FLARM antenna mounts for ASG-29
Old September 2nd 13, 02:13 PM posted to rec.aviation.soaring
Sean F (F2)
Default FLARM antenna mounts for ASG-29
I have seen some beautiful setups with nice antenna holders for the powerflarm brick. Where do you buy these or are they built by the owners? Any tips would be welcomed.
Happy Labor Day!
Sean
Old September 2nd 13, 05:28 PM posted to rec.aviation.soaring
bumper[_4_]
Happy Labor Day!
Sean
First find out if the nose on your ship is reinforced with CF . . .
Rex Mayes has been installing the small center fed dipole antennas inside the nose on the ASH26E. That works very well, as the wall of the nose is fiberglass. Unfortunately, on the 31Mi there is a course weave of carbon, that you can easily see looking from the inside with strong light outside, which precludes that location due to the carbon. Not sure about the ASG-29.
Anyway, with the carbon reinforced nose you have fewer options. I've seen a couple of installs with the dipoles mounted under the glareshield with the upper radiator poking through a hole in the shield. Sub-optimal due to the metal bits and equipment blocking the RF, but I'm guessing it still works.
bumper
Old September 2nd 13, 06:35 PM posted to rec.aviation.soaring
Sean F (F2)
Used a cardboard temp and it works right out of the box. Impressive. The oudie shows me riding my bike around the airport with a portable. Will build (wish this was commercially available) a nicer one this winter when able.
Thanks!!
Sean
Old September 2nd 13, 06:39 PM posted to rec.aviation.soaring
Richard[_9_]
I have seen some beautiful setups with nice antenna holders for the powerflarm brick. Where do you buy these or are they built by the owners? Any tips would be welcomed. Happy Labor Day! Sean
Sean,
Some other antenna options that are cleaner and work. I believe the 2.3" will fit in the 29. Measure the height available, if you can fit the 3.4 use it. They also have a 18" cable length so less loss.
http://www.craggyaero.com/cables_&_antennas.htm
Richard
www.craggyaero.com
Old September 2nd 13, 09:39 PM posted to rec.aviation.soaring
SteveB_Z5
I know someone who made antenna holders with a 3D printer.
Old September 2nd 13, 11:09 PM posted to rec.aviation.soaring
On Monday, September 2, 2013 1:39:02 PM UTC-4, Richard wrote:
On Monday, September 2, 2013 6:13:15 AM UTC-7, Sean F (F2) wrote: I have seen some beautiful setups with nice antenna holders for the powerflarm brick. Where do you buy these or are they built by the owners? Any tips would be welcomed. Happy Labor Day! Sean Sean, Some other antenna options that are cleaner and work. I believe the 2.3" will fit in the 29. Measure the height available, if you can fit the 3.4 use it. They also have a 18" cable length so less loss. http://www.craggyaero.com/cables_&_antennas.htm Richard www.craggyaero.com
There are photos on the ASW-27 group site showing PF installation using above antenna.
UH
Old September 4th 13, 09:31 PM posted to rec.aviation.soaring
Morgan[_2_]
I have had really good results building mounts from plexiglass. You can buy inexpensive 1/8" sheets at any hardware store and easily cut it with a fine jigsaw. With a heat gun you can bend, twist and form it to a variety of shapes and it remains clear and strong once it cools.
May be worth trying out for your needs.
UH
Old September 5th 13, 01:42 AM posted to rec.aviation.soaring
Craig R.
Consider the "what if" if you have to jettison your canopy. You don't want the antenna wires restricting the canopy ejection during an emergency.
Craig
Old September 5th 13, 03:02 PM posted to rec.aviation.soaring
Dan Marotta
It's doubtful those flimsy cables/mounts would retain a canopy against the
relative wind.
"Craig R." wrote in message
Craig
Old September 5th 13, 09:09 PM posted to rec.aviation.soaring
Craig R.
Dan, some of the top pilots in the world flying 29's will disagree with you and have taken precautions for their antenna installation.
relative wind.
PowerFLARM antenna mounts Dave Nadler Soaring 52 August 14th 14 01:34 PM
Nice FLARM antenna mount in ASG-29 Dave Nadler Soaring 8 April 6th 13 09:49 PM
Again with FLARM antenna questions. brianDG303[_2_] Soaring 0 July 23rd 12 05:35 PM
PowerFLARM antenna mounts Dave Nadler Soaring 0 July 4th 12 04:11 PM
FLARM antenna installation Kevin Neave Soaring 5 January 16th 07 06:53 PM
