On Saturday, January 11, 2014 2:35:45 AM UTC-5, Chris Rollings wrote:
If you are gliding from one thermal to another, optimum speed is the same whether you are going into wind, downwind or no wind, it just depends on the rate of climb achieved in the next thermal. If you are gliding to a point on the ground, final glide or round a turn-point, then optimum speed will be higher into wind than downwind. Then, on Saturday, January 11, 2014 4:18:33 PM UTC-6, Kevin Christner wrote: This is true from an optimal speed perspective. Kawa and Brigliodori's point (I think) has to do with increasing search range. Flying faster upwind and slower downwind increases your search range. Also, if you've ever looked at a graph for flying slightly faster or slower than optimum MC bumping up or down one know has very little effect on total speed. Finding a better thermal (or a thermal at all) would make you faster or keep you from going Aux Vauche.... Thoughts? 2C Take your polar, see what your speed is for MC3. Let's say it is 75 knots. Calculate your L/D from the polar. Now, fly into a headwind, say 5 knots, and determine your L/D over the ground. Now, check your L/D flying at 80 knots into that same 5 knot headwind. Did your L/D go up or down? Try adding another 5 knots to the cruise speed and see what happens with your L/D.. Try subtracting 5 knots and calculate your L/D Now, bump the headwind to 10 knots, then 15, and 20. Figure out how strong the headwind has to be for your L/D to actually go UP by flying at 80 or 85 knots indicated versus 75 knots indicated. Think you will find that flying faster into the wind will only increases your search range when the MC is low and the wind speed is high. As for increasing your search range when flying down wind, why slow down since you have the tailwind increasing your search range? But, those are increasing glide distance over the ground, which is not the same as maximizing cross country speed. And, as BB said, MC for final glide is climb rate for your last thermal. Not more if the final glide will be into the wind. Altitude required increases for a headwind, but speed to be flown does not change because of wind. Steve Leonard |
My earlier post was referring to the theoretical considerations. The
essential point is that the thermals drift with the wind, applying simple McReady theory gives maximum achieved average speed through the air, any variation gives a lower average airspeed and therefore also a lower average ground speed. In the real World, for the last 40 years, my teaching and practice, in UK/NW Europe conditions, has been: default setting 1 knot, if you're getting low or it doesn't look good ahead set 0 knots, if it's a really good day and you're high and going well set 2 knots, if it's a fantastic day, the best you've ever flown on and you look like setting a record, set 3 knots. If you are tempted to set 4 knots, land, take 2 asperin and lie down, you're feverish. For strong thermal areas like the American South West, South Africa and Australia, add one knot to all the above, except perhaps the 0 knot case. You go faster flying between 6 knot thermals with 2 knots set than you do flying between 4 knot thermals with 4 knots set. The lower setting you use, the greater your range and the greater your chance of finding the really good thermals. This doesn't apply on final glide, when you do need to allow for head or tail wind and you should use the instantaneous rate of climb when you leave the thermal, not the average. At 04:11 12 January 2014, Steve Leonard wrote: On Saturday, January 11, 2014 2:35:45 AM UTC-5, Chris Rollings wrote:=20 If you are gliding from one thermal to another, optimum speed is the same= =20 whether you are going into wind, downwind or no wind, it just depends on= =20 the rate of climb achieved in the next thermal. If you are gliding to a= =20 point on the ground, final glide or round a turn-point, then optimum spee= d=20 will be higher into wind than downwind.=20 Then, on Saturday, January 11, 2014 4:18:33 PM UTC-6, Kevin Christner wrote= : This is true from an optimal speed perspective. Kawa and Brigliodori's po= int (I think) has to do with increasing search range. Flying faster upwind an= d slower downwind increases your search range. Also, if you've ever looked = at a graph for flying slightly faster or slower than optimum MC bumping up or = down one know has very little effect on total speed. Finding a better thermal = (or a thermal at all) would make you faster or keep you from going Aux Vauche= .... Thoughts? 2C Take your polar, see what your speed is for MC3. Let's say it is 75 knots.= Calculate your L/D from the polar. Now, fly into a headwind, say 5 knots= , and determine your L/D over the ground. Now, check your L/D flying at 80= knots into that same 5 knot headwind. Did your L/D go up or down? Try ad= ding another 5 knots to the cruise speed and see what happens with your L/D= .. Try subtracting 5 knots and calculate your L/D Now, bump the headwind t= o 10 knots, then 15, and 20. Figure out how strong the headwind has to be = for your L/D to actually go UP by flying at 80 or 85 knots indicated versus= 75 knots indicated. Think you will find that flying faster into the wind = will only increases your search range when the MC is low and the wind speed= is high. As for increasing your search range when flying down wind, why slow down si= nce you have the tailwind increasing your search range? But, those are increasing glide distance over the ground, which is not the = same as maximizing cross country speed. And, as BB said, MC for final glide is climb rate for your last thermal. N= ot more if the final glide will be into the wind. Altitude required incre= ases for a headwind, but speed to be flown does not change because of wind. Steve Leonard |
Not sure it's true ... but I recall Bill Bartell(US comp pilot) initially misunderstood MC ... and would set his MC value to altitude/1000 ... i.e. 5000' MC = 5 .... 2000' MC = 2.
He had some pretty good comp results during this period - as I recall. :-) kk |
![]() In the real World, for the last 40 years, my teaching and practice, in UK/NW Europe conditions, has been: default setting 1 knot, if you're getting low or it doesn't look good ahead set 0 knots, if it's a really good day and you're high and going well set 2 knots, if it's a fantastic day, the best you've ever flown on and you look like setting a record, set 3 knots. If you are tempted to set 4 knots, land, take 2 asperin and lie down, you're feverish. For strong thermal areas like the American South West, South Africa and Australia, add one knot to all the above, except perhaps the 0 knot case. You go faster flying between 6 knot thermals with 2 knots set than you do flying between 4 knot thermals with 4 knots set. The lower setting you use, the greater your range and the greater your chance of finding the really good thermals. This reflects current practice, and it's really interesting. "Range" doesn't really describe the reason, I think. In the southwest USA at 10,000' we have tons of range, we don't stop for under 6 knots, yet flying at 100 knots does better than 120 (go look up mc 6 speed!), and 95 won't kill you. I think the reason is more that flying at warp speed, you (or at least I) lose the feel of the air; I can't adjust slightly to benefit from gliding through rising air. And, I might fly right through that great thermal and not feel it. John Cochrane |
On Friday, 10 January 2014 22:01:28 UTC+2, wrote:
There are second order effects -- thermals don't drift exactly with the wind, you may be able to bump more or less effectively depending on wind, etc. But it would take a whole new generation of theory and software to begin to quantify these effects. John Cochrane Yes, theoretically *if* thermals would drift perfectly with wind, there wouldn't be any windshear across thermals, resulting that they would be completely symmetrical (round). Or they would ascend at impossible angles (2 m/s thermal drifting in 20 m/s wind would result 1:10 angle). Flying under clouds with real-time wind information is quite revealing. krasw |
This was exactly my understanding until I read Brigliadori. On pages 359
through 364 they make a pretty good case for flying a bit faster into wind on task due to the slope of thermals and vice versa, all with worked examples. Jim At 07:35 11 January 2014, Chris Rollings wrote: If you are gliding from one thermal to another, optimum speed is the same whether you are going into wind, downwind or no wind, it just depends on the rate of climb achieved in the next thermal. If you are gliding to a point on the ground, final glide or round a turn-point, then optimum speed will be higher into wind than downwind. |
On Monday, January 13, 2014 2:34:40 AM UTC-6, krasw wrote:
Yes, theoretically *if* thermals would drift perfectly with wind... Uh oh. Next problem. If thermals don't drift at the same speed as the wind, how accurate is that wind speed your computer derrives from drift while you are thermalling? Steve |
On Friday, January 10, 2014 2:10:45 PM UTC-5, Kevin Christner wrote:
My understanding is that modern flight computers (which seem to have 10X more features than anyone could possibly use) don't make adjustment to STF calculations for the wind. From my reading of recent "authoritative" sources (Brigliodori, Kawa) it is optimal to increase speed into the wind and decrease speed downwind, relative to non-adjusted McCready. Also of critical importance to me would be a final glide optimizer. Currently when making a final glide I "move the dial" up and down in McCready speeds as I get close to final glide. Often changing the McCready value up into the wind and down with the wind leads to lower required altitude. Am I missing anything? 2C what flight computer are you running? |
On Monday, January 13, 2014 11:17:35 AM UTC-5, Steve Leonard wrote:
On Monday, January 13, 2014 2:34:40 AM UTC-6, krasw wrote: Yes, theoretically *if* thermals would drift perfectly with wind... Uh oh. Next problem. If thermals don't drift at the same speed as the wind, how accurate is that wind speed your computer derrives from drift while you are thermalling? Steve It is well known that thermals do not exactly drift with the wind. Consider the inertia of the heated parcel of air as it rises through increasing wind aloft... Hang-glider pilots have known for decades to fly upwind in thermal wind shadows. Not all flight computers use drift while thermalling to estimate wind! For example, the ILEC SN10 does not... Hope that helps, Best Regards, Dave "YO electric" PS: Steve, how's the first SN10 ever delivered to a customer treating you? |
Steve Leonard wrote, On 1/13/2014 8:17 AM:
On Monday, January 13, 2014 2:34:40 AM UTC-6, krasw wrote: Yes, theoretically *if* thermals would drift perfectly with wind... Uh oh. Next problem. If thermals don't drift at the same speed as the wind, how accurate is that wind speed your computer derrives from drift while you are thermalling? My experience with a 302 and SeeYou Mobile was the differences were small compared to other variations due to time, location, and altitude, and small enough that I usually didn't notice any difference. But, there may be places that do have bigger differences, and I just didn't fly there. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
Personal flight computers | kd6veb | Soaring | 26 | January 30th 13 07:15 PM |
Question about flight computers | Some Other Guy | Piloting | 0 | December 5th 10 12:02 AM |
In Flight computers and softwa | Walt Connelly | Soaring | 15 | November 21st 10 01:01 AM |
Zander 940/941 or ZS-1 Flight Computers??? | Tim[_2_] | Soaring | 8 | August 10th 08 10:01 PM |
Zander flight computers | rhwoody | Soaring | 0 | May 7th 08 04:30 AM |
