1-26 1000km attempt
Old April 25th 14, 04:00 AM posted to rec.aviation.soaring
JS
Default 1-26 1000km attempt
I thought it was just Ron wishing he'd flown the ASW20.
Old April 25th 14, 04:11 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
On Thursday, April 24, 2014 10:00:19 PM UTC-5, JS wrote:
I thought it was just Ron wishing he'd flown the ASW20. Jim
Or subliminal (ASW27) messaging (ASG29) of some sort.
Steve
Old April 25th 14, 05:43 PM posted to rec.aviation.soaring
Soartech
On Thursday, April 24, 2014 3:42:48 PM UTC-4, Vernon Brown wrote:
On these discussion groups and R.A.S in particular I keep seeing "=20"
Can some please explain the meaning?
I wondered the same thing so I Googled it and found the answer.
=20 is code for a normal space and =A0 is code for a space between words where the line can't break (a non-breaking space). For an example of the use of the latter, if I was to type something like "read this help article: https://productforums.google.com/d/topic/gmail/WCklpQTrJMk/discussion", the Forum editor puts a non-breaking space in place of the normal space after the ":". You can check the effect by changing the width of the window where you are reading this to try and make the word "article:" sit at the end of a line - it will instead wrap on to the next line along with the URL.
Old April 26th 14, 07:37 PM posted to rec.aviation.soaring
Vernon Brown
Thanks to all who contributed with the explanation of =20
Tried to send this message earlier today, but for some reason it did not
appear
Vernon
"=3D20"
=20
=20
=3D20 is code for a normal space and =3DA0 is code for a space between
word=
th=
articl=
e:
aft=
w=
en=
URL.
1000km in a 1-26 Tony[_5_] Soaring 8 June 29th 12 03:04 PM
Check out Ron Tabery's 1000km WR Soaring 3 August 12th 09 02:41 AM
1000km Soaring Weather coming to NV CA SW U.S. - Fri-Sun 06/23-25 WaltWX Soaring 16 June 29th 06 09:04 AM
1000KM + Soaring conditions - SPECTACULAR - Fri-Mon 06/23 - 26 WaltWX Soaring 1 June 22nd 06 11:14 PM
Narromine FAI 750 Km and 1000KM in Australia Mal Soaring 1 November 2nd 04 04:08 AM
