Gelcoat care
Old October 31st 13, 10:58 PM posted to rec.aviation.soaring
Ramy
Default Gelcoat care
On Thursday, October 31, 2013 7:14:33 AM UTC-7, mike wrote:
On Wednesday, October 30, 2013 7:32:14 AM UTC-6, dogger wrote:
What is the best way to prolong gelcoat life?
I have a friend that says that waxing, polishing is only good for the
pilot, does almost nothing for the gelcoat.
I really don't know much about this issue.
Would it make sense to cut a bit off like .002 every once in a while to
stop/prevent any crazing? Then wax it?
Does Gelcoat off gas over time and then start going bad?
Seeing how very little time most ships are out in the sun, a lot of them
look rough. Sailboats sit outside 24/7 and can look good for many years..
Whats up? Should I be parking my LS3a in a Marina?
Do nothing or try and work on the gelcoat to attempt to get the longest
life out of it; or something in between?
If Gelcoat does off gas, and kind of dries out and cracks,would it make
sense during the winter lay up to cover the gelcoat with a coat of wax, to
seal it, and then buff it off come spring?
I painted a sailplane several years ago and did a fair amount or research before actually applying the paint. My paint guys told me that sanding the finish actually allows for a more rapid (UV) degradation of the surface as the resin the encapsulates the pigment has been compromised. Waxing does slow the process down. I think that this would also apply to Gelcoat. The more completely a wax would seal the sanded surfaces would be more beneficial, and wax using nano technology such as WX Seal and Block would be closer to the ideal. Other waxes also are now advertising Nano technology. Whether or not they are as effective as the WX products may be open to discussion.
No one mentioned trailer solar vent so far? How effective are they? They only cost something like $200 so I must wonder if they are effective why they are not provided with every trailer. I added one to mine but it keeps breaking down every 1-2 years and I wonder if I should even bother replacing it again.
Ramy
Old October 31st 13, 11:14 PM posted to rec.aviation.soaring
son_of_flubber
Whats up?
Sailboats don't fly in mountain wave.
I heard that the rapid temperature changes of wave flights are tough on gel coat.
I heard that Germany is the place to buy a used glider with a good gel coat. Maybe it has something to do with Germany's high latitude and cloudy weather.
Old November 1st 13, 08:50 AM posted to rec.aviation.soaring
Surge
On Wednesday, 30 October 2013 23:14:12 UTC+2, HGXC wrote:
Not many boat owners stare down and whip every inch of their hulls every time they use them.
I don't know if any glider pilots who whip every inch of their gliders before use either.
Old November 1st 13, 03:10 PM posted to rec.aviation.soaring
Dan Marotta
Instead of a solar vent, I installed two vents, one low in the front of the
trailer and one high on the doghouse. Each had louvers to keep out rain and
screen to keep out bugs. When the temperature warms up, circulation begins.
Worked for me for many years and I probably spent under $10 for everything.
Aluminum Cobra, LS-6a, no gel coat crazing.
"Ramy" wrote in message
to
open to discussion.
it again.
Ramy
Old November 1st 13, 11:31 PM posted to rec.aviation.soaring
K
Who ever told you this is on drugs. Although, I notice the skin on my hands is nice and soft after a wax job. I have a family member who will pay 8K to repaint an 9 YO oxidized Infinity because he doesn't believe in car care products but he cannot explain how my 20 YO Mustang (Which gets waxed regularly) still has original paint which looks new. My 77 vintage glider was the same way. Original finish and it looked great. I waxed the entire ship in the off season and then I would do the upper surfaces twice during the season. I have attended product webonars and spoke with product support people at Simtec Dupont and others and they all say the same thing. If you want your stuff to look good and last, it has to be taken care of.
Old November 2nd 13, 01:01 AM posted to rec.aviation.soaring
Ramy
I can't think of any reliable convincing way to prove that waxing helps, other than always waxing only one wing and comparing after 15-20 years. Otherwise you don't compare apples to apples.
Ramy
Old November 2nd 13, 02:45 PM posted to rec.aviation.soaring
On Wednesday, October 30, 2013 12:49:15 PM UTC-4, Soartech wrote:
On Wednesday, October 30, 2013 10:20:11 AM UTC-4, John Galloway wrote:
Here is a good technical article. The two component process
mentioned in the article refers the Wx Seal and Wx Block.
http://www.wingsandwheels.com/Weather%20Block%20Tech.h
I have read testimony from other pilots here that this stuff works but this
still does not explain why (massive) fiberglass boats, which probably never get
waxed, don't crack. Is it because they don't flex?
I have a friend with an old ASW-19 in which the wings are really crazed but
the fuselage is not.
Good article. Gelcoat is a petroleum based product and will dry out. Its easier to maintain then to bring back.
Canopy Care Guy[_7_] Soaring 15 March 25th 10 04:50 AM
Any ex-zoomies out there care to comment? Stewart Kissel Soaring 2 April 14th 05 06:02 PM
VA Health Care Steve Mellenthin Military Aviation 0 August 19th 04 05:45 PM
New Paint Care Suggestions Nathan Young Owning 11 July 11th 04 11:24 PM
I don't care what harrison Ford says Tony Ryan Piloting 17 March 29th 04 10:21 AM
