Delorme InReach Explorer
Old April 15th 14, 04:04 PM posted to rec.aviation.soaring
javelin77@gmail.com
Default Delorme InReach Explorer
Anyone know anything about this new version of the Delorme InReach? Apparently adds ability to navigate to waypoints and route planning/navigation.
Old April 15th 14, 04:16 PM posted to rec.aviation.soaring
javelin77@gmail.com
Link: http://www.inreachdelorme.com/
Old April 15th 14, 05:26 PM posted to rec.aviation.soaring
jfitch
I can't imagine that to be of much use in a glider, unless you had crashed and were trying to walk out.
Old April 15th 14, 05:52 PM posted to rec.aviation.soaring
Paul Remde
Hi,
I have updated my DeLorme web page with some details on the new inReach
Explorer
http://www.cumulus-soaring.com/delor...Reach-Explorer
The inReach Explorer is physically identical to the inReach SE (except for
the color) and offers all the same features as the SE and uses the same data
plans. The only difference is that the Explorer adds the ability to navigate
to waypoints. It will be interesting to see whether the addition of
navigation is worth the extra $80 to glider pilots.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
____________________________________
Old April 15th 14, 08:01 PM posted to rec.aviation.soaring
son_of_flubber
A potential problem with using a handheld GPS to walk out is the finite battery duration. I prefer a compass and paper topo map when I'm hiking backcountry. The GPS is good to use for a few seconds to obtain current position.
Old April 16th 14, 01:43 AM posted to rec.aviation.soaring
jfitch
I think the Delorme is good for about 4 or 5 days, more if tracking is shut off. If it takes you longer than that to walk out, it better have been at the far end of an almost successful world record distance attempt!
Old April 20th 14, 08:09 PM posted to rec.aviation.soaring
Ramy[_2_]
And you can always carry a smal external battery.
I wonder how many XC pilots carry external battery for their cell phone in case of landout? Otherwise you likely going to run out of your smartphone battery just before your crew arrives.
Ramy
Old April 20th 14, 09:10 PM posted to rec.aviation.soaring
7C
Ramy
I solved this problem by having the same connector for my navigation (Kobo) as my phone and my inReach. As I've only ever exceeded the capacity of one battery 3 times in 10 years I'm guessing there will always be something left in the other one to charge them up. I truth I also have a small USB battery pack that is in my landout bag, total cost about £15.00
Old April 20th 14, 09:33 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Carry a 12v-5v converter with usb out, wired with same connector as your glider battery. You will almost always have some capacity left which is not useful after you land... Computer shops have 3 in 1 usb cables with multiple common cellphone connectors. Mine has samsung, iPhone 4 and 5 (I can even offer charges to other pilots in the same field).
Old April 21st 14, 03:26 AM posted to rec.aviation.soaring
Dan Marotta
Not about the lithium battery, but about the cell phone.
First, I turn my phone off before takeoff. This saves a lot of battery.
Second, since I power my Dell Streak via a switch controlled 12v power
connector (cigarette lighter) and a 12v to USB converter, I bought a twin
jack USB converter so that I can charge my cell in flight off the ship's
batteries (if I want to) and keep my Streak charged. I keep a charge cable
for my phone connected and coiled up so if I land out, I can make sure the
phone is fully charged. I also carry spare batteries for the Spot.
"Ramy" wrote in message
Ramy
DeLorme InReach info Sean F (F2) Soaring 2 July 12th 13 03:17 PM
DeLorme inReach SE units now in stock Paul Remde Soaring 1 July 4th 13 01:05 AM
DeLorme inReach Paul Remde Soaring 8 February 12th 13 07:26 PM
Any user reports on Delorme Inreach? Steve Koerner Soaring 8 March 16th 12 06:51 PM
More on Delorme InReach Satellite Tracker Frank Paynter[_2_] Soaring 12 October 8th 11 05:50 AM
