Cambridge 302 Calibration
Old March 9th 14, 03:46 PM posted to rec.aviation.soaring
Karl Kunz[_2_]
Default Cambridge 302 Calibration
I can't remember where I saw it but is calibration check on the 302 now required every 5 years vs. 2 ?
Also who still does them?
-karl
Old March 9th 14, 09:35 PM
dbrunone dbrunone is offline
Member
First recorded activity by AviationBanter: Oct 2011
Not sure about intervals but Gary Kammerer at Clearnav can hook you up
Old March 10th 14, 12:11 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
On Sun, 09 Mar 2014 13:27:18 -0700, Karl Kunz wrote:
So calibration is only required for record flights not badges and
contest?
I've always understood that rule to mean that for badges you're OK
provided its less than 5 years since it was last calibrated or, if it was
calibrated more than 5 years ago, you get the logger calibrated within
the next month after the flight.
Others can talk about contests.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old March 10th 14, 01:27 PM posted to rec.aviation.soaring
Tim[_10_]
a lot of pilots waste money getting loggers and barographs calibrated for
no reason. Most never turn in a flight for a badge or record ever and even
those who do can have the calibration done AFTER the flight they want to
turn in just as easily as having it done ahead of time. The calibration
doesn't change or improve the logger in any way, it simply shows how much
its trace is off from actual pressure altitude. As far as I know even
contest flown that might brequire a secure logger don't require a
calibration to be legal.
tim
"dbrunone" wrote in message
dbrunone
60 Days for Calibration [email protected] Soaring 7 May 1st 06 03:00 AM
IGC badge calibration [email protected] Soaring 8 May 2nd 05 05:32 AM
Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 Nathan Whelchel Soaring 4 July 5th 04 11:22 PM
Calibration LX5000-IGC Jan Joost Bierhoff Soaring 2 March 25th 04 08:35 AM
Volkslogger Calibration Ray Lovinggood Soaring 5 September 13th 03 04:56 PM
