#81
![]() snip... How about we move the whole affair up 500 feet? John Cochrane Completely agree with moving it up 500 feet, in the old days, if you arrived 6 ft below the hard deck (the ground), you stayed there.... However having the 500ft floor only in the finish cylinder, with all the speed points at risk, does seem to incentivize low thermaling in an area that has high concentration of (perhaps) head down pilots. The pilot might even feel more comfortable trying to climb there due to the proximity of the airport. Here is a suggestion, put the 500 ft hard deck out to 4 miles. Once you make your 4 mile call you are over a hard deck. You still need to come into the finish cylinder, everything remains the same, but once you fall under the 500 ft hard deck your done, join the landing traffic. If your final glide is marginal, and you think this is likely, you will want to stop and try to climb outside the hard deck, where the increased radius will help spread out the traffic. |
#82
On Friday, January 24, 2014 10:14:39 AM UTC-5, Andy Gough wrote:
First of all I would like to congratulate Sean for being able to pick the most controversial subjects to discuss on RAS. Just about every thread Sean starts or joins turns into a weeks long exchange that explores every possible nuance to the point of ad nauseam. If newcomers to the sport could be encouraged to the same degree we would see a boom in soaring participation. But I digress my main observation is that twenty years ago before GPS to receive a good finish one had to arrive within the airfield boundaries with flying speed and it was necessary to complete a touchdown, roll out and stop without catastrophic incident. If you landed before the fence or executed an arrival rather than a landing, points for a successful finish were not awarded. The difference now is we are required to arrive above and within the horizontal boundaries of the top of an invisible cylinder. The cylinder itself is no different than a line of trees on the airfield boundary, enter it from anywhere other than above and you did not make the finish. Except of course we have graduated penalties, which change the whole safety objective, the main reason for going to a finish cylinder. Imagine if we had the same graduated penalties in the finish line scenario: · hit the fence post but cause only superficial damage 20 points · stall and groundloop just inside the airfield boundary, breaking off the tail boom 500 points · but come to rest past the runway threshold 100 points Well I hope you get the picture. Logically, if you don't complete the mission the way it is intended you don't deserve the points. If safety is not the reason for adopting a finish cylinder then we might as well go back to the old finish line at least it was fun and it was simple to determine a valid finish. Both methods open the possibility to pull ups and thermalling low and close to the airport. Is this the behaviour we are trying to mitigate? Thermalling low down or aggressive pull ups can occur anywhere on task, this behaviour is not governed by proximity to the finish. However funnelling the fleet into a 1 mile radius cylinder at 500 ft may concentrate traffic to the point this behaviour can be detrimental to more than the individual performing these manoeuvres. We use a 5 mile cylinder for the start to provide separation should we not do the same at the finish.. It could be argued that there is greater concentration at the start than the finish, but gaggling ensures a mass finish is not unusual. Finishing the race further out would necessitate a higher cylinder to allow the glider to cover the distance to the airport and extra height is needed to perform a circuit. The desired circuit arrival height can be used to determine the height at which the race ends at the circle boundary. Spectator value disappeared along with the finish line but if one is bent on thrilling the onlookers there is plenty more time and room to execute the move using the remote finish. Contest site management already has the leeway to set a finish height. We have testimony that unless the finish is set high enough lower performance gliders entering the finish cylinder at the optimum height may encounter difficulty completing a satisfactory circuit and landing. Again if safety is the motivation then maybe we need to allow contest management the ability to set realistic safety parameters to suit the contest they are running. In a large contest at a restricted site a wider finish ring with height set high enough to ensure an orderly circuit for the given site and different finish heights to suit each class might alleviate safety concerns and given the more generous margins obviate the need for penalty points and the arguments they create. In short flexible finish height and an elastic cylinder radius may be the answer but despite all the risks I still prefer the old fashioned flying finish the most. Andy Gough You are correct Andy. Even a 700ft AGL minimum finish height is not enough for a low performing glider to execute a safe pattern. Coming back from the ridge at Mifflin, into the wind and a good bit of sink, I found that at 700ft 1 mile out, it would be just enough to do a base-final turn. It was not intentionally executed in this manner... just a function of getting accustomed to another ridge site and its arrival procedures from the ridge. At other contests, 500ft AGL puts low performing gliders into a straight-in final to the runway. Regards, Daniel Sazhin |
#83
The decision to thermal at 500ft AGL is the same at the finish sector, out on course or attempting to thermal out from a relight near the airport. It's irrelevant where this is taking place. If this is affecting finishing gliders, I suggest to move the finish up to 1000ft so that if there is really someone who is trying to thermal up at 500ft AGL, that there is enough separation that he does not affect the incoming traffic.
If you want a hard-deck 4 miles out to prevent pilots from electing bad judgement and thermalling low near the airport, then why is it okay to do so 5 miles from the finish? Or 50 miles from the finish to not land-out? I don't necessarily support the hard-deck nor am I opposed to it, but if you follow this sort of logic presented, that's a great reason to have a harddeck completely around the whole task area. The decision to thermal at 500ft is still the same decision, no matter where the pilot is. Best Regards, Daniel Sazhin |
#84
Or perhaps we just give the folks that are pushing for a rolling finish what they want and let Darwinism deal with them. Caveat; if you cut me off in the pattern, if I have to do evasive maneuvers to avoid you within the finish cylinder, if you jeopardize my safety in the pattern in any way, or if you jeopardize the safety of someone on the ground, then you are summarily tossed from the contest.....
#85
On Friday, January 24, 2014 8:52:32 AM UTC-8, Craig R. wrote:
Or perhaps we just give the folks that are pushing for a rolling finish what they want and let Darwinism deal with them. Caveat; if you cut me off in the pattern, if I have to do evasive maneuvers to avoid you within the finish cylinder, if you jeopardize my safety in the pattern in any way, or if you jeopardize the safety of someone on the ground, then you are summarily tossed from the contest..... What everyone is blowing off is that the finish is NOT about YOU and having a thrill at the finish, but the safety of the other pilots and ground personnel that your actions impact. Let's keep our eye on that ball. |
#86
And lastly while I am on a roll, this graduated penalty stuff is really bizarre, especially with respect to turnpoints, followed by starts and finishes. I understand that 25 years ago that the GPS loggers were much less accurate and a one mile leeway for hitting the turnpoint may have been necessary.. Nowadays, the vast majority of pilots have displays on their logging systems which clearly show if they hit the turnpoint or not. Even the ancient Colibri that I have used as my IGC logger beeps when the turnpoint is touched. The one mile leeway we have is insane! To save two miles on hitting the turnpoint and taking a penalty is a very valuable tactical decision and rules should not affect tactical decisions in this way. Bottom line, I think this should be ended.
For starts, most people have stopwatches, or some other form of clock. Furthermore, no one has ever said that you must wait exactly two minutes and go.. Why shouldn't a pilot stay say 3 minutes as an added safety factor? It would be more beneficial to simplify the rules and make 2 minutes the defining factor. With respect to starts and finishes, I think there should be 50ft of leeway given, but with 1 point per foot. A MINIMUM altitude is intended to be the floor or the ground. In the past, you could not finish under the ground. With 50ft of leeway given in starts/finishes, this could account for most instrument errors with a simple penalty system that does not require understanding a long formula. Best Regards, Daniel Sazhin |
#87
On Friday, January 24, 2014 11:51:28 AM UTC-5, wrote:
The decision to thermal at 500ft AGL is the same at the finish sector, out on course or attempting to thermal out from a relight near the airport. snip... Daniel, I had the same thought, but really I think there is a difference between having a hard deck out on course or having one just in the "prep for landing zone". I have been guilty of low save attempts, some successful, some not, some in contests, some not. But when I have attempted them, I was alone with each turn pointed at a final into an airport or field. Having someone try it near the finish cylinder is undesirable not for their own safety (well that too) but for the safety of others. Giving a 400 pt "bonus" for pulling it off, does not seem like the right thing to do. Extending the floor of the finish cylinder out some reasonable distance, would remove the incentive to save a "land out at the airport" near the airport. I would note that the suggestion of increasing the size of the finish cylinder accomplishes the same thing, but perhaps makes the pattern entry of the landing traffic less predictable. RR |
#88
It was a low overcast, windy (25-35 G 50), cold frontal day and I was the
duty tow pilot and didn't get to fly. Guess I was just testy. Thanks for the slap, Steve. :c) "Steve Leonard" wrote in message ... On Thursday, January 23, 2014 10:12:42 AM UTC-6, Dan Marotta wrote: All this talk of "safety" and you post a picture you took of your speedometer while driving at 72 MPH? And probably on a two lane road. Sheesh... Yeah. That is way too slow, Dave. I have taken pictures of the speedo at upwards of 100 MPH on two lane roads. Step it up, will ya? Actually, Dan. Dave's picture was of the odometer. Just happens you also get to see the speedometer. :-) Steve |
#89
![]() What everyone is blowing off is that the finish is NOT about YOU and having a thrill at the finish, but the safety of the other pilots and ground personnel that your actions impact. Let's keep our eye on that ball. Wow. This whole thread is fascinating - I'm looking at flying my first competitions this season, and finding I'm in way over my head. My comments are a bit off the main thread, but relevant to me and perhaps others that aren't competition pros. The idea of thermaling at 500' AGL or lower is beyond my comprehension at this point in my soaring career, and entering a landing pattern at 500' - 700' from a mile out contrary to all my student piloting lessons (even though I can calculate that it is readily doable in my glider). The rules themselves seem straightforward, even though I have little idea of how they play out in a contest. And the start and finish cylinder concepts seem straightforward. All I'm really interested in for my first tries is finishing each day, flying safely, not doing anything stupid, leaving plenty of margin, scoring some points, and having a challenge and fun (i.e. wanting to do it again). I expect as time goes on, flying more contests will lead to my learning and appreciating the strategies and tactics discussed in a lot of this thread - but my main concerns are whether the current rules are in fact safe for a neophyte to contests and a relatively low-timer. From the discussions, I'm not getting a clear sense of whether they are or not (specifically as related to the finish). I understand we are all subject to sometimes making dumb decisions, or the weather making our plans (and margins) vanish - but the rules should basically enable safe flying in contests, even accounting to some degree the wide variance in risk different pilots are willing to take under varying circumstances. Reassure me that the rules do enable basically safe flying in contests. I have to assume they do since the fatality rate doesn't seem to be something that draws headline attention. Eric Bick |
#90
On Friday, January 24, 2014 12:52:06 PM UTC-6, Eric Bick (1DB) wrote:
What everyone is blowing off is that the finish is NOT about YOU and having a thrill at the finish, but the safety of the other pilots and ground personnel that your actions impact. Let's keep our eye on that ball. Wow. This whole thread is fascinating - I'm looking at flying my first competitions this season, and finding I'm in way over my head. My comments are a bit off the main thread, but relevant to me and perhaps others that aren't competition pros. The idea of thermaling at 500' AGL or lower is beyond my comprehension at this point in my soaring career, and entering a landing pattern at 500' - 700' from a mile out contrary to all my student piloting lessons (even though I can calculate that it is readily doable in my glider). The rules themselves seem straightforward, even though I have little idea of how they play out in a contest. And the start and finish cylinder concepts seem straightforward. All I'm really interested in for my first tries is finishing each day, flying safely, not doing anything stupid, leaving plenty of margin, scoring some points, and having a challenge and fun (i.e. wanting to do it again). I expect as time goes on, flying more contests will lead to my learning and appreciating the strategies and tactics discussed in a lot of this thread - but my main concerns are whether the current rules are in fact safe for a neophyte to contests and a relatively low-timer. From the discussions, I'm not getting a clear sense of whether they are or not (specifically as related to the finish). I understand we are all subject to sometimes making dumb decisions, or the weather making our plans (and margins) vanish - but the rules should basically enable safe flying in contests, even accounting to some degree the wide variance in risk different pilots are willing to take under varying circumstances. Reassure me that the rules do enable basically safe flying in contests. I have to assume they do since the fatality rate doesn't seem to be something that draws headline attention. Eric Bick Eric, The minimum finish height is a minimum and there is no maximum. So there is no reason that the rules regarding the finish especially should force you into an unsafe position unless you choose to go there personally. I have only flown 4 contests but I think I can count on 1 hand how many times i've finished anywhere close to the minimum. Usually my problem is just getting down. 3 of those four have been at sites without particularly inviting landable terrain near the airport (Llano, TX and Moriarty). I was at my first contest in Llano and didn't really know how to use the final glide stuff on my Oudie anyway and finished ridiculously high most days. At Moriarty I usually wouldn't set out on final glide unless I had a 1000 or 1500 foot pad over minimum to hopefully account for dynamic air on the final glide.. I can think of at least one time in Moriarty where that wasn't enough. At Llano I landed out one day after finding a nice river of sink on the final glide. Your approach is smart and should lead to years of fun flying contests. I take a similar approach: don't do anything i wouldn't do in "normal" flying, bring the glider back in one piece, have fun, etc. and I have had a great time so far. |
Sean F2, Evan T8, HELP! Current finish cylinder rule! | Tom Kelley #711 | Soaring | 5 | May 24th 13 09:59 PM |
Safety finish rule & circle radius | Frank[_1_] | Soaring | 19 | September 12th 07 07:31 PM |
Height records? | Paul Repacholi | Soaring | 2 | September 7th 03 03:14 PM |
