Fuses on the panel, or not
Old October 16th 13, 02:11 AM posted to rec.aviation.soaring
Dan Marotta
Default Fuses on the panel, or not
More air flow can fan or extinguish a fire.
In his shoes, I'd have stepped over the side. I'd really hate to have a
major part of the glider burn away while on final approach!
"son_of_flubber" wrote in message
On Tuesday, October 15, 2013 11:39:59 AM UTC-4, 7C wrote:
If you can't physically isolate then you are stuffed when you are
flying... Bet you can't land quickly enough
Someone told me a story about bad smoke developing in the cockpit of a
glider. The pilot ejected the canopy. At that point the increased airflow
stoked the smoldering fire and something burst into flames. Story goes, he
landed and the fire went back to smoldering.
Does this sound plausible or is it yet another BS story?
Old October 16th 13, 08:42 PM posted to rec.aviation.soaring
JohnDeRosa
A couple of comments about circuit protection some of which has been covered before in other threads;
- Pete Purdie's comment above about undersized wiring is on target. Bigger is better (within reason)! If you saw smoke you probably do not have Tefzel wiring. Get some!
- Fuses are great as they are cheap, fast acting and have ZERO voltage drop across its terminals. Cons are that they are more difficult to replace in flight and somewhat fragile (glass type).
- Breakers are great as they are easy to reset in flight. Cons are that they are expensive, somewhat slow acting and will cause a voltage drop across its terminals. This voltage drop effect is worse at small breaker values, you can loose 1/2 volt or more. That is fine for ships with generators but lousy for gliders.
- Put a FUSE on each battery at the terminals. This is the absolute minimum circuit protection you MUST have.
So if you really want separate protection for each of your devices, then use small value fuses rated just above the maximum current for each piece of hardware. Otherwise go with a large value single breaker to protect the entire system.
As to the use of different types of fuses (glass versus blade type) this relates more to what your IA will sign off. Blade type are certainly more robust and I saw them in lots of experimental airplanes at Oshkosh. But the FAA is a strange and demanding mistress. ;-)
My $0.02. Good luck.
- John
Old October 16th 13, 10:26 PM posted to rec.aviation.soaring
Dave Nadler
Please don't install glass fuses, because they are prone to:
- blowing under vibration (like, rolling during launch)
- even more prone to blowing in gas-powered motorgliders
- corroding and introducing voltage drop at the (non-gas-tight) ends
The voltage drop breakers introduce can be significant and can cause problems.
Use blade types inline (not on the panel!) and avoid these problems...
Hope that helps,
Best Regards, Dave "YO electric"
Old October 16th 13, 10:49 PM posted to rec.aviation.soaring
I have just finished designing my new panel and will now place all fuses behind the panel. The reasons are 1) I want a very clean panel and 2) in the past 600h of flight i never had to reset a fuse, and i wouldn't do so if it blew. The only thing you must make sure is to have a possibility to shut off power in case of smoke/fire (master switch).
Old October 17th 13, 03:17 PM posted to rec.aviation.soaring
Dan Marotta
....And be sure to have an appropriate sized fuse as close to the battery
terminals as possible.
Old October 18th 13, 04:23 PM posted to rec.aviation.soaring
Regarding mini-blade type fuses, my searching has yet to locate a reasonable sized mini-fuse block as well as not being able to locate mini-blade fuses in low amp values. IMSMC, 2 amp was the smallest value I could find cataloged from DigiKey or Mouser.
I would appreciate a steer to any small mini-blade fuse blocks or low amp mini-fuses.
Old October 18th 13, 04:42 PM posted to rec.aviation.soaring
James Lee
Take a look at these motorcycle fuse blocks- http://www.easternbeaver.com/Main/main.html
Old October 19th 13, 01:21 AM posted to rec.aviation.soaring
son_of_flubber
https://www.google.com/search?q=1amp...ient=firefox-a
Old October 19th 13, 03:23 PM posted to rec.aviation.soaring
John Galloway[_1_]
My preference is for individual equipment CBs to be on the panel
and visible (rather than hidden fuses or CBs) to help with in flight
diagnosis in the event of an instrument or equipment power loss.
In some cases I might try a reset - I did so succesfully once when
the turbo pylon CB popped with the engine half retracted. I
would probably reset a bugwiper CB too. Delicate intruments -
not so likely. Nor if the cockpit were to be getting smokey.
John Galloway
all fuses
be=
and 2) in the
so if
it=
to shut
o=
Old October 19th 13, 08:09 PM posted to rec.aviation.soaring
son_of_flubber
Some dumb questions, but these things sometimes don't work like I imagine they would.
Say I have a 3 amp fuse at the battery and a 1 amp blade fuse in series and the one amp feeds power to a single instrument. (with other 1 amp fuses going to other devices)
Is there a scenario where a 1 amp blows and the 3 amp does not? I figure that most shorts will draw more than 3 amps and blow both fuses. Do devices develop "partial shorts"?
Is there a scenario where both fuses blow?
Would it make sense to make the 3 amp "slow blow" and the 1 amp "normal blow"?
What am I missing?
Fuses in general Tuno Soaring 19 December 11th 08 06:45 PM
fuses vs. circuit breakers raulb Soaring 0 November 8th 07 02:48 PM
Bussman Fuses kevmor Piloting 10 May 25th 07 03:25 AM
Bussman Fuses kevmor Piloting 2 May 22nd 07 09:28 PM
Fuses versus Breakers ContestID67 Soaring 14 March 14th 05 01:47 PM
