IGC-approval documents for a number of types of Flight Recorders have been updated to include IGC-approval levels that will apply from 1 October 2013.
This is the final stage of a two year process following the 2011 ANDS/GFAC paper on FR Security that was approved by the IGC Bureau and Plenary. On 1 October 2013 the following types of older FR will be at "Badge Flights up to and including Diamonds" level: LX Navigation DX50, LX20, LX21, LX5000; also the SDI Posigraph and Zander 940. This also applies to the LX Navigation Colibri versions 1 and 4, unless updated to Firmware version 8 which includes a security update for which the Approval level is flights for "all IGC badges and Distance Diplomas". There are 47 different types of IGC-approved Flight Recorders from 17 different manufacturers. For the GFAC web site, see: www.ukiws.demon.co.uk/GFAC The table of all IGC-approved FRs with links to Approval Documents is at: www.ukiws.demon.co.uk/GFAC/igc_approved_frs.pdf This document contains: (1) a table of all types of IGC-approved Flight Recorders in alphabetical order of manufacturer name, with links to their IGC-approval documents. (2) a table of Manufacturers of IGC-approved Flight Recorders, in alphabetical order of manufacturer name. (3) a list of all IGC-approval activity from 1996 to the present day. (4) a history of IGC GNSS Flight Recording. -------------------------- For the IGC web site: http://www.fai.org/gnss-recording-de...ight-recorders Scroll down to "IGC-Approved Flight Recorders - Approval Documents" Then click on the box underneath the above heading which says: "IGC-approval Documents for all IGC-approved Flight Recorders". This will call up a list of documents, the first one being "IGC-approval tables" with links to individual Approval documents. This is followed by IGC-approval documents in alphabetical order of manufacturer’s name. Scroll down to the Recorder type and click on its name. The IGC-approval document will then download automatically to the directory that you have set for downloads, without being displayed on screen first. ------------------------- IGC-approval follows test and evaluation by the IGC GNSS Flight Recorder Approval Committee (GFAC) in accordance with Annex B to the Sporting Code for gliding and the Technical Specification for IGC-approved GNSS Flight Recorders. The Technical Specification is available through the igc-approved-flight-recorders web site above or directly from the GFAC web site: http://www.ukiws.demon.co.uk/GFAC/do..._spec_gnss.pdf The Sporting Code for gliding (SC3) and its annexes A-D may be downloaded via www.fai.org/igc-documents ------------------------ Ian Strachan Chairman, IGC GNSS Flight Recorder Approval Committee www.ukiws.demon.co.uk/GFAC |
Ian,
It might be useful to clarify the hierarchy, as it's not always 100% clear to people (me included). So, as I understand it: - "Up to and including Diamonds" means that Diplome Fights and World Records are the only flights that are precluded? - "all IGC badges and Distance Diplomas" means that only World Record flights are precluded? Erik Mann On Monday, September 9, 2013 5:01:13 AM UTC-4, Ian Strachan wrote: IGC-approval documents for a number of types of Flight Recorders have been updated to include IGC-approval levels that will apply from 1 October 2013. This is the final stage of a two year process following the 2011 ANDS/GFAC paper on FR Security that was approved by the IGC Bureau and Plenary. On 1 October 2013 the following types of older FR will be at "Badge Flights up to and including Diamonds" level: LX Navigation DX50, LX20, LX21, LX5000; also the SDI Posigraph and Zander 940. This also applies to the LX Navigation Colibri versions 1 and 4, unless updated to Firmware version 8 which includes a security update for which the Approval level is flights for "all IGC badges and Distance Diplomas". There are 47 different types of IGC-approved Flight Recorders from 17 different manufacturers. For the GFAC web site, see: www.ukiws.demon.co.uk/GFAC The table of all IGC-approved FRs with links to Approval Documents is at: www.ukiws.demon.co.uk/GFAC/igc_approved_frs.pdf This document contains: (1) a table of all types of IGC-approved Flight Recorders in alphabetical order of manufacturer name, with links to their IGC-approval documents. (2) a table of Manufacturers of IGC-approved Flight Recorders, in alphabetical order of manufacturer name. (3) a list of all IGC-approval activity from 1996 to the present day. (4) a history of IGC GNSS Flight Recording. -------------------------- For the IGC web site: http://www.fai.org/gnss-recording-de...ight-recorders Scroll down to "IGC-Approved Flight Recorders - Approval Documents" Then click on the box underneath the above heading which says: "IGC-approval Documents for all IGC-approved Flight Recorders". This will call up a list of documents, the first one being "IGC-approval tables" with links to individual Approval documents. This is followed by IGC-approval documents in alphabetical order of manufacturer’s name. Scroll down to the Recorder type and click on its name. The IGC-approval document will then download automatically to the directory that you have set for downloads, without being displayed on screen first. ------------------------- IGC-approval follows test and evaluation by the IGC GNSS Flight Recorder Approval Committee (GFAC) in accordance with Annex B to the Sporting Code for gliding and the Technical Specification for IGC-approved GNSS Flight Recorders. The Technical Specification is available through the igc-approved-flight-recorders web site above or directly from the GFAC web site: http://www.ukiws.demon.co.uk/GFAC/do..._spec_gnss.pdf The Sporting Code for gliding (SC3) and its annexes A-D may be downloaded via www.fai.org/igc-documents ------------------------ Ian Strachan Chairman, IGC GNSS Flight Recorder Approval Committee www.ukiws.demon.co.uk/GFAC |
| New flight recorder - flyWithCE Flight Recorder | uros | Soaring | 12 | May 5th 09 09:31 PM |
| Updates to IGC approval documents for GNSS flight recorders | Ian Strachan | Soaring | 2 | September 27th 04 02:32 PM |
| Updated IGC-approval documents for some types of GPS Recorders | Ian Strachan | Soaring | 1 | April 13th 04 04:23 AM |
| New and updated IGC-approval documents for GNSS Flight Recorders | Ian Strachan | Soaring | 0 | November 25th 03 06:55 PM |
| Updated IGC approval documents for Cambridge GNSS flight recorders | Ian Strachan | Soaring | 0 | August 27th 03 06:28 PM |
