#51
On Tuesday, February 18, 2014 7:17:16 AM UTC-6, Don Johnstone wrote:
At 11:54 18 February 2014, Pieter Oosthuizen wrote: Thanks Chris - appreciate your comments! ![]() Apologies if I interpreted it incorrectly. PO I think Chris has made it pretty clear that the fitting of an automatic system is not at this time a practical solution. I think he has also made it pretty clear that once the sequence starts the result, as far as the tug is concerned, is inevitable. This is one of those situations where tug pilots are going to have to decide what risks they are willing to take. I would support any tug pilot who said that he would not tow a glider on a CoG or Compromise hook. On the other hand I would not tell him he could not do it. There is also a responsibility for those of us who teach aerotowing to really get across to students the danger, to the tug pilot, of getting out of position. I am not sure we have done this in the past, I know I have not been as pedantic as I should in getting this point home. Tug pilots do not always know the people they are towing so they are perhaps not aware of the experience, or lack of it, of the pilot on the back. In those circumstances the saviour should be the authoriser. We all know that does not work. Perhaps tug pilots need to be more circumspect in who they are prepared to tow. It occurred to me that attaching the tow rope to the tug near the center of gravity (top of turtle deck on a Pawnee for example) would make kiting a non-event. That's how all the RC gliders are towed since you cannot control the position of the glider really well in relation to the towplane while standing on the ground. Interference of the tow rope with rudder and elevator does not seem to be a problem for RC fliers. |
#52
On Tuesday, 18 February 2014 11:25:24 UTC-5, wrote:
On Tuesday, February 18, 2014 7:17:16 AM UTC-6, Don Johnstone wrote: It occurred to me that attaching the tow rope to the tug near the center of gravity (top of turtle deck on a Pawnee for example) would make kiting a non-event. That's how all the RC gliders are towed since you cannot control the position of the glider really well in relation to the towplane while standing on the ground. Interference of the tow rope with rudder and elevator does not seem to be a problem for RC fliers. Um... wouldn't that cause a great risk of fouling the tail feathers of the tug? No more "boxing the wash". |
#53
At 16:41 18 February 2014, C-FFKQ 42 wrote:
On Tuesday, 18 February 2014 11:25:24 UTC-5, wrote: On Tuesday, February 18, 2014 7:17:16 AM UTC-6, Don Johnstone wrote: =20 It occurred to me that attaching the tow rope to the tug near the center = of gravity (top of turtle deck on a Pawnee for example) would make kiting a= non-event. That's how all the RC gliders are towed since you cannot contr= ol the position of the glider really well in relation to the towplane while= standing on the ground. Interference of the tow rope with rudder and elev= ator does not seem to be a problem for RC fliers. Um... wouldn't that cause a great risk of fouling the tail feathers of the = tug? No more "boxing the wash". OK here is a whacky idea. A V shaped boom with the point to the rear of the rudder, the release mounted at this point. The two front points mounted to a pivot, through the fuselage above the wing, near the CoG. The V arrangement can pivot up, but not down. The space between the arms has to be sufficient to allow full rudder. Would only work for low wing monoplanes. |
#54
On Tuesday, February 18, 2014 1:50:52 PM UTC-7, Don Johnstone wrote:
OK here is a whacky idea. A V shaped boom with the point to the rear of the rudder, the release mounted at this point. The two front points mounted to a pivot, through the fuselage above the wing, near the CoG. The V arrangement can pivot up, but not down. The space between the arms has to be sufficient to allow full rudder. Would only work for low wing monoplanes. Well as long as were are drawing on envelopes, how about a bridle attached to each wingtip of the towplane, with the towhook at the apex of the bridle, able to slide side to side (to prevent rudder stalls) while the bridle pivots up during kiting so the force just pulls the towplane higher! To drop the glider, release one end of the bridle and the towhook just slips off. Or just teach the stupid glider pilot to fly the correct tow position! Of course, a good winch solves this problem nicely.... Kirk |
#55
On Tuesday, February 18, 2014 6:56:56 PM UTC-5, kirk.stant wrote:
On Tuesday, February 18, 2014 1:50:52 PM UTC-7, Don Johnstone wrote: OK here is a whacky idea. A V shaped boom with the point to the rear of the rudder, the release mounted at this point. The two front points mounted to a pivot, through the fuselage above the wing, near the CoG. The V arrangement can pivot up, but not down. The space between the arms has to be sufficient to allow full rudder. Would only work for low wing monoplanes. Well as long as were are drawing on envelopes, how about a bridle attached to each wingtip of the towplane, with the towhook at the apex of the bridle, able to slide side to side (to prevent rudder stalls) while the bridle pivots up during kiting so the force just pulls the towplane higher! To drop the glider, release one end of the bridle and the towhook just slips off. Or just teach the stupid glider pilot to fly the correct tow position! Of course, a good winch solves this problem nicely.... Kirk The Dragonfly towplane for hang & ultralite gliders uses a bridle attached above the top of the rudder and just below the bottom of the rudder, withbthe tow rope free to ride up and down on the bridle. Hang gliders sometimes get way out of shape, but the tug isn't affected. UH |
#56
On Tue, 18 Feb 2014 08:41:57 -0800, C-FFKQ (42) wrote:
On Tuesday, 18 February 2014 11:25:24 UTC-5, wrote: On Tuesday, February 18, 2014 7:17:16 AM UTC-6, Don Johnstone wrote: It occurred to me that attaching the tow rope to the tug near the center of gravity (top of turtle deck on a Pawnee for example) would make kiting a non-event. That's how all the RC gliders are towed since you cannot control the position of the glider really well in relation to the towplane while standing on the ground. Interference of the tow rope with rudder and elevator does not seem to be a problem for RC fliers. Um... wouldn't that cause a great risk of fouling the tail feathers of the tug? No more "boxing the wash". From what I know of model aircraft I suspect, but can't prove it, that the fin on an RC model is (relatively) considerably stronger than the fin on a towplane. Structurally, most RC model fins are either solid balsa sheet or a foam-filled fibreglass moulding. If its a sheet balsa fin its almost guaranteed to be a lot harder and denser than I'd ever use on a model I was building myself. An RC model can be dumped on the strip in a manner that would wreck any GA aircraft. They are very frequently landed this way. Rounding out? Whats that? Land the model badly on grass enough to flip it over onto its back and the fin is almost guaranteed to be undamaged. Could you say the same about a typical towplane's fin? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#57
On Tuesday, 18 February 2014 12:07:20 UTC+2, Chris Rollings wrote:
That might work but I suspect it would be impossible, in the real World, to get a sufficiently high degree of reliability that we did not get more accidents from innocent gliders be jettisoned at low altitudes than we currently get from kiting accidents. Hi Chris This is not a personal attack - I appreciate your valuable input but ... With modern technology we can reliably detect pitch, roll, acceleration of a tug plane IMO. e.g. My Note 2 has a magnetometer, electronic gyros, accelerometers, barometer, and GPS. I downloaded an artificial horizon app for my Android phone and when it blends all the sensor data you get a very reliable pitch and roll output. It doesn't even experience gyro drift because it is able to compensate using the magnetometer to sense gravity. Another example are all the Ardupilot projects. If they are capable of flying DIY autonomous drones around for under $300 then I think the technology is available and good enough for us to use. Even so, I'd rather have a 1 in 1000 chance of accidentally being dumped than kill a tug pilot and myself through a momentary lapse of judgement/attention. I happen to fly at the club in South Africa which had the low altitude, tug upset on Sunday 16th Feb 2014, resulting in the death of the tug pilot in a Cessna 182A. I simply refuse to believe that we can fly to the moon and back but can't devise a reliable automatic tow release mechanism. How many more tug pilots around the world do we have to kill before we devise a mechanism which works? To detect a tug upset reliably I think one would only need: 1. To sense the tug elevator at the back stop + 2. The pitch of the tug (say 20 degrees down and increasing) + 3. The load on the rope (glider still attached). I can't imagine the above being present in any normal operational situation. Paul |
#58
At 07:23 19 February 2014, Surge wrote:
On Tuesday, 18 February 2014 12:07:20 UTC+2, Chris Rollings wrote: That might work but I suspect it would be impossible, in the real World, to get a sufficiently high degree of reliability that we did not get more accidents from innocent gliders be jettisoned at low altitudes than we currently get from kiting accidents. Hi Chris This is not a personal attack - I appreciate your valuable input but ... With modern technology we can reliably detect pitch, roll, acceleration of a tug plane IMO. e.g. My Note 2 has a magnetometer, electronic gyros, accelerometers, barometer, and GPS. I downloaded an artificial horizon app for my Android phone and when it blends all the sensor data you get a very reliable pitch and roll output. It doesn't even experience gyro drift because it is able to compensate using the magnetometer to sense gravity. Another example are all the Ardupilot projects. If they are capable of flying DIY autonomous drones around for under $300 then I think the technology is available and good enough for us to use. Even so, I'd rather have a 1 in 1000 chance of accidentally being dumped than kill a tug pilot and myself through a momentary lapse of judgement/attention. I happen to fly at the club in South Africa which had the low altitude, tug upset on Sunday 16th Feb 2014, resulting in the death of the tug pilot in a Cessna 182A. I simply refuse to believe that we can fly to the moon and back but can't devise a reliable automatic tow release mechanism. How many more tug pilots around the world do we have to kill before we devise a mechanism which works? To detect a tug upset reliably I think one would only need: 1. To sense the tug elevator at the back stop + 2. The pitch of the tug (say 20 degrees down and increasing) + 3. The load on the rope (glider still attached). I can't imagine the above being present in any normal operational situation. Paul Paul, by the time your items 1, 2 & 3 are present it is probably too late, the tail-plane is almost certainly stalled and even if the glider were jettisoned at that instant, the tow-plane would probably still pitch down another 40 or 50 degrees before recovery (I say probably, could someone please test it with a camera plane alongside at safe altitude, done deliberately it should be possible to pull the release at exactly the right moment - might take three or four goes to get on exactly right). The thing that is constantly under-estimated by those that haven't experienced it is how quickly it all happens. LESS THAN 3 SECONDS FROM ALL NORMAL TO ALL OVER. People take at least that long to react to something unexpected unless it is something they have practiced frequently, certainly not the case in kiting incidents. |
#59
It is clear from what we have seen on this thread that we have identified
an occurrence which has resulted in the death of tug pilots. If we do nothing tug pilots will continue to be killed and the question is, "Are we resigned to classing these future deaths as a normal operating hazard?" For my part I would not be particularly comfortable with this, especially as I could be the pilot on the back. We have established, thanks to Chris that the event, from start to finish, happens over a very short period. He estimates 2 - 3 seconds and I have no reason to doubt this assessment. Chris is a very experienced pilot of both gliders and tugs and he further states that once the event starts it is unlikely that either pilot can react in time to prevent a predictable outcome. That predictable outcome is the tug pointing vertically at the ground at full throttle. The only unknown in any of these events is whether or not there is sufficient height for the tug pilot to recover from this situation before the ground gets in the way. If there is insufficient height the tug pilot is going to die. There has been much discussion concerning an auto release mechanism. Chris has said that he does not think that a mechanical "angle detection" system would work in time, I concur with that view. The problem is not just the height above the tug that the glider reaches but the rate of change in height. It has been suggested that by the time the glider has reached the height behind the tug to cause a problem it is too late to do anything about it. There is one possibility, measurement of the rate of change in height relative to the tug. The technology for this exists and is abundant, we see this every day in the boxes on the side of the road, I speak of course of speed cameras. It would not be difficult to have a device that operated the release if there was a rate of change in excess of what we consider normal. You could even take two measurements or more to detect an increasing rate of change (Unsafe) to a decreasing rate of change (Less Unsafe). The device would trigger the release instead of the camera. Ideally this would be mounted in the glider but given the cost implications it would be acceptable in the tug. There is an opportunity to give the glider the rope before the tug gets into an irrecoverable situation. This would not be cheap, and I am sure there are other options we have yet to discover, but is the option of doing nothing acceptable? We do not know the cause of this occurrence in every case, we do know the effect and the outcome. We do know the factors that are likely to contribute to the cause, for example CoG hooks, but addressing this alone, as Chris has pointed out, is not the complete answer. We are left with mitigating the effects and I think we owe it to the people who provide our tows to do all we can. Lastly I would like to thank Chris Rollings for sharing his research. Without his work we would be dealing with theories, which are less compelling than real results. |
#60
I think the Gyro, and full back stick switch has some potential but has some issues, such as calibrating the Gyro, and possible Test/fault issues that would need to be overcome.
Another one to consider would be a time delay switch on the Throttle. Once the throttle has been set to climb power for more than say 5 seconds (time might need to be adjusted) then if the stick is moved to full aft, a release is initiated. The throttle delay is to prevent releases during the 1st part of the ground roll. I can't think of any other time when the tow plane would have full back stick and full throttle that the pilot would not want the glider to be released. One advantage of this system is that the tow pilot should know this combination will cause a release and bring a higher awareness to the possibility of the glider kiting. Another issue to be addressed by either of these systems is that it will require a powerful actuator to ensure a release actually occurs when needed. Just brain storming some idea's Brian |
inReach website not updating track automatically | Eric Greenwell[_4_] | Soaring | 4 | September 23rd 13 09:59 PM |
Compare/Contrast: CG hook on aerotow vs. CG hook on winch | son_of_flubber | Soaring | 37 | June 4th 12 10:40 PM |
TOST E85 RELEASES | [email protected] | Soaring | 2 | March 6th 05 04:21 PM |
Cumulus releases version 1.2.1 | André Somers | Soaring | 0 | March 2nd 05 09:58 PM |
NSA releases EC-121 Liberty tapes: no smoking gun | Mike Weeks | Military Aviation | 0 | July 9th 03 05:06 AM |
