Charging multiple glider batteries
Old January 7th 14, 07:44 PM posted to rec.aviation.soaring
Don[_4_]
Default Charging multiple glider batteries
Lots of good input from you all. We will definitely make some changes
now. Will check the condition of each battery under load, cull out the
worst and then probably use a separate charger for each battery. Thanks
to all, but we will be watching to see if any other comments come in
before getting started. Don.
Old January 7th 14, 08:41 PM posted to rec.aviation.soaring
Vaughn
On 1/7/2014 12:38 PM, Soartech wrote:
For even less you can get a similar small battery charger at Harbor Freight.
They are $10 but are often on sale with a coupon for less.
http://www.harborfreight.com/automat...ger-42292.html
Because of HF's lack of quality control, I would hesitate to recommend
these. That said, I have used two of them with good results. One of
them I used for several years!
Vaughn
Old January 7th 14, 08:50 PM posted to rec.aviation.soaring
Brian[_1_]
From the Battery Tender Web Site.... Short version, yes it is OK to charge the same voltage batteries in Parallel....
Can the Battery Tender® Plus battery charger be used to charge more than 1 battery simultaneously if the batteries are connected in parallel?
Yes, but with restrictions. A parallel connection means that positive posts of each battery are electrically connected together and the negative posts of each battery are electrically connected together. The voltage of a parallel connected battery pack is exactly the same as the voltage of each battery in that pack.
If the nominal battery voltages (i.e. 12V, 8V, 6V) are the same on each battery, and if the batteries are the same lead acid type (flooded, AGM, or Gel Cell), then yes, the Battery Tender® Plus battery charger can be used to charge more than 1 battery simultaneously when those batteries are connected in parallel. Just remember that 2 batteries in parallel behave like one large battery. The charge storage capacity of each battery simply adds together. Two 12 volt batteries, each with 25 amp hour capacities, will look like one 12 volt battery with a 50 amp hour capacity. You may be able to charge more than 1 battery simultaneously, but it will take longer to do it.
Old January 7th 14, 09:32 PM posted to rec.aviation.soaring
Mike J.
On Monday, January 6, 2014 1:53:37 PM UTC-6, Don wrote:
Our club (US) keeps 8 batteries charged in two banks of 4 batteries. We use two Battery Tender Junior chargers, one for each bank. The charging rate is not very fast, but they have at least 20 hours between use and often a week. Mostly this has worked pretty well, but we are more often finding batteries that are not fully charged, even though the battery tender is green indicating full charge. Once fully charged, the charger just floats them. The batteries are the popular glider batteries, 12 volt 7 amp hour sealed lead acid. How do other clubs, commercial ops keep multiple batteries charged up? I realize charging problems can occur when one battery is damaged, won't take a full charge or is simply dead. Or if the charging rate varies markedly from batt to batt. It may be possible to overcharge the other ones. Ideally each battery would be charged individually, but that is expensive and takes more space. What solutions are out there?
Old January 7th 14, 10:01 PM posted to rec.aviation.soaring
Neil Allison
Hi Don,
I built a 1Ux19" rack mount, 12-way charger for the Canterbury Gliding Club. Batteries remain connected to the charger whenever they are not in a glider. The charger uses Silvertel Ag102 multi-stage battery charger modules, one per battery.
Each channel has a green LED that is illuminated when the battery has returned to float charging. The idea is to help club members identify which batteries have just been connected and which have been recharged.
These photos are from my workshop during testing:
http://www.avon-tech-solutions.co.nz...arger_Rack.JPG
http://www.avon-tech-solutions.co.nz...12WCharger.JPG
On our flying camps at Omarama, we take a couple of 4-outlet versions that are powered by a laptop AC adapter:
http://www.avon-tech-solutions.co.nz/gliding.html
When I test batteries I do a semi-automatic, timed discharge to 10.5V using a 50W 12V halogen light bulb. If this duration is less than about 75% of the nominal Ah value I suggest the battery is replaced.
Neil Allison
Christchurch, NZ
Old January 7th 14, 10:06 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
On Mon, 06 Jan 2014 23:05:00 +0000, Tim Newport-Peace wrote:
There are meters which will measure battery capacity, but cost more than
6 batteries, so probably not an option. I have used one for many years,
but I bought it as a work tool where it pays for itself.
Tim,
Battery checkers are cheaper that you may think if you look in the right
places. I think that means model shops.
I have a Pro-Peak Prodigy II that charges and cycles NiCd, NiMH, Li-poly/
ion and SLA batteries. It runs off 12v and but can charge and cycle cell
stacks of up to 18v. You get to set the chemistry, charge and discharge
rates and, after the cycle is complete, it gives a read-out of both
charge and discharge capacity. The current Pro-Peak model has similar
capabilities and sells for just under £55.
Pure capacity checkers run £15-£20 though you'd have to hunt round
because most only deal with Li-poly/ion or LiFe batteries. However,
you'd want one that can deal with NiCd, NiMH or SLA because the per-cell
cut-off point for Li-poly/ion is normally 3.1v/cell.
I prefer to use Yuasa NP7-12L SLA batteries. The current cost is £16.80
including VAT and shipping, so the price of model flying cyclers and
testers doesn't look all that far out of line with the price of these
batteries.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old January 7th 14, 11:43 PM posted to rec.aviation.soaring
Li-poly/
batteries.
The one I use is Actmeter IBT tester.
http://www.actmeters.com/battery-tes...battery-tester
Testers that need to do full charge/discharge cycles are no use to me
when I have a customer with about 200 NP7-12 batteries installed.
Fair comment, but I was looking at something that an individual or club
might use to check a few batteries once a year. Any of the Pro-peak
chargers or their equivalents are perfectly adequate for that duty cycle.
org |
Old January 8th 14, 04:02 AM posted to rec.aviation.soaring
GC[_2_]
Very neatly executed!
I assume the vertical boards are the Ag102 and the horizontal ones are
your I/O circuits. Is that right? What did you need to add?
The Shortform doc says the charger IS temperature-compensated but also
says that "With the addition of a low-cost thermistor, charge voltages
CAN be temperature compensated". Which is right? Did you have to add a
thermistor yourself?
Is there an NZ/Oz distributor for Silvertel?
GC
On 8/01/2014 09:01, Neil Allison wrote:
Hi Don,
Old January 8th 14, 05:15 AM posted to rec.aviation.soaring
Neil Allison
Thank you.
Correct. XLR rack mount panel is from Jaycar. I chose to use a microcontroller to detect and signal float conditions: one 8pin ATiny13 and its associated 5V supply and voltage sensing parts does a pair of charger channels. I resisted the temptation to indicate bulk and absorption charging state by flashing the LED at different rates (except as an experiment during development).
Yes, you do need to add the NTC: one per channel. I chose not to temp comp because of the perceived challenge of measuring the (correct) battery temperature in a club situation. But I left provision on my pcb to provide temp comp.
Fairmont Marketing. www.semiconductorstore.com also ship down here.
Cheers
Neil
Glider Batteries and Chargers Grider Pirate Soaring 29 September 1st 10 05:52 AM
FA: multiple used glider/soaring related items Mark Zivley Soaring 0 February 12th 06 05:20 PM
Still interested in Lithium batteries for your glider? Eric Greenwell Soaring 5 March 5th 05 02:32 PM
Charging? PaulaJay1 Owning 25 February 2nd 05 06:03 AM
Cessna 210 charging problem John Clonts Owning 9 July 14th 04 03:08 PM
