#11
It would be nice to have the option to include a list of transponder codes that were always suppressed. For example, 1202. One could make the determination if a majority of the local gliders with a transponder also had FLARM. If that was a reasonable assessment for your location, then suppressing all the 1202 hits would potentially reduce the false alarms based on transponders and would rely on the more reliable FLARM data.
On Saturday, April 19, 2014 2:49:22 PM UTC-7, wrote:
It would be nice to have the option to include a list of transponder codes that were always suppressed. For example, 1202. One could make the determination if a majority of the local gliders with a transponder also had FLARM. If that was a reasonable assessment for your location, then suppressing all the 1202 hits would potentially reduce the false alarms based on transponders and would rely on the more reliable FLARM data. Ah the trouble there is you cannot definitively associate a Mode A squawk reply with the same transponder doing a Mode C reply. And there will be situations where targets are doing Mode C only replies (e.g. any time a target is being interrogated by TCAS I or II but out of range of ground SSR... which I'm guessing happens a fair amount). The 'best' you could do in that situation is stop all PCAS warnings. That may be/is likely too drastic, you can also so try adjusting the PCAS height/range parameters. Ultimately there is nothing you can do that is goign to work that well with Mode C transponders. Hopefully over time this will go away as an issue as Mode S transponder use keeps growing in the USA glider fleet. There is no need/strong justification to replace a Mode C today, they work great for letting ATC know where you are and with TCAS, TCAD and PCAS in GA aircraft etc. but on the other hand there is no sane reason to buy a new Mode C transponder today. The possible issues here with PowerFLARM interoperability is just one of those reasons. Over time and as equipment ages and gets expensive to repair and new Mode S transponder technology hopefully keeps falling in cost and size etc. we'll just see the current Mode C usage in the glider fleet migrating over to Mode S. I'm much less worried about Mode C vs. Mode S than I am to encourage *any* transponder use in areas of high airline, fast jet, and even GA traffic. Anybody who what my opinion on what the FAA should have really done with Mode S vs. Mode C transponders and ADS-B Out carriage mandates, etc. is welcome to buy me a six pack of beer and put up with an hour of whining. |
Of course you all know that I'm not a Flarm guy.
Having said that, it strikes me funny that nobody seems to have noticed that it's the "same altitude" aircraft that's going to hit you. Why would you want all transponders at co-altitude to be suppressed? And the notion that you're going to be OK since the Flarm will point out other Flarm traffic. Listen up, Guys: GA, military, and airlines are NOT using Flarm. Oh, and we have at least one guy at Moriarty who has a Flarm but not a transponder. So he and the half dozen or so Flarm equipped gliders can avoid each other but he's cruising along blissfully unaware that ATC can't see him, nor can the airliners or military flights that buzz in and out of ABQ daily. Hopefully Flarm will work this out as Zaon did several years ago. "darrylr" wrote in message ... On Saturday, April 19, 2014 2:49:22 PM UTC-7, wrote: It would be nice to have the option to include a list of transponder codes that were always suppressed. For example, 1202. One could make the determination if a majority of the local gliders with a transponder also had FLARM. If that was a reasonable assessment for your location, then suppressing all the 1202 hits would potentially reduce the false alarms based on transponders and would rely on the more reliable FLARM data. Ah the trouble there is you cannot definitively associate a Mode A squawk reply with the same transponder doing a Mode C reply. And there will be situations where targets are doing Mode C only replies (e.g. any time a target is being interrogated by TCAS I or II but out of range of ground SSR... which I'm guessing happens a fair amount). The 'best' you could do in that situation is stop all PCAS warnings. That may be/is likely too drastic, you can also so try adjusting the PCAS height/range parameters. Ultimately there is nothing you can do that is goign to work that well with Mode C transponders. Hopefully over time this will go away as an issue as Mode S transponder use keeps growing in the USA glider fleet. There is no need/strong justification to replace a Mode C today, they work great for letting ATC know where you are and with TCAS, TCAD and PCAS in GA aircraft etc. but on the other hand there is no sane reason to buy a new Mode C transponder today. The possible issues here with PowerFLARM interoperability is just one of those reasons. Over time and as equipment ages and gets expensive to repair and new Mode S transponder technology hopefully keeps falling in cost and size etc. we'll just see the current Mode C usage in the glider fleet migrating over to Mode S. I'm much less worried about Mode C vs. Mode S than I am to encourage *any* transponder use in areas of high airline, fast jet, and even GA traffic. Anybody who what my opinion on what the FAA should have really done with Mode S vs. Mode C transponders and ADS-B Out carriage mandates, etc. is welcome to buy me a six pack of beer and put up with an hour of whining. |
I am pretty sure that the suppression is based on power as well, in addition to altitude. So only a strong signal at the same altitude will be suppressed. Which mean you will still get warning for same altitude until the other aircraft is very close, giving you enough warning. I assume this is the same way that Zaon works. But again this is just my guess. Will be nice if Flarm folks will comment on this.
Ramy |
Dan -
The statistics show over and over that glider-to-glider collisions are more of a threat than glider-to-GA/Miliatry. FLARM isn't intended to be a perfect solution; it's intended to provide a very reliable, medium-cost, low-power solution for the biggest collision threat: other maneuvering gliders. Mode C and even Mode S systems are not well-suited for combating glider-on-glider carnage when the craft are in close proximity and maneuvering. There simply is no perfect solution; but I for one will take the single solution that reasonably covers the broadest range of targets and situations - and right now that's a PowerFLARM. --Noel |
"noel.wade" wrote:
Dan - The statistics show over and over that glider-to-glider collisions are more of a threat than glider-to-GA/Miliatry. FLARM isn't intended to be a perfect solution; it's intended to provide a very reliable, medium-cost, low-power solution for the biggest collision threat: other maneuvering gliders. Mode C and even Mode S systems are not well-suited for combating glider-on-glider carnage when the craft are in close proximity and maneuvering. There simply is no perfect solution; but I for one will take the single solution that reasonably covers the broadest range of targets and situations - and right now that's a PowerFLARM. --Noel Hopefully that decision gets made by each pilot for the conditions they fly in. And it's not necessarily a choice between a transponder or PowerFLARM. And the decision should not always come down to PowerFLARM being the first choice for all pilots. And having both provides very broad technology assistance. And if in busy airspace areas establishing local procedures, radio contact with ATC etc. with or without a transponder may be appropriate. Around busy airspace with lots of airliners and fast jet traffic the PowerFLARM is just not going to be of much use. Except maybe highlighting how much airline etc. traffic is around to be worried about as you see them via 1090ES (around 1/3rd of airliners are currently 1090ES Out? I am not sure). Worrisome areas include those with lots of fast aircraft, all of who are are in touch with ATC and everybody expects TCAS to just work because 'everybody else has a transponder'. The consequence of being the invisible glider without a transponder that gets run into by an airliner is not going to be pretty, so hopefully there is a local flying situation risk x consequence part of any decision of what to equip with. But yes clearly for glider-glider collision risks PowerFLARM is by far the best choice. PCAS in PowerFLARM gives you useful help around GA traffic, but for the big/fast conflicts you want to be seen by ATC and the TCAS aboard those aircraft. Which means you need a transponder. ADS-B remains largely a complex mess/futureware. Darryl |
That's what I would hope. I recall that, when I installed my Mode S
transponder and had it tested, it was putting out over 175 watts to the test equipment antenna. Don't we have an inverse cube function of power density to distance? I think that's right, though I probably didn't say it correctly. Anyway, an aircraft a couple of hundred feet away would be received in the milliwatt range, maybe somewhat more, but certainly not at 100+ watts. "Ramy" wrote in message ... I am pretty sure that the suppression is based on power as well, in addition to altitude. So only a strong signal at the same altitude will be suppressed. Which mean you will still get warning for same altitude until the other aircraft is very close, giving you enough warning. I assume this is the same way that Zaon works. But again this is just my guess. Will be nice if Flarm folks will comment on this. Ramy |
Good points, Noel.
"noel.wade" wrote in message ... Dan - The statistics show over and over that glider-to-glider collisions are more of a threat than glider-to-GA/Miliatry. FLARM isn't intended to be a perfect solution; it's intended to provide a very reliable, medium-cost, low-power solution for the biggest collision threat: other maneuvering gliders. Mode C and even Mode S systems are not well-suited for combating glider-on-glider carnage when the craft are in close proximity and maneuvering. There simply is no perfect solution; but I for one will take the single solution that reasonably covers the broadest range of targets and situations - and right now that's a PowerFLARM. --Noel |
Well, I can report that the PowerFlarm core fails to warn me of commercial traffic most of the time. In the past week, I have been within distances of concern to a Boeing 737 and a Canadair Regional jet - they descend over our gliderport into Tucson International. My transponder seems to work, though - both these aircraft took evasive action to avoid me. The Canadair was at my altitude and had to make a very steep turn away from me. Not a peep from the Flarm!
Mike |
On Sunday, April 20, 2014 10:14:46 AM UTC-5, Dan Marotta wrote:
Listen up, Guys: GA, military, and airlines are NOT using Flarm. Oh, and we have at least one guy at Moriarty who has a Flarm but not a transponder. So he and the half dozen or so Flarm equipped gliders can avoid each other but he's cruising along blissfully unaware that ATC can't see him, nor can the airliners or military flights that buzz in and out of ABQ daily. Blissfully unaware? Well, since GA, military, and airliners are pretty much all using either Mode A/C, Mode S, or ADS-B, that PFlarm-only guy is probably fully aware of the location of any potentially threatening traffic in his vicinity - even that VFR doctor in the Bonanza squawking 1200 and not talking to anybody... And he is also aware of where all his gliding buddies are - and that's a lot of fun, too! - even the clueless new guy who it trying to run into him under his nice Cu in the middle of nowhere. So while I agree that if you routinely mix in with high-speed airline traffic (common out West, not as common in most of midwest or east) a transponder is a smart thing, I think that a PFlarm is even more of a good thing. Both is best. Try it - you might like it. Seriously. Cheers, Kirk |
PowerFLARM 3.0 and TIS | Andy[_1_] | Soaring | 6 | January 21st 14 09:35 AM |
PowerFLARM USB 3 cables and ConnectMe to PowerFLARM through V7 | Tim Taylor | Soaring | 20 | June 17th 13 05:56 PM |
PowerFLARM 2.71...WTF? | [email protected] | Soaring | 40 | May 2nd 13 03:32 AM |
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available | Paul Remde | Soaring | 30 | May 25th 12 11:58 PM |
PowerFLARM | Greg Arnold[_2_] | Soaring | 6 | November 2nd 10 09:32 AM |
