Any Hints for servicing Tost Master Cylinder (Type 7)?
Old July 9th 13, 04:01 PM posted to rec.aviation.soaring
Default Any Hints for servicing Tost Master Cylinder (Type 7)?
Specifically, is there an easy way to seat/move into the proper position the "Seal G" on the master piston?
I've lubricated with brake fluid, but had my first attempt result in a snapped/failed seal.
Any experienced hints would be appreciated.
Tim EY
Old July 17th 13, 09:12 AM posted to rec.aviation.soaring
Ventus2NZ
Tim EY
I found the very same problem with 2 seals supplied from Tost. It appears the seal in the kit is the incorrect size or old stock that is no longer supple enough to fit over the flange.
Alan.
Master cylinder rebuild? J. Murray Soaring 4 September 28th 12 04:41 AM
www.soaringdata.info hints (US) 2KA Soaring 0 March 25th 11 04:43 PM
Grob 103 Twin II Brake Master Cylinder Mike McCarron Soaring 28 November 23rd 08 03:33 PM
ATC subtle hints kontiki Piloting 76 October 25th 06 01:13 AM
Need G-103 Acro Master Cylinder Ray Lovinggood Soaring 5 September 30th 03 03:39 AM
