P-38 Exhaust
Old April 9th 04, 08:54 PM
Stephen Harding
Default P-38 Exhaust
Time to do my share to improve the S/N ratio here at r.a.m,
or at least make a try at it!
It's easy to overlook. No exhaust pipes visible protruding
from the sheet metal around the Allison engines on the P-38.
Given that Lookheed, and Kelly Johnson in particular, paid
a lot of detailed attention in the design and execution of
the aircraft, I'm wondering why they never made an effort
to use exhaust thrust to squeeze a few extra hp/mph out of
the engines for this aircraft.
The Spitfire in particular, but I believe the P-51 as well,
all made use of exhaust thrust to gain a bit more speed. Given
the P-38 was designed in 1937-ish and didn't appear in person
until about 1939, perhaps the advantage of using thrust to
boost speed a little wasn't really thought of? Perhaps the
Allison at the time of design just didn't have the oomph for it?
Also, exactly where does the P-38 engine exhaust exit the
engine? Seems to be a big, upward facing pipe in the vicinity
of the turbocharger, but never really knew if that was turbo
intake or an exhaust of some sort.
Upward directed exhaust doesn't seem a good choice.
SMH
Old April 9th 04, 09:01 PM
Steven P. McNicoll
"Stephen Harding" wrote in message
They did, by having the exhaust drive a turbocharger.
Old April 9th 04, 11:27 PM
Chris Mark
That's it, just behind the turbo, the exhaust waste gate outlet. No place else
to duct it as directly aft is the wheelwell, which is filled not only with the
wheel but engine coolant plumbing, the engine coolant radiators being behind
the wheel well. Just forward of the turbo are two turbine cooling air intakes
and a cockpit heater air intake. Then all the plumbing and ducting for not
only the turbo but oil and intercooler radiators, carburetor, etc. No room at
all, especially compared to a the turbosupercharger set up in something fiarly
straightforward like, say, the B-17. But even the B-17 just pokes the exhaust
gate out of the lower rear of the engine nacelle.
Chris Mark
Old April 10th 04, 05:09 AM
The Enlightenment
Much of the energy of the exhaust would already have been extracted by
the turbo-supercharger but I expect there was still some residual
thrust in it.
The thrust of a Merlin was I believe around 300lbs. (about 140kg or
1400N). At 440 mph (200m/s) that would be equivalent to 280kw or
400hp more at the shaft if prop efficiency of around 80% was allowed
for.
Turbochargers probably make more sense for slower moving aircraft.
Kelly Johnson was not all that happy with the GE trubosuperchargers on
the Alison because they had been specified by the airforce rathern
than properly integrated by Lockheed.
Aircraft like the P39 and Allison P51 did not perform well at altitude
because they did not have the turbosupercharged Allison only a single
stage super charger. Apparently the USAAF had neglected super-charger
development in favour of turbo-charger development.
The Merlin with a two stage intercooled supercharger and jet exhaust
nozzles could do the job almost as good without a turbo.
The P39 was tested with a turbo, I don't know if the P51 ever was.
There was a turbo-compounded Allison as well in which the turbo drove
the main engine shaft via a hydraulic trogue converter instead of a
supercharger.
It seems that for raw material reasons the special alloys needed were
reserved mainly for 4 engined bombers with the exception being P47s
and P38s.
The Germans because they had lower octane fuels had to use larger
lower boosted engines and instead relied on variable speed single
stage superchargers. Their raw material problemes were quite severe
even though they had by 1938 BMW turbo chargers that were reliable and
could cope with 850C temperatures.
The only turbo-supercharged engine to enter service appears to have
been the BMW801T which made it into a small number of high altitude
reconaiseance Ju 388's (there was a night fighter version as well
designed to interecpet high altitude B29s should they begin night time
bombing)
The Ta 152 did have a two stage intercooled supercharger on its
version of the Jumo 213 engine.
It probably kept exhaust duck back pressure low and got rid of a
draggy exhaust nozzle.
SMH
Old April 10th 04, 05:19 AM
Peter Stickney
Stephen Harding writes:
Right. On all Lockheed Model 322s other than the RAF Lightning 1s,
the exhaust gas is ducted to the hot section of the turbosupercharger
in the tail boom.
Given that Lockheed, and Kelly Johnson in particular, paid
Because it was far more useful to use the energy in the exhaust to run
the 1st stage (Turbosupercharger) or the 2-stage supercharger setup on
the P-38. If that supercharger stage were run from a gear train from
the engine, it would eat up 150-200 Shaft Horsepower that would
otherwise go to the propeller. At speeds below about 400 MPH, you
gain more thrust by providing that power to the propeller, rather than
as jet thrust.
This is due to the Thrust-Power relationship.
Since 1 HP = 550 lb ft/sec, or 1 HP = 375 lb Miles/Hr,
1 HP = 1 lb (force) of thrust at 375 moh. At lower speeds, 1 HP
produces more thrust, and at higher speeds, less. Here's a table
showing thrust values for a 1000 HP engine at various speeds,
ignoring propeller efficiency.
SHP Speed, mph Thrust, lb
1000 50 7500
1000 100 3750
1000 150 2500
1000 200 1875
1000 250 1500
1000 300 1250
1000 350 1071
1000 400 938
1000 450 833
So, as you can see, thrust starts out quite high, and drops off as
speed increases. For a constant power output engine, such as a recip
or the propeller section of a turboprop, this number represents the
maximum amount of thrust that can be produced by the propeller.
Now, a constant thrust value will produce more Horsepower as the
airplane moves faster. Here's a table showing how much power is
produced by our nominal 100# of thrust from our 1000 HP engine.
Thrust,lb Speed, mph Thrust HP
100 50 13
100 100 27
100 150 40
100 200 54
100 250 67
100 300 80
100 350 93
100 400 108
100 450 120
At about 25,000', it takes about 150 HP to compress the air that the
turbosupercharger is taking in. So, I'll gin up another table,
showing the thrust produced by an 850 SHP engine, with 100# of jet
thrust, and the thrust that our 1000 HP engine would produce.
Speed, SHP Propeller Jet Total 1000 SHP 1000 SHP
MPH Thrust lb Thrust Thrust Thrust Thrust Advantage
50 850 6385 100 6485 7500 1015
100 850 3188 100 3288 3750 462
150 850 2125 100 2225 2500 275
200 850 1594 100 1694 1875 181
250 850 1275 100 1375 1500 125
300 850 1063 100 1163 1250 87
350 850 910 100 1010 1071 61
400 850 797 100 897 938 41
450 850 708 100 808 833 25
500 850 638 100 738 759 12
As you can see, not losing that 150 SHP to run the first supercharger
stage gives you a really big gain at low speeds. Which is where you
really need it - best climb for a P-38 was at around 150 mph, so
excess thrust in that speed range really pays off.
It was, actually fairly well understood, (The N.A.C.A. had published
several papers on it before the XP-38 had ever flown)
Pretty much all inline-engined fighters from the late 1930s used
ejector exhausts to get a bit of jet thrust. Take a look at an Me
109, a P-40, or a Hurricane. Most radials used collector-type
exhausts, and that pretty much negated any thrust that you'd be able
to extract. Later A-20s, B-25s, the Fw 190, the A6M5, the A-26, and
the Centaurus engined Tempest and Sea Fury did end up with jet stacks.
Jet thrust is a product of Mass Flow (Pretty low, for a recip. and the
expansion ratio as the pressure reduces in the exhaust stacks from the
exhaust valve to atmospheric. Mass flow is a product of displacement
and RPM, so there's not much of a difference between a 1650 cubic
inch Merlin at 3000 RPM, and a 1710 cu. in. Allison at 3000 RPM.
In each case, you're getting "Something for free" - actually, it's
more like "Something you'd otherwise get no use out of" by choosing to
use either a gear-driven first supercharger stage (As in the later
(Post 1942) Merlin 60 series) and get more jet thrust, or a
turbine-driven auxiliary stage, like the Allison in the P-38, and not
gain the jet thrust. Depending on the propeller efficiency at high
speed, (Which we neglect here, because it's really, really,
complicated, and doesn't change the results much) It's possible to get
a slight gain in thrust by using the ejector exhausts - but only at
the very high end of the speed range, and at a substantial cost in
engine Shaft Horsepower.
The turbosupercharger gives you much more thrust a lower speeds, where
it really help to improve your climb rate, and excess power for
sustaining turns. It comes at a fairly large cost of weight and bulk,
There was just no way that an engine-turbosupercharger installation
like that of a P-38, with its ducting, intercoolers, extra
lubrication, and extra oil coolers, was going to fit in a small
fighter like a Spitfire, or a P-51. Look at the original XP-39. It
started out with a turbosupercharger, but all the various coolers &
ducts added so many lumps, bumps, and bulges, because they wouldn't
fit in the airframe, that it would never have made its performance
guarantees. In an airframe that was already going to be big, like a
P-38, or a P-47, it wasn't that much of a cost. It's all a matter of
tradeoffs, and what you're willing to spend in one area to gain in
another.
Yep, that's the turbine exhaust.
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
Old April 11th 04, 10:27 PM
Paul Hirose
Are you sure? I thought P-38 turbine wheels were visible on top of the
nacelle, exhaust gas simply shooting up between the blades into the
open air. Aft of the turbo was an exhaust pipe, but it was for gas
from the waste gate, not the turbine.
That's my understanding, anyway. Maybe it's wrong; I couldn't find
anything in my books to confirm or contradict it.
I think the P-38 was not the only airplane with the backside of its
turbocharger turbine "naked".
Paul Hirose
To reply by email delete INVALID from address.
Old April 12th 04, 01:36 AM
Stephen Harding
in the tail boom.
[snip lots of good info for further digestion]
Wow, spectacular reply Peter!
Thanks so much for this very informative response.
Need to read it a couple more times for it all to
sink in though.
SMH
Old April 17th 04, 07:20 AM
Paul Hirose
In a museum today I took a close look at one of those big General
Electric aircraft turbochargers, a type B-2-LY according to a sign at
the exhibit. The turbine portion is much different from any modern
turbo I've seen. Exhaust gas from the engine enters a toroidal plenum
through a port in its circumference. A second port 180 degrees away
goes to a butterfly valve in a short duct leading to the atmosphere.
This is the waste gate.
The side of the plenum that faces away from the compressor has a
circle of nozzles to direct the gas against the single stage axial
flow turbine wheel, which is on the exterior of the turbocharger! Of
course this requires the turbine to be flush with the aircraft
surface.
A small cooling air duct crosses the turbine's exposed face, like a
bridge. It connects to a stationary circular "cooling cap" which
covers the center of the turbine wheel. Air flows through the duct,
into the cooling cap, then exits through a narrow gap (about 1 or 2
mm) between the cooling cap and turbine disk, near the roots of the
blades.
The air duct continues across the turbine wheel and ends in an
attachment to the exhaust plenum. Apparently this is simply to give
support; the pipe comes to a dead end here.
In photos of a P-38 upper nacelle it's possible to see all this. The
cooling cap air duct is quite visible running fore and aft above the
turbine. Some photos show the turbine blades too. They appear as a
close-spaced pattern of radial lines, almost like a grille.
I've seen the same thing in pictures of B-24s. But later bombers used
a different turbine exhaust configuration. In the B-36 (B-29 & B-50 as
well, I think) the turbines were enclosed.
Paul Hirose
Old April 19th 04, 12:49 AM
IBM
Paul Hirose wrote in
[snip]
B17 is like that IIRC.
Mind you its been a few years since I was under one.
IBM
__________________________________________________ _____________________________
Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com
The Worlds Uncensored News Source
Old April 19th 04, 01:16 AM
Dale
Both the B-17 and B-24 have the same turbocharger the P-38 has...of
course on the bombers it's on the bottom of the nacelle.
Dale L. Falk
Citabria 7ECA Exhaust Wanted Capt. Dave Home Built 2 February 2nd 05 04:20 AM
Exhaust Valves Boelkowj Home Built 4 January 25th 05 12:15 AM
SS exhaust ball joints Stu Home Built 1 January 3rd 04 10:34 PM
YF-23 exhaust? Sir Loin of Beef Military Aviation 0 August 1st 03 04:55 AM
Exhaust Tape RobertR237 Home Built 19 July 30th 03 03:06 AM
