A friend and I recently purchased a Mini Nimbus. I'm interested in acquiring a wing wheel to make it easy for one person to move the glider around.
Are there any out there and available? Are there any out there and available that are going cheap? Thanks, Van Van Henson Mini Nimbus N301YC |
They are very simple to make and don't have to be a really good fit. Any
cuff that will fit over the wing without pinching or flopping around will be just fine. "Van Henson" wrote in message ... A friend and I recently purchased a Mini Nimbus. I'm interested in acquiring a wing wheel to make it easy for one person to move the glider around. Are there any out there and available? Are there any out there and available that are going cheap? Thanks, Van Van Henson Mini Nimbus N301YC |
http://www.wingsandwheels.com/page34.htm
On Tuesday, March 18, 2014 11:28:38 AM UTC-4, Dan Marotta wrote: They are very simple to make and don't have to be a really good fit. Any cuff that will fit over the wing without pinching or flopping around will be just fine. "Van Henson" wrote in message ... A friend and I recently purchased a Mini Nimbus. I'm interested in acquiring a wing wheel to make it easy for one person to move the glider around. Are there any out there and available? Are there any out there and available that are going cheap? Thanks, Van Van Henson Mini Nimbus N301YC |
If you want a wing wheel that really fits your wing profile and will not nibble nastily at aileron and flap trailing edges I would suggest that you contact Mark Mocho (M&M Fabrication). Tel: 505-298 2922. His wing wheels also work well in serious cross winds.
I am a well satisfied customer. On Monday, March 17, 2014 11:52:26 PM UTC-6, Van Henson wrote: A friend and I recently purchased a Mini Nimbus. I'm interested in acquiring a wing wheel to make it easy for one person to move the glider around. Are there any out there and available? Are there any out there and available that are going cheap? Thanks, Van Van Henson Mini Nimbus N301YC |
Howard- Thanks for the recommendation. Only problem with the post is the incorrect telephone number. I have moved to Moriarty from Albuquerque, and my cell number is 505 249-0161. Email remains the same: mark (at) mmfabrication (dot) com I also disagree with Dan's assertion that a wing wheel doesn't have to be a very good fit. I have seen a bunch of damaged trailing edges and ailerons due to badly fitting wing wheels. |
Sorry to disagree with you, Mark, but a tight fit on the left wing will not
work on the right wing. Think taper. I do agree, however, with what you said about the trailing edge. "Mark628CA" wrote in message ... Howard- Thanks for the recommendation. Only problem with the post is the incorrect telephone number. I have moved to Moriarty from Albuquerque, and my cell number is 505 249-0161. Email remains the same: mark (at) mmfabrication (dot) com I also disagree with Dan's assertion that a wing wheel doesn't have to be a very good fit. I have seen a bunch of damaged trailing edges and ailerons due to badly fitting wing wheels. |
| FS - IMI Wing Wheel | slbair | Soaring | 0 | September 17th 13 05:27 PM |
| LS3a or Mini Nimbus | [email protected] | Soaring | 14 | November 11th 06 11:36 PM |
| Mini Nimbus for sale - N. California | [email protected] | Soaring | 0 | August 1st 06 05:14 AM |
| Nimbus 2c wing templates | Robert Hart | Soaring | 7 | March 3rd 06 06:25 PM |
| For Sale - Mini-Nimbus | Frank Smith | Soaring | 1 | February 25th 04 08:23 PM |
