Flanker vs F-15
Old March 29th 04, 01:14 AM
monkey
"Tarver Engineering" wrote in message ...
"monkey" wrote in message
m...
om...
"Steve" wrote in message
On Thu, 25 Mar 2004 02:44:04 -0600, "Boomer"
yes Flankers have a switch which over rides the FBW limits,
that's
only
way they can do the "Cobra" manuever.
Or you can simply apply an extra 33lb of stick force.
That is a lot, the F/A-18 breaks out at 20 lbs.
Not true - you are confusing this with aoa feedback in the stick above
20 alpha -to get more g than the programmed limiter (usually 7.5) you
must engage the paddle switch, which will then give you 33% more g.
I am refering to the force required to move the stick. My F-18 (AV6)
had a
swich on the left panel to cut out the FCS much like the MiG.
move the stick for what?
The stick moves to operate the cable actuated system control system.
Do you know the airplane at all, monkey sock?
I'm actually talking about CAS - the only FCS configuration you would
EVER fight the Hornet in - not DEL or MECH modes.
  #32
Old March 29th 04, 06:28 AM
Tarver Engineering
om...
m...
om...
that's
only
above
you
g.
(AV6) had a
I take it you never flew the airplane.
  #33
Old March 29th 04, 04:56 PM
monkey
om...
m...
om...
that's
only
above
you
g.
(AV6) had a
you know what- I' don't need to justify what I've done to some wannabe
clown- if you've flown it you would know that all the DEL modes
(analog, digital, etc)and MECH are backup modes only for when the CAS
system fails. Besides, I'm on this board for entertainment purposes
only - the one I read for real professional discussion, you can't get
on unless you can prove you're a military pilot. I noticed you're not
on it Tarver.
  #34
Old March 29th 04, 05:15 PM
Tarver Engineering
om...
om...
system fails.
Or when CAS is switched out. Which is the way an F-18 can do a cobra like a
Flanker.
on it Tarver.
I did however design the HARV simulator at NASA and I am well aware of how
an F/A-18 works. (first accurate F/A-18 simulator)
  #35
Old March 30th 04, 03:06 AM
monkey
om...
om...
system fails.
Flanker.
on it Tarver.
OK, now I see where you are coming from - academically. It's taken
awhile for me to see your viewpoint. Operationally, one never uses any
mode except for CAS - there's no need to unless it craps out or you
get battle damage resulting in it. Referring to the checklist, DEL ON,
MECH ON, FCS CAUT, AIL OFF, FC AIR DAT, FCS HOT, FLAPS OFF, FLAP
SCHED, R LIM OFF, RUD OFF are all considered EMERGENCY situations and
are dealt with as such. I guess the test pilot dudes might play around
with that sort of stuff, but never the line guys.
  #36
Old March 30th 04, 03:20 AM
Tarver Engineering
om...
om...
om...
system.
would
system fails.
like a
Flanker.
on it Tarver.
how
The line guys need to know the emergency procedure of breaking the stick out
in order to be safe. The fact that you are still disputing that seems odd
to me.
  #37
Old March 30th 04, 04:11 AM
John Weiss
"Tarver Engineering" wrote...
....and I take it you never flew an airplane.
  #38
Old March 30th 04, 04:41 AM
Matthew G. Saroff
"Ken Duffey" wrote:
The internal fuel load of a Su-27 Flanker is 9,400kg, on the F-15C it s
5,950kg (or 6,103 depending on source), the F-18 is 4,900kg.
Range without drop tanks is 3,680km for the Su-27, 1,970km for the F-15C &
2,200 for the F-18.
It should be noted that the Su-27 is G-limited with a
full fuel load. Some of the internal tanks are not designed for
manoeuver when full.
--Matthew Saroff
I'm not an actor, but I play one on TV.
Check http://www.pobox.com/~msaroff, including The Bad Hair Web Page
  #39
Old March 30th 04, 05:49 AM
Tarver Engineering
"John Weiss" wrote in message
I flew the simulator, which puts me ahead of either of you WRT how the
operator inputs work. Monkey was playing a little game and got caught, but
I have never been one to believe pilots know how airplanes work. That would
be silly.
Of course these days the civil side of the system is beginning to drive out
operator ignorance. It is something that should have been done long ago.
  #40
Old March 30th 04, 09:34 AM
Eunometic
Mary Shafer wrote in message . ..
On Fri, 26 Mar 2004 22:04:59 -0000, "Ken Duffey"
"Mary Shafer" wrote in message
I read this in one of the British aircraft magazines a few years back,
in an article comparing the F-18 with the similar Russian airplane.
At least once and a half as much fuel internal to the Hornet and the
author made the comment that the US had, historically, always carried
more internal fuel in its fighters, citing WW II aircraft numbers as
well.
Mary, you are WAY out on this one.
Yes, but only because I believed a seemingly reliable source.
As I was typing the remark about big countries it did cross my mind
that the USSR wasn't exactly small. And that using ground controllers
might not work in the more remote areas.
Oh, well. There's half my quota for the year.
Yes, the Flanker has a lot of internal fuel, more than the F-18 or
F-15. Reports to the contrary are wrong.
Mary
The F15 has those conformal fastpacks on the sides of the intakes that
effectively raise the fuel level.
OT-ish Su27 Flanker fans *might* enjoy... Andrew MacPherson Military Aviation 0 February 1st 04 11:33 AM
F-22 Comparison robert arndt Military Aviation 39 December 4th 03 04:25 PM
[New WebSite] Su-27 Flanker Benoit Military Aviation 0 November 11th 03 04:54 PM
Su-27SK(Upgraded), Su-27KUB & new Flanker book Thomas J. Paladino Jr. Military Aviation 6 July 28th 03 07:53 PM
RIAT Fairford Reviews John Cook Military Aviation 4 July 21st 03 07:36 PM
