Glider accident while filming commercial in 2011. NTSB Report updated
Old June 29th 13, 03:22 PM posted to rec.aviation.soaring
Nigel Pocock[_2_]
Default Glider accident while filming commercial in 2011. NTSB Report updated
Excessive initial ecceleration can cause problems with certain types. I
have experienced it with 2 types.
PW5 with stick fully forward at the start of the launch. Hard acceleration
caused the glider to rotate from the nose wheel to the tail wheel and
rocket into the air. I only managed to regain control at about 50ft.
The other one is the K8. Light glider, high wing. Similar problem.
If slow acceleration is a safety problem what about the ground run and take
off with aerotow using belly hooks, and autotows?
  #122
Old June 29th 13, 03:42 PM posted to rec.aviation.soaring
Bill D
K8's and PW-5's, as with all "nose dragger's, are supposed to rotate back onto their tail wheels. What do you mean exactly by "regained control"? You're still with us so, presumably, it worked. With those gliders you should have started the ground roll with the stick full forward.
Aero tow with a CG hook isn't safe as discussed elsewhere on this forum. However a tug can't generate the forces a winch can so a wing drop induced ground loop likely won't be as severe.
  #123
Old June 29th 13, 07:32 PM posted to rec.aviation.soaring
Bill D
Here's a PW-5 winch launch done right. Note the 1 second ground roll.
http://www.youtube.com/watch?v=IseFvZXK7Dw
Here's a K8 also with a one second ground roll.
http://www.youtube.com/watch?v=ict8W0Q5ZpA
Both of these launches were at accelerations greater than 1G. Neither showed an "uncommanded" pitch up. So, neither the gliders nor the acceleration are a problem.
  #124
Old June 29th 13, 11:16 PM posted to rec.aviation.soaring
Andy[_1_]
"Aero tow with a CG hook isn't safe"
bull****!
  #125
Old June 30th 13, 07:46 AM posted to rec.aviation.soaring
BruceGreeff
Default Glider accident while filming commercial in 2011. NTSB Reportupdated
There is a lot of that around.
GC hook is a little more work on aerotow but not intrinsically unsafe.
Possibility of kiting is greater, and the glider is easier to get out of
position laterally. Conversely, the glider is easier to get where you
want it laterally...
Many aerotows later on a CG hook on a Std Cirrus.
bull****!
Bruce Greeff
T59D #1771
  #126
Old June 30th 13, 07:49 AM posted to rec.aviation.soaring
BruceGreeff
Thanks for the info Andreas.
Not that the reporting is that diligent in either case when far from home.
And BGA Numbers include any that occurred to a BGA member, anywhere, in
any registration.
Bruce
On 2013/06/29 2:23 PM, Andreas Maurer wrote:
On Fri, 28 Jun 2013 09:56:50 +0200, BruceGreeff
Indeed.
As an example - the BGA statistics include any accident or incident
reported by a member anywhere in the world. So their numbers include
locations in Spain and South Africa.
The German numbers do not.
I express no opinion on which is a better approach. Merely that the one
is organisational statistics and the other is geographic.
HI Bruce,
German accident statistics include any accident/incident that happened
on a German airfield, in Germany, or in which a German registered
aircraft was involved, worldwide.
Cheers
Andreas
Bruce Greeff
T59D #1771
  #127
Old July 1st 13, 03:58 PM posted to rec.aviation.soaring
Nigel Pocock[_2_]
If Bill D could be bothered to read my posting before spouting a reply he
wouls see that I had started the launch with full forward stick in both
cases.
Hard acceration with these gliders can cause the tail to hit the ground
hard - not safe. To avoid this the tail of the K8s are usually held down
for the launch. Too hard acceration can cause the glider to shoot into the
air and immediately into a 45 degree climb despite the stick position. If
the rope breaks at this point you have too little height to recover. Hence
the winch driver will give slower initial acceleration with these types.
By regained control I mean the elevator having any effect. Until then you
are just a passenger.
I was always taught with ground launch to keep it straight and level until
the glider lifts off in a shallow climb. When a safe speed had been reached
to rotate steadily into a full climb. At any point in this process you can
still recover and land safely using the correct procedures - as taught be
both the german and british systems.
=20
have experienced it with 2 types.=20
=20
acceleratio=
n
=20
=20
=20
=20
=20
=20
ta=
ke
=20
o=
Yo=
shoul=
H=
g=
  #128
Old July 1st 13, 04:44 PM posted to rec.aviation.soaring
Bill D
Nigel, I read your post and it's mostly an "old wives tale".
Yes, gliders lower their tails which can be an issue on hard surfaces so someone holds them down as seen in the PW-5 video. On turf, it's a non-issue.. However, it has nothing to do with acceleration causing premature uncommanded rotation. The tailwheel on the ground prevents it. Glider's don't "shoot into the air" or do anything else inappropriate under 1G acceleration. It's been thoroughly flight tested.
cases.
=20
=20
acceleratio=
n
=20
=20
=20
=20
=20
=20
ta=
ke
=20
o=
Yo=
shoul=
H=
g=
  #129
Old July 1st 13, 05:47 PM posted to rec.aviation.soaring
John Galloway[_1_]
Leaving aside the tail hitting the ground aspect, a glider doesn't
necessarily stop accelarating just because it has left the ground
- in fact it is sometimes quite noticeable to me (in a Discus
2cT) that the accelaration is increasing after lift off - especially
with a powerful winch that is capable of acheiving a safe cable
speed of 60+ knots (depending on the type being launched).
Long ago, even with a low powered old winch and far less than
1g acceleration, I remember routinely having to keep the stick
forward in a K8 to prevent over-rotation.
I put my trust in the BGA advice on winch launching which is
based on many decades of experience by dozens of clubs,
thousands of individual pilots and instructors, and with
numerous winch and glider types.
John Galloway
surfaces so
so=
it's a
non-issue=
premature
uncomma=
Glider's don't
"s=
acceleration.=
spouting a reply he
=20
stick in both
=20
cases.
=20
the ground
=20
held down
=20
shoot into
th=
e
=20
position. If
=20
recover.
Henc=
e
=20
these types.
=20
Until then you
=20
=20
and level
unti=
l
=20
had been
reach=
ed
=20
process you
ca=
n
=20
as taught be
=20
=20
=20
=20
=20
=20
=20
Pocock wrote:
=20
certain types.
I
=20
=3D20
=20
have experienced it with 2 types.=3D20
=20
=3D20
=20
Hard
=20
acceleratio=3D
=20
n
=20
=3D20
=20
tail wheel and
=20
=3D20
=20
about 50ft.
=20
=3D20
=20
problem.
=20
=3D20
=20
=3D20
=20
=3D20
=20
ground run and
=20
ta=3D
=20
ke
=20
=3D20
=20
=20
=20
supposed to rotate
bac=
k
=20
o=3D
=20
"regained control"?=
=20
=20
Yo=3D
=20
gliders you
=20
shoul=3D
=20
=20
=20
on this
forum.=
=20
=20
H=3D
=20
wing drop
induce=
d
=20
g=3D
=20
=20
  #130
Old July 1st 13, 07:56 PM posted to rec.aviation.soaring
Bill D
John Galloway
John, your post is too confused to answer. Keep in mind what is considered "normal" in the UK has not resulted in an enviable safety record. Instead of constantly retelling anecdotal stories to each other, maybe you should study the actual physics and what's done in other countries.
NTSB crash report, autopsy report- Stevie Ray Vaughan Mark. Piloting 5 March 22nd 20 10:17 PM
NTSB Report on Bill Phillips' Accident Ron Wanttaja[_2_] Home Built 63 September 29th 09 12:02 PM
Preliminary NTSB report on Walton accident ChuckSlusarczyk Home Built 11 July 12th 05 04:23 PM
Prelim NTSB report, Pilatus accident in PA vincent p. norris Piloting 15 April 11th 05 02:52 PM
NTSB Aircraft Accident Reports Updated Daily? [email protected] Owning 2 March 4th 05 01:25 PM
