powerflarm not receiving
Old September 23rd 13, 06:24 PM posted to rec.aviation.soaring
Andy[_1_]
Default powerflarm not receiving
On Monday, September 23, 2013 5:42:13 AM UTC-7, wrote:
Hi, everybody with Portables with bad to non-existant RX performance, please: - Make sure your antenna(s) is/are tightly connected and in once piece. - If the above is positive, please request an RMA number from Rex @ Williams. --Gerhard
Gerhard,
Is the receive performance issue associated with the mandatory addition of the SAW filter?
If not, what is the cause so owners can try to avoid it?
thanks,
Andy
Old September 25th 13, 01:36 PM posted to rec.aviation.soaring
Robert Fidler[_2_]
On Tuesday, August 27, 2013 10:56:37 AM UTC-4,
I was allowed to use a portable at a recent funfly. System is worthless in my opinion, no returns on other flarms farther than a few hundred feet. I told the owner to send it back for repair or the trash bin.
Bob Fidler
F1
Old September 25th 13, 03:05 PM posted to rec.aviation.soaring
Bob Fidler
F1
Bob, your comments seem harsh. Did you use the Flarm Range Tool to evaluate the range of this portable? Did you mount it as recommended? Did others see your portable? So many variables and you wipe it all off the table with the 'worthless' label. If you were talking about a person I would call this character assassination.
Herb, J7
Old September 25th 13, 03:24 PM posted to rec.aviation.soaring
K
Bob Fidler
Sounds like operator error to me.
Old September 25th 13, 07:45 PM posted to rec.aviation.soaring
Andy[_1_]
Why would you assume that when the manufacturer has posted in this thread that there is a known issue with reception and recommended that units with this problem should be returned for repair.
I'm still waiting to hear what caused the degradation in reception and if there will be a full recall.
Andy
Old September 26th 13, 06:08 PM posted to rec.aviation.soaring
Andy[_1_]
On Friday, September 6, 2013 5:05:36 AM UTC-7, Tony wrote:
I was afraid of that... good news is I think I will be at Williams Soaring. tomorrow.
Tony,
Was your portable fixed and, if so, what was the problem?
thanks
Andy
Old September 27th 13, 12:16 AM posted to rec.aviation.soaring
Tony[_5_]
I still need to get an RMA or whatever and send it in.
AR 4201 low volume on receiving side Alexander Swagemakers[_2_] Soaring 10 June 23rd 12 02:40 AM
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 26th 12 12:58 AM
302 not receiving GPS satellites Stephen[_3_] Soaring 10 July 16th 11 11:11 PM
not receiving digest ... Ron Gleason Soaring 1 May 19th 10 08:11 PM
Off topic question - Are you receiving viruses? Mike Williams Rotorcraft 8 September 27th 03 05:14 AM
