#31
You might consider going to a Cross Country Camp. In a week you have lectures in the morning from experienced cross country pilots and flying during the afternoon, sometimes dual. Air Sailing has a good one as do other glider-ports. Thanks, have you read the thread? |
#32
Tom,
If you can, come to the Champs next June at Caesar Creek Club in Ohio. They will be in June, and you will learn more in a week and a half there than you can learn in 2 years on your own. It is a friendly site, and there will be people that will be glad to help and mentor you. Kevin 192 |
#33
Bob Whelan wrote, On 9/11/2013 8:39 PM:
On 9/11/2013 5:46 PM, Eric Greenwell wrote: Worst case: fly where four maps come together - super hassle trying keep track of where I am and what my options are. Check out Dalhart, TX. Taped-together sectionals definitely recommended, there. BTDT, using the above system. Worked fine for me. Reiterating, I recommend using whatever works for Joe Pilot. Being a simple minded kind of guy, I happen to appreciate simplicity. Bob - never even mildly lost - W. I did all that, too, and what a bloody nuisance redoing it every year to keep the charts up to date. There were other problems: over the years, I've marked dozens and dozens of uncharted landing places on the maps. Every map change meant tediously putting all these places on the new map; with the GPS, I just update the database - easy and accurate. I can also put comments on each database entry, making it easier to remember what the field, duster strip, whatever is like. Circles around airports? That worked when I didn't go very far, but with my typical 200-350 mile flights - unworkable. Unless it's a super day, I might target a 20 or more landing places as I work my way around the task. Putting circles on every point in my database would make the map almost unusable. And then there is cost: I fly in 5 to 10 states in a typical season, so buying new maps every year can equal the cost of a flight computer in just a few years. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl |
#34
About a month ago while flying a borrowed glider, my Streak batteries died and I had no GPS to tell me if I could glide back to the home base. I was mortified. Contemplated pulling the dive brakes and landing at the airport I was over, because 30+ miles with no glide computer and a 3k AGL day must be impossible. I am kidding. The reality is that when I have lost GPS, like this flight, I just fly a bit more conservatively because long distances are hard to judge, so I use closer points that are maybe 10-15:1 away to gauge progress.
As you have already discovered, you don't need a GPS or a Chart or a wiz-wheel. You need a sensible head and to pay attention to your surroundings and what the landmarks are doing as you fly towards them. I can't eyeball a 40:1 glide and know I'm going to make it to that obscured place on the horizon, but I can sure tell that the field 10:1 away is sliding under the nose. I came sailplanes from hang gliders, where you rarely even consider using a chart or relying on a glide computer for glide calculation so concern with the glide computer started out very low for me. I actually fly with two in my glider. An L-Nav and a Dell Streak. They are set up differently and rarely agree perfectly on glide. That's useful since the Streak is my pessimist and the L-Nav is my optimist Definitely get yourself a GPS. If nothing else, being able to review your logs in See You is an amazing tool for learning from your own decisions. You'll also gain an appreciation for the performance or lack thereof of your glider as you can see in real-time how you are doing towards a fixed point.. I do find that the GPS enables me to think farther ahead. If I'm 2000 above a conservative glide to an airport, I'm not spending as much time looking at closer alternatives. This is probably more of a high-performance glider issue than a 1-26 issue, but freeing processor cycles for more important activities is a good thing. If you think you can reach Airport X, and you have 5 landable fields in between you and Airport X, you'll be more comfortably focusing on the clouds or looking for birds or other indicators of lift. You get to focus on the soaring more as you've got an easily monitored data point to gauge your progress. Sounds like you are doing it right though. Head out of the cockpit, field to field. Fun stuff. Don't be afraid to augment that judgement with tools that we have available. On Wednesday, September 11, 2013 7:22:16 AM UTC-7, flgliderpilot wrote: I am fairly green had my PGL for about 3 years now. Been venturing into cross country, have done my first flight out to another airport, and last weekend, an out to that airport and return, about 30 miles round trip (in a 1-26, no ridges, it's all flat Florida). No it's not very far, but at least I am not just circling the airport for hours, and my enjoyment of soaring has been taken to a new level. However, I was told recently by an older experienced pilot that using a GPS is "not the correct way to do it". Instead I should be thinking "can I get there... now can I get there... can I get there...". I understand this ideology, but I am pretty sure nearly everyone is using GPS these days. So, does this mean I should not use modern navigation technology? I know how to plot a cross country flight on paper of course, and required altitudes to the next safe landing area. Does this mean I should I actually be drawing circles on charts, carrying a slide ruler to calculate arrival height at various distances, and mechanically doing everything my GPS is doing for me? This means I am not looking for traffic, or thermalling but instead flipping through charts and playing with a slide ruler or E6B, and my eyes are not outside the canopy. Anyway, please enlighten a new pilot, I am listening intently. if I should not be using a GPS at this point I'll go without. Thanks Tom |
#35
On Wednesday, September 11, 2013 10:22:16 AM UTC-4, flgliderpilot wrote:
I am fairly green had my PGL for about 3 years now. Been venturing into cross country, have done my first flight out to another airport, and last weekend, an out to that airport and return, about 30 miles round trip (in a 1-26, no ridges, it's all flat Florida). No it's not very far, but at least I am not just circling the airport for hours, and my enjoyment of soaring has been taken to a new level. However, I was told recently by an older experienced pilot that using a GPS is "not the correct way to do it". Instead I should be thinking "can I get there... now can I get there... can I get there...". I understand this ideology, but I am pretty sure nearly everyone is using GPS these days. So, does this mean I should not use modern navigation technology? I know how to plot a cross country flight on paper of course, and required altitudes to the next safe landing area. Does this mean I should I actually be drawing circles on charts, carrying a slide ruler to calculate arrival height at various distances, and mechanically doing everything my GPS is doing for me? This means I am not looking for traffic, or thermalling but instead flipping through charts and playing with a slide ruler or E6B, and my eyes are not outside the canopy. Anyway, please enlighten a new pilot, I am listening intently. if I should not be using a GPS at this point I'll go without. Thanks Tom honest and humble opinion: if you want to fly with GPS that's fine.In fact as your confidence and skills improve, and as your flights lengthen in duration and distance, i'd recommend it. however: there is something to be said for learning the basic "manual" navigation skills as building blocks. in any case you should have a map no matter what, and in the event that you're flying with GPS and everything goes "lights out", you should have the confidence to continue on or head home with just a map. but there is no one right answer. some people like to fly with maps, some like GPS. |
#36
Years ago I learned that, for a 40ish to 1 ship, you could hold out two
fingers at arm's length such that the top of the fingers rests on the under side of the horizon. Anything visible below the second finger is reachable at your present altitude. Give it a try! I suppose 3 fingers would work just fine for a 1-26. "Morgan" wrote in message ... About a month ago while flying a borrowed glider, my Streak batteries died and I had no GPS to tell me if I could glide back to the home base. I was mortified. Contemplated pulling the dive brakes and landing at the airport I was over, because 30+ miles with no glide computer and a 3k AGL day must be impossible. I am kidding. The reality is that when I have lost GPS, like this flight, I just fly a bit more conservatively because long distances are hard to judge, so I use closer points that are maybe 10-15:1 away to gauge progress. As you have already discovered, you don't need a GPS or a Chart or a wiz-wheel. You need a sensible head and to pay attention to your surroundings and what the landmarks are doing as you fly towards them. I can't eyeball a 40:1 glide and know I'm going to make it to that obscured place on the horizon, but I can sure tell that the field 10:1 away is sliding under the nose. I came sailplanes from hang gliders, where you rarely even consider using a chart or relying on a glide computer for glide calculation so concern with the glide computer started out very low for me. I actually fly with two in my glider. An L-Nav and a Dell Streak. They are set up differently and rarely agree perfectly on glide. That's useful since the Streak is my pessimist and the L-Nav is my optimist Definitely get yourself a GPS. If nothing else, being able to review your logs in See You is an amazing tool for learning from your own decisions. You'll also gain an appreciation for the performance or lack thereof of your glider as you can see in real-time how you are doing towards a fixed point. I do find that the GPS enables me to think farther ahead. If I'm 2000 above a conservative glide to an airport, I'm not spending as much time looking at closer alternatives. This is probably more of a high-performance glider issue than a 1-26 issue, but freeing processor cycles for more important activities is a good thing. If you think you can reach Airport X, and you have 5 landable fields in between you and Airport X, you'll be more comfortably focusing on the clouds or looking for birds or other indicators of lift. You get to focus on the soaring more as you've got an easily monitored data point to gauge your progress. Sounds like you are doing it right though. Head out of the cockpit, field to field. Fun stuff. Don't be afraid to augment that judgement with tools that we have available. On Wednesday, September 11, 2013 7:22:16 AM UTC-7, flgliderpilot wrote: I am fairly green had my PGL for about 3 years now. Been venturing into cross country, have done my first flight out to another airport, and last weekend, an out to that airport and return, about 30 miles round trip (in a 1-26, no ridges, it's all flat Florida). No it's not very far, but at least I am not just circling the airport for hours, and my enjoyment of soaring has been taken to a new level. However, I was told recently by an older experienced pilot that using a GPS is "not the correct way to do it". Instead I should be thinking "can I get there... now can I get there... can I get there...". I understand this ideology, but I am pretty sure nearly everyone is using GPS these days. So, does this mean I should not use modern navigation technology? I know how to plot a cross country flight on paper of course, and required altitudes to the next safe landing area. Does this mean I should I actually be drawing circles on charts, carrying a slide ruler to calculate arrival height at various distances, and mechanically doing everything my GPS is doing for me? This means I am not looking for traffic, or thermalling but instead flipping through charts and playing with a slide ruler or E6B, and my eyes are not outside the canopy. Anyway, please enlighten a new pilot, I am listening intently. if I should not be using a GPS at this point I'll go without. Thanks Tom |
#37
On Friday, September 13, 2013 1:03:59 PM UTC-5, Dan Marotta wrote:
Years ago I learned that, for a 40ish to 1 ship, you could hold out two fingers at arm's length such that the top of the fingers rests on the under side of the horizon. Anything visible below the second finger is reachable at your present altitude. Give it a try! I suppose 3 fingers would work just fine for a 1-26. "Morgan" wrote in message ... About a month ago while flying a borrowed glider, my Streak batteries died and I had no GPS to tell me if I could glide back to the home base. I was mortified. Contemplated pulling the dive brakes and landing at the airport I was over, because 30+ miles with no glide computer and a 3k AGL day must be impossible. I am kidding. The reality is that when I have lost GPS, like this flight, I just fly a bit more conservatively because long distances are hard to judge, so I use closer points that are maybe 10-15:1 away to gauge progress. As you have already discovered, you don't need a GPS or a Chart or a wiz-wheel. You need a sensible head and to pay attention to your surroundings and what the landmarks are doing as you fly towards them. I can't eyeball a 40:1 glide and know I'm going to make it to that obscured place on the horizon, but I can sure tell that the field 10:1 away is sliding under the nose. I came sailplanes from hang gliders, where you rarely even consider using a chart or relying on a glide computer for glide calculation so concern with the glide computer started out very low for me. I actually fly with two in my glider. An L-Nav and a Dell Streak. They are set up differently and rarely agree perfectly on glide. That's useful since the Streak is my pessimist and the L-Nav is my optimist Definitely get yourself a GPS. If nothing else, being able to review your logs in See You is an amazing tool for learning from your own decisions. You'll also gain an appreciation for the performance or lack thereof of your glider as you can see in real-time how you are doing towards a fixed point. |
#38
On Friday, September 13, 2013 2:03:59 PM UTC-4, Dan Marotta wrote:
Years ago I learned that, for a 40ish to 1 ship, you could hold out two fingers at arm's length such that the top of the fingers rests on the under side of the horizon. Anything visible below the second finger is reachable at your present altitude. Give it a try! I suppose 3 fingers would work just fine for a 1-26. Great tip, but it's probably 4 fingers for a 1-26, and another finger for a slight head wind. I'll try it! |
#39
Quote:
I stand corrected. Walt |
#40
I have had to use my map a few times already when the GPS provided erroneous data, so I only trust it when it sounds like it's being honest with me. So yes, I use a map also when I need to. |
| Thread Tools | |
| Display Modes | |
| First solo cross-country flight completed - question | Bertie the Bunyip[_25_] | Piloting | 19 | March 13th 08 08:17 PM |
| Cross country in the 1-34 | mat Redsell | Soaring | 3 | October 22nd 04 05:56 PM |
| a different cross-country time question | Arden Prinz | Piloting | 3 | December 29th 03 02:17 AM |
| A 4,200 NM cross-country | Phil Verghese | Piloting | 0 | September 1st 03 11:03 PM |
| Got my ticket.... now what (the cross-country question) | bdl | Piloting | 6 | July 13th 03 03:06 AM |
