Sorting out Experimental Airworthiness Certification and LSA designation
Old April 16th 14, 11:16 PM posted to rec.aviation.soaring
son_of_flubber
Default Sorting out Experimental Airworthiness Certification and LSA designation
I have a glider manufactured in 1998 in Poland and imported to the USA in 1999 and issued an Experimental Airworthiness Certificate. It is type certified in Europe. (SZD 51-1)
The glider appears to meet all of the operational specifications for LSA wrt weight, VNE, stall speed etc.. Is that sufficient to make it an LSA for FAR purposes? Is it necessary/possible to amend the Air Worthiness Certificate to designate the glider as an LSA? Is there any particular advantage/disadvantage to doing this?
Why would I stir the pot?
I bought the glider used. I moved it to a new base of operations. The original operating limitations required flying within 300 NM of the previous location. Last year, the local FAA office was happy with a program letter specifying my 'temporary' base of operation. This year they want me to amend my airworthiness certification and change my base of operations. They tell me that an inspection is not needed to amend the certificate.
Why do I care about LSA? I would like to get rid of the 300 NM geographic radius limitation and also eliminate the need for a program letter whenever I want to fly outside that radius. I'm wondering if I can ask for this amendment to be made at this time and whether the LSA designation would help me.
Old April 17th 14, 12:21 AM posted to rec.aviation.soaring
Two Shoes (Judson Knowles)
Here is what I found with my Google-Fu.... from RAS 2010: https://groups.google.com/forum/#!to...ng/L8SfJBQjM0I
Old April 17th 14, 12:35 AM posted to rec.aviation.soaring
Andy K
Where do you currently send you program letter?
Old April 17th 14, 01:43 AM posted to rec.aviation.soaring
I have no knowledge about LSAs.
But I have an experimental.
My FSDO has been quite helpful and easy to work with.
My yearly program letter calls out about 15 locations where I am planning to practice for proficiency or participate in racing.
Historically my planning never works out.
In the past I never made it anywhere close to all those 15 different locations in 1 year. I am not aware of any limit in the number of locations you can state in the program letter.
Anyway, my 15 locations cover all of the routes we usually fly.
Nearly all of California, Nevada, Utah.
And if I want to go to a location that I did not plan for at the moment of issuance of the program letter, I only need to send an email to my FSDO, stating the new location(s) as amendment.
Old April 17th 14, 03:09 AM posted to rec.aviation.soaring
Bill T
I would not care about changing an experimental to LSA. AFAIK it would gain you nothing. If the glider qualifies within the speed limitations of an LSA, a glider rated LSA pilot can fly it. An aircraft does not have to be registered as LSA for an LSA rated pilot to fly it.
Changing the program letter for a new location and region of flying is a standard practice for the "newer" program letters. It may require a reissue of the airworthy cert, I would keep it experimental for exhibition and racing.
I'm not sure if what is listed on the TCDS may restrict how it is certified, ruling out LSA.
BT
Old April 17th 14, 01:20 PM posted to rec.aviation.soaring
son_of_flubber
That helps.
Have any glider manufacturers brought their products into the USA as LSA?
The LSA lobby seems to be large, strong and effective at moderating regulations.
And though it is traditional and many have gotten used to it, Experimental Racing/Exhibition owners seem to be a small and marginalized group, that is at the mercy of local FSDO interpretations.
It seems that LSA regulations are friendly, and getting friendlier, whereas Experimental regulations seem somewhat arbitrary and tending to get less friendly over time.
I realize that the Experimental regs encompass all sorts of marginal truly experimental aircraft and thus the FAA oversight functions are justified. But putting my 'type-certified-in-Europe-conservative-glider' in the experimental bucket seems an expedient hack.
Now that LSA is emerging, I wonder if I'd should try to get into that bucket instead. The holder of the type certificate is still a viable business.
Old April 17th 14, 01:33 PM posted to rec.aviation.soaring
Tom (2NO)
"I would like to get rid of the 300 NM geographic radius limitation and also eliminate the need for a program letter whenever I want to fly outside that radius."
If you simply add OLC to your list of events you never have to worry about the geographic limitation. I fax my program letter in the first week of Jan each year. No receipt or confirmation is required, just make sure you have a copy of it with your other required documents.
Old April 17th 14, 02:11 PM posted to rec.aviation.soaring
son_of_flubber
I suppose that would work until someone at my FSDO decides that OLC is not a 'race' in the same sense as what is called a 'race' in my operating limitations written in 1998.
Old April 17th 14, 04:03 PM posted to rec.aviation.soaring
Dan Marotta
I've owned one Standard airworthiness category glider and 5 Experimental. I
would not want other than Experimental simply for the lower maintenance
requirements. I don't mean shoddy maintenance - I simply mean that I can do
more and an A&P can complete the annual condition inspection. The program
letter is a bothersome requirement but trivial to execute. I keep a copy on
my computer and simply update it annually and email it to the FSDO. The
first time I had to do this, I called and spoke to a real person. He gave
me his email address and said to send the letter directly to him. He never
responds unless I ping him for confirmation, but I copy myself as proof that
it was sent. The wording says, in addition to planned events, that I can
fly anywhere while practicing for those events or for the OLC.
"Bill T" wrote in message
racing.
ruling out LSA.
BT
Old April 17th 14, 08:02 PM posted to rec.aviation.soaring
Frank Whiteley
Your operating limitations should say something about FAI and SSA records and awards. SSA recognizes OLC.
Frank Whiteley
Experimental Airworthiness PS Soaring 13 July 1st 09 03:54 PM
USA Glider Experimental Airworthiness Certificate charlie foxtrot Soaring 4 April 15th 06 05:04 AM
FS 2002 - sorting aircraft rottenberg Simulators 1 November 2nd 04 07:59 PM
How did F117 get it's designation? ReeferGuy Military Aviation 13 January 24th 04 02:32 PM
Airworthiness certification of an experimental Ace Pilot Home Built 0 July 16th 03 03:26 PM
