I am pleased to announce IGC-approval for the Naviter Oudie-IGC GPS Flight Recorder for "all flights" including world records. The IGC-approval document may be downloaded from the FAI/IGC web site or the GFAC web site, see below. A table of all IGC-approved Flight Recorders can also be downloaded from these web sites which has links to the IGC-approval document for each type of Recorder.
There are now 46 different types of IGC-approved Flight Recorders from 18 different manufacturers. If you own or fly with one of these types of IGC Flight Recorder, you are recommended to download its latest IGC-approval document from one of the web sites given below. For the GFAC web site: www.ukiws.demon.co.uk/GFAC The table of all IGC-approved FRs with links to Approval Documents is at: www.ukiws.demon.co.uk/GFAC/igc_approved_frs.pdf This document contains: (1) a table of all types of IGC-approved Flight Recorders in alphabetical order of manufacturer name, with links to their IGC-approval documents. (2) a table of Manufacturers of IGC-approved Flight Recorders, in alphabetical order of manufacturer name. (3) a list of all IGC-approval activity from 1996 to the present day. (4) a history of IGC GNSS Flight Recording. -------------------------- For the IGC web site: http://www.fai.org/gnss-recording-de...ight-recorders Scroll down to "IGC-Approved Flight Recorders - Approval Documents" Then click on the box underneath the above heading which says: "IGC-approval Documents for all IGC-approved Flight Recorders". This will call up a list of documents, the first one being "IGC-approval tables" with links to individual Approval documents. This is followed by IGC-approval documents in alphabetical order of manufacturer's name. Scroll down to the Recorder type and click on its name. The IGC-approval document will then download automatically to the directory that you have set for downloads, without being displayed on screen first. ------------------------- IGC-approval follows test and evaluation by the IGC GNSS Flight Recorder Approval Committee (GFAC) in accordance with Annex B to the Sporting Code for gliding and the Technical Specification for IGC-approved GNSS Flight Recorders. The Technical Specification is available through the igc-approved-flight-recorders web site above or directly from the GFAC web site: http://www.ukiws.demon.co.uk/GFAC/do..._spec_gnss.pdf The Sporting Code for gliding (SC3) and its annexes A-D may be downloaded via www.fai.org/igc-documents ------------------------ Ian Strachan Chairman, IGC GNSS Flight Recorder Approval Committee www.ukiws.demon.co.uk/GFAC |
So if I have an Oudie-V7-Nano setup, is there any reason to keep to Nano anymore?
On Wednesday, March 26, 2014 2:43:47 PM UTC-5, dbrunone wrote:
So if I have an Oudie-V7-Nano setup, is there any reason to keep to Nano anymore? Yes, the original Oudie and Oudie 2 do not have IGC-approved flight recorders -- only the latest product called "Oudie IGC". |
When is the last time the Oudie IGC has been updated (todays date 3/4/16)?
Seems like electronics are outdated after a year or two if not updated. Does the IGC have bluetooth? I could not find this, so is this something Naviter is considering or never will be in IGC? Seems like a lot of electronics have bluetooth. |
On Friday, March 4, 2016 at 7:36:23 AM UTC-5, Casey wrote:
When is the last time the Oudie IGC has been updated (todays date 3/4/16)? Seems like electronics are outdated after a year or two if not updated. Does the IGC have bluetooth? I could not find this, so is this something Naviter is considering or never will be in IGC? Seems like a lot of electronics have bluetooth. I believe it does have bluetooth, but admittedly, I have not tried it yet on mine. |
On Friday, March 4, 2016 at 8:09:16 AM UTC-5, Minot Moonshiners wrote:
On Friday, March 4, 2016 at 7:36:23 AM UTC-5, Casey wrote: When is the last time the Oudie IGC has been updated (todays date 3/4/16)? Seems like electronics are outdated after a year or two if not updated. Does the IGC have bluetooth? I could not find this, so is this something Naviter is considering or never will be in IGC? Seems like a lot of electronics have bluetooth. I believe it does have bluetooth, but admittedly, I have not tried it yet on mine. Yes it does appear to have bluetooth. Retailers do not have it listed but I found on Naviter site via support. |
IGC-approval for the FlarmMouse Flight Recorder | Ian Strachan | Soaring | 0 | August 2nd 13 12:37 PM |
LX7007FC Flight Recorder gains IGC-approval. | Ian Strachan | Soaring | 0 | January 24th 12 02:11 PM |
New type of Flight Recorder gains IGC-approval | Ian Strachan | Soaring | 0 | August 31st 11 06:21 AM |
New IGC-approval for GNSS Flight Recorder | Ian Strachan | Soaring | 0 | February 14th 09 08:00 PM |
IGC-approval issued for Aircotec GPS Flight Recorder | Ian Strachan | Soaring | 0 | May 30th 06 11:47 PM |
