Gravity does not power our gliders. The forward tilt of lift is what moves us forward. The sun powers our gliders. ( after the initial boost from dead dinosaurs)
us forward. The sun powers our gliders. ( after the initial boost from dead dinosaurs) What came first, the chicken or the egg? I'm with you on the sun being the power, but I gotta ask - what provides the forward tilt of lift? Bob - I'll rack out now - W. |
On 2/8/2014 10:13 PM, Bob Whelan wrote:
Gravity does not power our gliders. The forward tilt of lift is what moves us forward. The sun powers our gliders. ( after the initial boost from dead dinosaurs) What came first, the chicken or the egg? I'm with you on the sun being the power, but I gotta ask - what provides the forward tilt of lift? Bob - I'll rack out now - W. Sheesh...I really SHOULD rack out. I'll admit Mr. Sun is crucially important to us actually soaring (i.e. gaining energy), nonetheless I'm pretty sure the glider would still move forward in the absence of sunlight...but the FAA frowns on my testing that hypothesis. Bob - gravity never quits - W. |
Waveguru wrote:
Gravity does not power our gliders. The forward tilt of lift is what moves us forward. Say what now?!? You're flying in equilibrium, in unaccelerated straight line flight at a speed just above the stall. You have a nose high attitude and a line perpendicular to your wing surface is pointing rearwards. Where is the "forward tilt of lift"? You'd need a lift distribution shaped like a flaccid.....err, a slinky that's toppled forward to sustain this hypothesis. Your 'forward pointing force', the one that's opposing drag and "replacing thrust" if you're of the powered persuasion, is the forward component of weight. So yes, gravity is indeed our "engine". CJ B3 |
A rock has air and gravity when you drop it, but does not move forward through the air. Our wings provide our thrust to move us horizontally.
Boggs |
Waveguru wrote:
A rock has air and gravity when you drop it, but does not move forward through the air. Our wings provide our thrust to move us horizontally. Boggs A rock doesn't fall in equilibrium (until terminal velocity at least) and it's forces operate in only one plane - the vertical. Can we compare apples with apples please? If you have sound reasoning to offer and preferably, a vector diagram, I'm all ears. CJ B3 |
SOARING on The Aviators Set to Air | Charlie Papa[_2_] | Soaring | 1 | November 30th 13 04:04 PM |
The Aviators TV Soaring Segment | Frank Whiteley | Soaring | 1 | August 9th 13 12:32 AM |
Episode 3 of InsideSoaring | [email protected] | Soaring | 4 | April 24th 08 04:33 AM |
Mythbusters Episode and FMS | Marco Leon | Piloting | 19 | February 13th 07 05:45 AM |
New PEZ episode | John Shelton | Soaring | 11 | December 17th 03 07:49 AM |
