The near mid-air at the Region 9 contest
Old June 20th 13, 07:41 PM posted to rec.aviation.soaring
Wallace Berry[_2_]
Default The near mid-air at the Region 9 contest
Brad wrote:
We're the pilots talking to each other on the radio?
I've only flown in 1 contest, but if I recall radio "chatter" was frowned
upon.
thanks,
Brad
(who has PowerFlarm and loves it)
"Barking dogs" as Spratt called them, are definitely frowned upon.
However, radio calls in the service of safety are definitely encouraged
by the rules as well as popular opinion. "WB, I'm at your 7 o'clock and
turning inside..." type calls are more than welcome.
Old June 21st 13, 01:36 AM posted to rec.aviation.soaring
waremark
About 10 years ago I had s mid-air collision on thermal entry. Happily, neither of us was hurt; we both came down safely on parachutes. If we had both had working Flarms (not available back then) the collision would not have occurred. So I think Flarm/Powerflarm is A GOOD THING.
I have slight reservations about this idea of using rental units at comps. I think you get used to using Flarm over time - the first time I experienced a Flarm warning I jumped out of my skin. And you get used to using it as an aid to scan rather than a distraction from it. Really, it would be better to do that not in a comp environment. And you have to work out how to fix and power the unit safely in your plane.
Mark Burton
London Gliding Club, Dunstable, UK (where Flarm is being adopted quite rapidly by the cross-country community, but it is not compulsory for any type of flying - and Powerflarm and transponders are both very uncommon)
upon.
thanks,
Brad
Old June 21st 13, 01:42 AM posted to rec.aviation.soaring
Ramy
I have slight reservations about this idea of using rental units at comps.. I think you get used to using Flarm over time - the first time I experienced a Flarm warning I jumped out of my skin. And you get used to using it as an aid to scan rather than a distraction from it. Really, it would be better to do that not in a comp environment. And you have to work out how to fix and power the unit safely in your plane.
Mark Burton
upon.
thanks,
Brad
One thing worth pointing, that even if someone is totally unfamiliar with how to use the unit, just turning it on and ignoring it or even turning down the volume, may be sufficient since it will still warn others.
Ramy
Old June 21st 13, 07:09 AM posted to rec.aviation.soaring
I got accommodated to Flarm on the first flight. I think the benefits so far exceed any learning curve concerns that I strongly favor a rental program.. Ramy makes a great point for those with a shallow learning curve. There is definitely momentum towards 100% compliance at contests in the US right now.
9B
Old June 21st 13, 12:42 PM posted to rec.aviation.soaring
Sean F (F2)
Agreed...but...I wonder if it would have, at least, better warned one of the pilots who could have made an adjustment to his/her flight path and avoided the close call. FLARM, for me at least, seems to do a very good job of beeping at me if I begin to close on another Flarm equiped glider in thermal entry. And if its really close its always been "going nuts" for many seconds before that potential collision can occur. At the same time if their is no decrease in relatively close range, its silent. As soon as the range begins decreasing, say I turn inside, it immediately warns both pilots by beeping violently. It's a good product.
It's far, far better that nothing I think and this kinda thing is exactly what Flarm is designed to prevent.
Anyhow. I have flarm in both the Lak and Eric just bought a Flarm brick for his 29, installing today for him in Ionia. I have had flarm since 2011 in Uvalde and I never fly without it, even when I fly by myself for power traffic!
How about flarm makes a one time discounted by for US pilots this summer? How about $1499 (the original discount price thru August 31 if 100 pilots join in the group buy)? Lets do something to motivate our fellow pilots to purchase one!
Sean
F2
Old June 21st 13, 08:11 PM posted to rec.aviation.soaring
mike
Mark Burton
upon.
thanks,
Brad
Ramy
Doesn't having a transponder also alert the Flarm unit/user?
Mike
Old June 21st 13, 08:31 PM posted to rec.aviation.soaring
Mike
Mode S will tell every flarm in miles where you are. Mode C is next to useless for flarm, and many flarm people will have turned mode c warnings down/off.
John Cochrane
Old June 21st 13, 09:39 PM posted to rec.aviation.soaring
mike
Mike
John Cochrane
I remain in stealth mode...with mode c. ;^)
Old June 22nd 13, 03:37 AM posted to rec.aviation.soaring
bumper[_4_]
Mike
John Cochrane
That is true IF the Mode S or C is operating in an ATC radar environment, or if it is being actively interrogated by a TCAS equipped aircraft. Otherwise, the flarm or PCAS will never know you're there.
That's part of the beauty of PowerFlarm, unlike a transponder, PF is an active system transmitting your position for other PF users to see.
Both PF and a transponder are important if you fly near gliders or powered aircraft . . . it's not a one or the other deal, though depending on where you fly, one might be more advantageous to have than the other, though both is best.
bumper
Old June 22nd 13, 09:39 AM posted to rec.aviation.soaring
Ramy
John can you elaborate? That's the first time I hear that there is a difference between mode C and mode S as for PCAS alert? AFAIK both will provide approximate distance, altitude difference and no direction.
Ramy
Region V So Contest, USA Hartley Falbaum[_2_] Soaring 0 April 16th 12 02:12 AM
NEW REGION 2 CONTEST J9 Soaring 0 May 15th 11 02:35 PM
Region 3 contestants Welcome-Region Six North Contest Ionia November Bravo Soaring 0 August 13th 09 12:53 PM
Region 12 contest g l i d e r s t u d Soaring 0 December 17th 07 06:35 PM
(US) Region 11 Contest Pat Russell Soaring 2 July 13th 06 09:29 PM
