Removing Cambridge 302 bezel?
Old April 19th 14, 06:14 AM posted to rec.aviation.soaring
Kurt Thams
Default Removing Cambridge 302 bezel?
The needle fell off my 302 today, just sitting behind the plastic bezel. Anyone know how to remove that bezel so I can re-seat the needle?
Old April 19th 14, 08:51 AM posted to rec.aviation.soaring
Peter Purdie[_3_]
You are not the first. A SMALL drop of cyanoacrylate glue will hold it
when replaced. However, you have to completely disassemble the unit to fix
it, after which it will need an agent to electronically reseal (and best to
replace the memory battery at the same time).
Suggest you ask Gary at Clearnav, who is the US repair agent, or Klaus Keim
or Dickie Feakes if in Europe.
Old April 19th 14, 03:02 PM posted to rec.aviation.soaring
Paul Remde
I can also repair it and change the backup battery and re-seal it.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"Peter Purdie" wrote in message
Old April 19th 14, 07:02 PM posted to rec.aviation.soaring
Dan Marotta
I had the same experience a year or two ago and sent the unit to Gary as
suggested and got a quick turn-around.
Now I wonder... Since I'm not interested in contests or records and have
all my diamonds, couldn't I have simply done the job myself? Wouldn't the
unit still provide igc files acceptable to OLC and Skylines?
"Paul Remde" wrote in message
Best Regards,
Paul Remde
fix
to
Keim
Removing Old Tape Kevin Christner Soaring 5 March 28th 12 12:07 AM
Removing RTV John Home Built 6 October 31st 06 11:07 PM
Removing Ethanol from Gas? Jay Honeck Piloting 67 August 16th 06 04:29 PM
Winter Mech Vario Bezel Mike Hostage Soaring 2 March 29th 05 06:42 AM
Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 Nathan Whelchel Soaring 4 July 6th 04 12:22 AM
