day, near 500' AGL At least we were going slow enough to read the names of the towns as we went by............. It flew pretty smooth, Rick. With the delta wing it seemed like it cut through the turbulence. Sort of like water skiing. With 2 skis you feel every ripple. With a single slalom ski it bites deeper into the water and dampens out lots of the surface turbulence. With moderate turbulence we'd get an occasional slap-bang but not very bad. This, at a time when B-52s were aborting the route due to turbulence. Rick Clark MFE |
"Darrell" wrote in message news:sTnac.30514$wl1.6853@fed1read06... B-58 Hustler History: http://members.cox.net/dschmidt1/ Darrell wrote: B-58 we also had high speed segments which we flew at 600 KIAS. Darrell, how did the B-58 ride at 600KIAS down low? The B-57 would crack your head on the canopy bouncing along at 360 on a hot day, near 500' AGL At least we were going slow enough to read the names of the towns as we went by............. It flew pretty smooth, Rick. With the delta wing it seemed like it cut through the turbulence. Sort of like water skiing. With 2 skis you feel every ripple. With a single slalom ski it bites deeper into the water and dampens out lots of the surface turbulence. With moderate turbulence we'd get an occasional slap-bang but not very bad. This, at a time when B-52s were aborting the route due to turbulence. Since the B-58 community must have been rather small, given its limited production and service life, I wonder if you recall ever serving with a pilot by the name of Wright? He also flew the B-66/EB-66 at some point in his career. Brooks Rick Clark MFE |
"Kevin Brooks" wrote:
Since the B-58 community must have been rather small, given its limited production and service life, I wonder if you recall ever serving with a pilot by the name of Wright? He also flew the B-66/EB-66 at some point in his career. Brooks Did he have a brother?... ![]() -- -Gord. |
| Thread Tools | |
| Display Modes | |
| B-58 Hustler | Darrell | Military Aviation | 10 | February 23rd 04 07:14 PM |
| B-58 Hustler site | Darrell | Military Aviation | 16 | November 8th 03 01:55 AM |
| Aerofax B-58 Hustler volume signed by test pilots | Tim V | Military Aviation | 4 | September 8th 03 05:04 PM |
