Slip slidin' away.
Old August 30th 13, 08:45 AM posted to rec.aviation.soaring
Uncle Fuzzy[_2_]
Default Slip slidin' away.
For fun. If you get the chance to fly a Janus up high. Play with slips. It will 'lock over' to either side, dropping like a set of car keys (Thanks for that image JS) and the canopy mounted yaw string (s) will be pointing..... well, you'll see.
I started playing with this about the time that Jonkers broke a rudder cable and the guy had to bail. Having read Derek Piggot's warning about the Janus, and realizing it really took a LOT of pedal force to straighten up, I started thinking about 'recovery' if one of my 30+ year old rudder cables broke. Turns out it IS recoverable, but involves a lot of elevator, and eats a lot of altitude. From a mile AGL, it's doable.
Wondering how long my wandering will persist.
Old August 30th 13, 03:30 PM posted to rec.aviation.soaring
John Galloway[_1_]
Just to address the reference to the JS1 accident, according to
Uys Jonker speaking at the BGA conference, what happened
there was not a broken rudder cable but similar to what you
describe in the Janus (and various other gliders) i.e. a situation
of a high pedal force required to overcome a locked-over rudder
in a side slip.
This scenario is described in the JS1 flight manual as:
"WARNING: If an excessive slip angle is not corrected with
opposite rudder input, the secondary effect of yaw may cause
the sailplane to roll and enter a spiral dive. It is not possible to
prevent roll by applying full opposite aileron during excessive
sideslip.
CAUTION: The rudder control input force to recover from a side
slip exceeding 20° is high (approximately 20daN) and increases
if the speed is allowed to build up during the resulting spiral
dive. Apply sufficient rudder input to recover from the sideslip to
prevent spiral dive."
John Galloway
with slips.
I=
(Thanks
be
pointing..=
rudder
cabl=
about the
Jan=
straighten up, I
s=
rudder cables
br=
and eats
a lot of altitude. From a mile AGL, it's doable.=20
Old August 30th 13, 04:29 PM posted to rec.aviation.soaring
mike
Is that right?
The sister ship also at the same field had the same problem. Luckily it failed on the ground. I was shown the frayed cable prior to its complete failure.
Mike
in a side slip.
sideslip.
John Galloway
with slips.
I=
(Thanks
be
pointing..=
rudder
cabl=
about the
Jan=
straighten up, I
s=
rudder cables
br=
and eats
The FAA inspected the sailplane and found a worn through rudder cable. The sister ship, at the same field, had the same problem and failed on the ground.
Old August 30th 13, 05:10 PM posted to rec.aviation.soaring
John Galloway[_1_]
It is certainly right insofar as that was what was described in
the Jonker Sailplanes presentation to the BGA conference and
has also been added to the flight manual V3. As someone on
the JS1 waiting list I was listening attentively and I knew that
the original suspicion had been of a broken rudder cable and
also that JS1 rudder cable S tubes had been modified after the
accident.
Has an accident investigation report been published in the US?
John Galloway
At 15:29 30 August 2013, mike wrote:
Is that right?
Luckily it
fa=
complete
fail=
ure.
Mike
to=20
=20
happened=20
=20
you=20
=20
situation=20
=20
rudder=20
=20
in a side slip. =20
=20
=20
=20
=20
=20
=20
with=20
=20
cause=20
=20
to=20
=20
excessive=20
=20
sideslip.
=20
=20
=20
side=20
=20
slip exceeding 20=B0 is high (approximately 20daN) and
increases=20
=20
spiral=20
=20
sideslip to=20
=20
=20
=20
=20
John Galloway
=20
=20
=20
=20
Play=20
=20
with slips.
=20
I=3D
=20
keys=20
=20
(Thanks
=20
=3D
=20
will=20
=20
be
=20
pointing..=3D
=20
=20
broke a=20
=20
rudder
=20
cabl=3D
=20
warning=20
=20
about the
=20
Jan=3D
=20
us, and realizing it really took a LOT of pedal force to=20
=20
straighten up, I
=20
s=3D
=20
old=20
=20
rudder cables
=20
br=3D
=20
elevator,=20
=20
and eats
=20
=3D
=20
a lot of altitude. From a mile AGL, it's doable.=3D20
=20
=20
=20
rudder cable. The
on the
grou=
nd.
Old August 30th 13, 05:45 PM posted to rec.aviation.soaring
Wallace Berry[_2_]
well, you'll see.
Would love to fly a Janus sometime. Never even seen one in person.
I have played with full rudder slips in a 301 Libelle and a Standard
Cirrus above 6000 ft agl, at around 50 knots starting airspeed. Nothing
happened in the Libelle except for flying fairly sideways and generating
a pretty good sink rate. Tried gradually pulling the nose up to see at
what attitude/airspeed it would start to misbehave. Airspeed was not
reading due to the extreme slip. Thought it would depart and spin before
the nose got too high. I chickened and relaxed the stick when I felt
more buffeting and the controls started getting slack. It flew ok in a
slip with the nose at an attitude I would consider highly alarming close
to the ground. Slipping the Cirrus, the rudder would go hard over to the
right if I got close to full right rudder. Surprised me a bit the first
time it happened. Felt like I was suddenly flying directly sideways. Did
not take inordinate effort to recenter the rudder and the glider behaved
itself just fine. Should try it with the nose up sometime.
If there is one good thing about training in Schweizers, it's that one
learns to slip for glidepath control.
WB (who has also slipped Cezznas with full flaps).
Old August 30th 13, 07:19 PM posted to rec.aviation.soaring
Bill D
accident.
John Galloway
NTSB Identification: CEN12LA265
Old August 30th 13, 08:02 PM posted to rec.aviation.soaring
John Galloway[_1_]
Thanks Bill but that link only consists of the initial pilot's report.
Old August 30th 13, 10:31 PM posted to rec.aviation.soaring
kirk.stant
In glass, it's not the slip that is the problem - it's trying to land afterwards without using dive brakes that can be really interesting (and expensive)!
Unfortunately, that is not a problem in a Schweizer, so bad habits can (and have) transfer - and lead to broken gliders.
Kirk (who has also tried the dreaded Cezzna full flap slip)
66
Old August 31st 13, 08:51 AM posted to rec.aviation.soaring
Ramy
I find it disturbing that no follow up that I am aware off was published yet about the cause of this incident by the pilot or anyone else who knows about it. If I was flying a JS1 I would be even more disturbed. Now we all know we can't trust the NTSB to teach us anything about the cause of glider accidents, but one would hope that at least we will be sharing information among ourselves, so we don't have yet another one of those "too bad he wasn't aware of this".
Ramy
Old August 31st 13, 10:51 AM posted to rec.aviation.soaring
John Galloway[_1_]
I too would like to see a full report into the US accident but I
doubt that JS1 pilots will be at all disturbed now when they are
flying:
If the US accident was the result of the rudder cable fraying
(which clearly was a design issue) and then breaking in flight
then that should be fixed by the modification to the rudder
pedal S tube design by adding bell ends and sleeve inserts to
protect the cables (Technical Note TN.JS-010 06 July 2012).
If it was due to misinterpretation of the rudder over-locking in a
side slip then that aspect has been highlighted in the flight
manual.
John Galloway
published
ye=
who knows
ab=
Now we all
kn=
cause of glider
a=
information
a=
"too bad he
wasn'=
t aware of this".
Ramy
Slip (balance) and Turn indicator mikeaaron353 General Aviation 1 March 30th 13 02:16 AM
PZL EZS-3 Turn and slip UncleMart Soaring 7 April 12th 11 04:42 PM
SLIP/SKID INDICATORS [email protected] Soaring 0 December 26th 07 10:13 PM
Side slip Jim Naval Aviation 4 December 6th 06 07:18 PM
A Waikerie slip up? Vassilios Mazis Soaring 4 July 28th 03 11:34 PM
