Keep your hand off the release handle during aero tows!
Old October 14th 13, 02:43 PM posted to rec.aviation.soaring
Bill D
Default Keep your hand off the release handle during aero tows!
On Monday, October 14, 2013 3:43:07 AM UTC-6, Paul Ruskin wrote:
On Monday, October 14, 2013 3:03:44 AM UTC+1, Bill D wrote:
I don't get accident statistics from RAS comments.
Which would be an admirable position Bill, except that I took the trouble to go and find the accident reports from the BFU and BGA and posted a list of winch accidents in my comment, including sources and accident report numbers.
The data says that in the period 2006-12 a German pilot had much the same chance as a UK civilian pilot of being killed or injured in a winch accident.
Perhaps you'd let us know whether you now accept that conclusion, rather than claiming that UK winch launches are 10 times more dangerous?
Paul
Yes, I read your ramble. The operable statistic is number of accidents per number of launches - very simple and not included in your post.
For 2011 (The numbers just look worse for the UK the further back one goes.)
The Germans suffered one accident every 180,000 launches
The UK suffered one every 16,000 launches.
That's better than 10:1 and the number can't be twisted to show parity.
  #102
Old October 14th 13, 02:56 PM posted to rec.aviation.soaring
Justin Craig[_3_]
Bill,
You have still not confirmed if you are in fact the highly regarded Bill
Daniels?
I hope you are not, because each time you post, you loose any credibility
by being rude and obnoxious. Why is it necessary to make statements such as
"Yes, I read your ramble"?
If you are the "real Bill Daniels" please let us know.
If you are not, I am sure the "real Bill Daniels" will be royally ****ed
off that you have been letting the wider population of the gliding
community assume that you are whilst blighting his good name!
Justin Craig
trouble
list
numbers.
same
accident.
rather
Paul
per
goes.)
  #104
Old October 14th 13, 04:17 PM posted to rec.aviation.soaring
Del Copeland
Paul did allow for the greater number of glider pilots and winch
launches in Germany and his figures are for fatal and serious
injury accidents only. As I have pointed out to you before, the
BGA accident statistics include all minor accidents and incidents
that are even vaguely related to winch launching and which do
not cause death or serious injury. There are probably 10 such
incidents for every serious accident which probably explains the
difference. There are lies, damn lies, and your interpretation of
accident!
Derek Copeland
the trouble
posted a list
accident report
numbers.
much the same
winch
accident.
conclusion, rather
dangerous?
Paul
accidents per
post.
back one
goes.)
show parity.
  #105
Old October 14th 13, 04:18 PM posted to rec.aviation.soaring
Paul Ruskin[_2_]
OK. I note that you've avoided my question, which was whether we you agree with "The data says that in the period 2006-12 a German pilot had much the same chance as a UK civilian pilot of being killed or injured in a winch accident. "
So, I'll ask again - do you agree with that conclusion? I've provided all the data you need, and its source, and the calculation is simple.
Whether you think that's a good "operable statistic" or not is different. I happen to think it is - because then we don't confuse different reporting of incidents.
Paul
  #106
Old October 14th 13, 04:54 PM posted to rec.aviation.soaring
Chris Nicholas[_2_]
There is some under-reporting of minor accidents in the UK, and I
expect in almost every country. There is no way of knowing the
extent, but if for example a German poster here were to admit to
knowledge of a minor accident not featured in their national figures,
it would confirm the issue in principle.
I believe that the figures for fatal accidents are unlikely to be
underreported, however. “Serious” accidents might have different
interpretations in different countries; I know of no way to be certain
of that.
So the only reliable statistics seem to me to be fatalities per
100,000 winch launches, which for the UK ought to include the air
cadet figures (no fatalities). I do not know if German data includes
an equivalent to air cadet data which would not be in DAeC
statistics. Perhaps somebody could advise on that.
Furthermore, the only fatalities relevant to these discussions are
those due to the winch launch itself, and not to (for example)
spinning off a final turn at the end of a flight that started with a
winch launch. Paul Ruskin’s analysis sought to do that, it seems to
me, by summarising the actual events.
Chris N
  #107
Old October 14th 13, 04:56 PM posted to rec.aviation.soaring
John Galloway[_1_]
accidents
post.
had much the
a winch
accident. "
provided all
simple.
different.
different reporting
of incidents.
Paul
There can be no doubt when an injury or a fatality occurs and
such an event should always be reported and recorded in
gliding developed countries. I think we can all agree that no
country will over-report death and injury data. Therefore the
only way that comparison of death and injury rates between two
countries could *not* be based on valid operable statistics is if
you were to believe that one country is under-reporting them -
which would be an interesting propositon to put to the Germans.
John Galloway
  #108
Old October 14th 13, 05:22 PM posted to rec.aviation.soaring
Chris Nicholas[_2_]
John, Paul’s figures are for fatals and “serious” injuries, not all
injuries, AIUI. I would not be surprised if the definition of “serious”
differs.
Chris N
  #109
Old October 14th 13, 06:29 PM posted to rec.aviation.soaring
Del Copeland
Definitions are important for statistical analysis. If a glider crashes
after flying a circuit from an 800ft cable break, is it a winching
accident or an approach and landing accident? If it spins after
successfully completing a winch launch, is that a winching accident
or a stall/spin accident? I would think that a serious injury would be
broken bones, head injury, deep lacerations and anything that
requires hospital treatment. So a bruised backside or a grazed
finger shouldn't really count.
Derek Copeland
“serious��
differs.
Chris N
  #110
Old October 15th 13, 10:07 PM posted to rec.aviation.soaring
Del Copeland
Bill D has gone remarkably quiet!
accidents
post.
had much the
winch
accident. "
provided all
simple.
different.
reporting
of incidents.
Paul
Number of aero tows in 2011 Bill D Soaring 35 November 21st 12 03:39 AM
Looking for a Yellow Tow Release Handle Randy Teel Soaring 3 August 7th 12 10:36 PM
Schweizer Tow Release Handle/Bracket Jim Newton Soaring 2 May 14th 10 05:17 PM
Schweizer Tow Release Handle/Bracket Jim Newton Soaring 0 April 22nd 05 07:21 PM
CG hook on aero tows?? Ted Wagner Soaring 130 January 12th 04 11:04 PM
