PW-5 Main Tire Pressure?
Old June 22nd 13, 06:58 PM posted to rec.aviation.soaring
JohnDeRosa
Default PW-5 Main Tire Pressure?
On our PW-5 the main tire (aft of the CG) is labeled 0.35MPa (mega pascals). The POH says the same thing.
This converts to 50.8 PSI which seems really high to us.
The tire is a 400x4 TOST Aero.
Thanks, John
PS The Nose Wheel is
Old June 22nd 13, 08:36 PM posted to rec.aviation.soaring
shkdriver shkdriver is offline
Member
First recorded activity by AviationBanter: Aug 2008
Thanks, John
My 1967 SHK uses the same 400X4 tire and has a POH tire pressure of 49 PSI.
By the way, the tire only looks properly inflated with that pressure. less looks "flat" SHK max gross 820 lbs or so.
Scott W
Old June 23rd 13, 12:21 AM posted to rec.aviation.soaring
JohnDeRosa
Completing my transient thought....
PS The nose wheel is to be inflated to 0.2 MPa = 29.0 PSI.
Old June 23rd 13, 09:38 AM posted to rec.aviation.soaring
plantain
Discus 2a has a TOST Aero 400x4. Manual says 73psi, and that's what I keep it at.
-matthew
Thanks, John
Accurate tire pressure gage? Kurt Thams Soaring 6 September 25th 12 11:17 PM
Trailer tire pressure remote monitoring systems Eric Greenwell Soaring 11 August 9th 08 06:03 AM
Tire tread wear vs inflation pressure Ben Jackson Owning 22 October 6th 06 04:35 AM
High Oil Pressure (was: Low oil pressure, high oil temp?) Thomas Ploch Owning 4 October 5th 04 04:34 AM
Tire inflation pressure Paul Lee Home Built 80 November 19th 03 07:56 AM
