The "offical" LXNAV V7 thread
Old March 1st 14, 04:53 PM posted to rec.aviation.soaring
Default The "offical" LXNAV V7 thread
You need to ensure the baud speed for your logger is the same as the baud speed for the PDA (as the V7 gives the PDA direct access to the logger when declaring a task). This should fix the problem
Chris
On Thursday, 27 February 2014 02:03:11 UTC, ES wrote:
Has anyone had luck uploading tasks from Oudie to V7? This topic isn't discussed in the user guide, and I'm not having any luck repeating the settings in the youtube video on the subject (device = "LXNAV - Nano", interface = "COM4:", speed = "4800bps".
In the video, there is very quick connection and transfer.
When I try it (using the latest V7 firmware and Oudie version), I get "Connecting" on the Oudie, and the communication icon on the V7, but nothing else.
thanks
ted/ES
  #53
Old June 3rd 14, 07:10 AM posted to rec.aviation.soaring
Can someone post the wiring diagram to connect the Vertica V2 / Avier to the V7?
Thank you,
Nick
  #54
Old June 3rd 14, 04:53 PM posted to rec.aviation.soaring
Craig Funston
Thank you,
Nick
Google "glider guider USB/Serial Data Interface" There's a PDF that has the pinouts for the GliderGuider / Vertica V2. The pinouts for the V7 are available at the LXnav website in the V7 manual. I'm assuming you're using a separate GPS source for the V7. I'm not aware of a way to get the GPS data from the Vertica into the V7.
Cheers,
Craig
  #55
Old June 5th 14, 03:33 PM posted to rec.aviation.soaring
J. Murray
Howdy. Has anybody had trouble getting the V7 to display glide info from the Oudie lately?
Thanks, Jim
  #56
Old June 5th 14, 07:10 PM posted to rec.aviation.soaring
Paul Remde
Hi Jim,
I haven't tested it lately, but below is a note about how to get it working.
Some of the settings are not intuitive.
______________
Settings to have the Oudie send GPS data to the V7 and the V7 send vario and
airspeed data to the Oudie.
On the Oudie in the Menu Settings Hardware screen
Device: LXNAV V7
GPS Forwarding: enabled
Use backup GPS: disabled (may not be necessary)
Port Settings
Comm 4, 115200
On the V7 in the Communications screen
GPS-PDA Link: disabled
Auto baudrate: disabled
PDA port baudrate: 115200
GPS port baudrate: 115200
Tested – it works great.
Paul Remde
Cumulus Soaring, Inc.
________________________________________________
"J. Murray" wrote in message
the Oudie lately?
Thanks, Jim
  #57
Old June 5th 14, 09:55 PM posted to rec.aviation.soaring
J. Murray
I haven't tried disabling the PDA link. That'll be next...
Thanks!
  #58
Old June 5th 14, 11:25 PM posted to rec.aviation.soaring
Richard[_9_]
Thanks!
This one worked yesterday.
V7 COM Menu
* Auto Baud checked
* PDA 4800
* GPS 4800
* NMEA enable
Oudie Hardware Menu
* Device V7
* COM 4
* 4800
* Check GPS Forwarding
Oude Input Manual
* Com 4
* 4800
Richard
www.craggyaero.com
  #59
Old June 6th 14, 01:10 AM posted to rec.aviation.soaring
J. Murray
That's worth a try too.
Thanks Richard.
  #60
Old June 6th 14, 08:18 PM posted to rec.aviation.soaring
I'm connecting the 10 pin mini usb from the Avier V2/ Vertica V2 to the V7.
Has anyone installed their own male RJ45 connector on a mini USB to connect the V2 to the LXNAV V7?
I need the pin assignments for both.
LXNAV V7 - Reviews? David Reitter Soaring 10 October 21st 14 12:41 AM
New LXNAV LX9000 Overview Video Paul Remde Soaring 0 April 21st 12 01:33 AM
LXNAV V7 Paul Remde Soaring 2 November 2nd 11 12:31 AM
LXNAV Nano and LX 9000 Overview Videos Available Paul Remde Soaring 3 February 28th 11 01:58 PM
HELP! Need offical Blanik L-13 Canopy Strap John Scott Soaring 4 March 3rd 08 05:03 AM
