"Ragnar" wrote in message ...
"Yeff" wrote in message ... I've seen it suggested on some web pages that the Israelis are using smaller Hellfire warheads for their anti-terror strikes than come standard. Is this true and, if so, does anyone have a good cite? From what I understand, the Israelis have converted both the TOW and Hellfire to use blast/frag warheads instead of the usual shaped charge ones. Blast/frag is more efficient for attacking the target set they are going after. I don't know about weight though. I've heard the same from someone who was over there during the height of the tit-for-tat missile strikes and Pal attacks a couple of years ago (sure doesn't seem that long). |
![]() "Arie Kazachin" wrote in message ... In message - "Kevin Brooks" writes: For some reason, people like Hitler or Arafat tend to by lucky enough to be saved from a bomb by a heavy table or to walk away from a plane crash... Well, in Arafat's case, the Israeli government has made a conscious decision NOT to target him for years. He could have been easily whacked on a number of occasions. |
writes: [snip] Well,Hellfire uses a shaped charge warhead,so it makes a "jet' of penetrating metal,tearing through the car's interior and the blast may occur outside the car,and it would not affect the hubcaps/wheelcovers. Think about what you just said. The fact that the standard Hellfire uses a HEAT warhead does not really greatly affect the blast effect; it only means that a portion of the blast has been used (as it expands outward) to invert the liner and turn it into a stream of really hot metal and gas focused on a small area. The explosive still exhibits a generally spherical blast pattern overall. Set a fifteen pound demo shaped charge against the average passenger vehicle and you'll see that it does not *need* the shaped charge effect to do a pretty good number on the target; that much HE going off in close contact to the car will tend to ruin everyone's day if they were unfortunate enough to be inside it. Brooks There was at least one case when a terrorists leader remained alive because he was sitting in a front seat while the missile hit the back seat. So it seems the blast effect is far from spherical. Or maybe he just got extreamly lucky. For some reason, people like Hitler or Arafat tend to by lucky enough to be saved from a bomb by a heavy table or to walk away from a plane crash... Those damn ROE: not only the pilots have to hit a specific car at specific moment, they also need to hit it at specific point... ************************************************** **************************** * Arie Kazachin, Israel, e-mail: * ************************************************** **************************** NOTE: before replying, leave only letters in my domain-name. Sorry, SPAM trap. ___ .__/ | | O / _/ / | | I HAVE NOWHERE ELSE TO GO !!! | | | | | | | /O\ | _ \_______[|(.)|]_______/ | * / \ o ++ O ++ o | | | | | \ \_) \ | \ | \ | \ | \ | \ | \ | \_| |
![]() "Jim Yanik" wrote in message .. . "Kevin Brooks" wrote in : "Jim Yanik" wrote in message .. . Glenfiddich wrote in : On Tue, 20 Apr 2004 15:52:44 -0400, Yeff wrote: I've seen it suggested on some web pages that the Israelis are using smaller Hellfire warheads for their anti-terror strikes than come standard. Is this true and, if so, does anyone have a good cite? Highly likely - if it *was* a Hellfire. Check the early pictures of the last airstrike - the blast didn't even remove the car's hubcaps. Ignore later pictures - reports say the car was vandalised by souvenir seekers. Well,Hellfire uses a shaped charge warhead,so it makes a "jet' of penetrating metal,tearing through the car's interior and the blast may occur outside the car,and it would not affect the hubcaps/wheelcovers. Think about what you just said. The fact that the standard Hellfire uses a HEAT warhead does not really greatly affect the blast effect; it only means that a portion of the blast has been used (as it expands outward) to invert the liner and turn it into a stream of really hot metal and gas focused on a small area. The explosive still exhibits a generally spherical blast pattern overall. Set a fifteen pound demo shaped charge against the average passenger vehicle and you'll see that it does not *need* the shaped charge effect to do a pretty good number on the target; that much HE going off in close contact to the car will tend to ruin everyone's day if they were unfortunate enough to be inside it. Brooks -- Jim Yanik jyanik-at-kua.net I *did* think about what I wrote. The blast is going to occur in a place where the roughly spherical blast front is not likely to affect wheel covers or hubcaps. The jet will not do much damage in itself,the majority of damage inside - will- be caused by the blast. My guess is you have never seen these kind of warheads go off in proximity to a thin-skinned vehicle--they do tend to do a lot more than you seem to think against that kind of target. Brooks -- Jim Yanik jyanik-at-kua.net |
![]() "Arie Kazachin" wrote in message ... In message - "Kevin Brooks" writes: [snip] Well,Hellfire uses a shaped charge warhead,so it makes a "jet' of penetrating metal,tearing through the car's interior and the blast may occur outside the car,and it would not affect the hubcaps/wheelcovers. Think about what you just said. The fact that the standard Hellfire uses a HEAT warhead does not really greatly affect the blast effect; it only means that a portion of the blast has been used (as it expands outward) to invert the liner and turn it into a stream of really hot metal and gas focused on a small area. The explosive still exhibits a generally spherical blast pattern overall. Set a fifteen pound demo shaped charge against the average passenger vehicle and you'll see that it does not *need* the shaped charge effect to do a pretty good number on the target; that much HE going off in close contact to the car will tend to ruin everyone's day if they were unfortunate enough to be inside it. Brooks There was at least one case when a terrorists leader remained alive because he was sitting in a front seat while the missile hit the back seat. So it seems the blast effect is far from spherical. I'd think it more likely that he was rather lucky, or had the benefit of some armor protection, or a combination of both. Then again, did the missile actually strike the vehicle, or was it a near miss? Eight or ten pounds of Comp B (or whatever they are using as a filler) going off in intimate contact with the side of the average POV is going to be an experience that only the lucky occupants survive. Brooks Or maybe he just got extreamly lucky. For some reason, people like Hitler or Arafat tend to by lucky enough to be saved from a bomb by a heavy table or to walk away from a plane crash... Those damn ROE: not only the pilots have to hit a specific car at specific moment, they also need to hit it at specific point... ************************************************** ************************** ** * Arie Kazachin, Israel, e-mail: * ************************************************** ************************** ** NOTE: before replying, leave only letters in my domain-name. Sorry, SPAM trap. ___ .__/ | | O / _/ / | | I HAVE NOWHERE ELSE TO GO !!! | | | | | | | /O\ | _ \_______[|(.)|]_______/ | * / \ o ++ O ++ o | | | | | \ \_) \ | \ | \ | \ | \ | \ | \ | \_| |
: "Jim Yanik" wrote in message .. . "Kevin Brooks" wrote in : "Jim Yanik" wrote in message .. . Glenfiddich wrote in : On Tue, 20 Apr 2004 15:52:44 -0400, Yeff wrote: I've seen it suggested on some web pages that the Israelis are using smaller Hellfire warheads for their anti-terror strikes than come standard. Is this true and, if so, does anyone have a good cite? Highly likely - if it *was* a Hellfire. Check the early pictures of the last airstrike - the blast didn't even remove the car's hubcaps. Ignore later pictures - reports say the car was vandalised by souvenir seekers. Well,Hellfire uses a shaped charge warhead,so it makes a "jet' of penetrating metal,tearing through the car's interior and the blast may occur outside the car,and it would not affect the hubcaps/wheelcovers. Think about what you just said. The fact that the standard Hellfire uses a HEAT warhead does not really greatly affect the blast effect; it only means that a portion of the blast has been used (as it expands outward) to invert the liner and turn it into a stream of really hot metal and gas focused on a small area. The explosive still exhibits a generally spherical blast pattern overall. Set a fifteen pound demo shaped charge against the average passenger vehicle and you'll see that it does not *need* the shaped charge effect to do a pretty good number on the target; that much HE going off in close contact to the car will tend to ruin everyone's day if they were unfortunate enough to be inside it. Brooks -- Jim Yanik jyanik-at-kua.net I *did* think about what I wrote. The blast is going to occur in a place where the roughly spherical blast front is not likely to affect wheel covers or hubcaps. The jet will not do much damage in itself,the majority of damage inside - will- be caused by the blast. My guess is you have never seen these kind of warheads go off in proximity to a thin-skinned vehicle--they do tend to do a lot more than you seem to think against that kind of target. Brooks -- Jim Yanik jyanik-at-kua.net Sure,the blast will blow in the car's glass,and frags shred the metalwork. But the pressure wave would be directed such that wheel covers or hubcaps would be pushed ON,not blown off.It may not even be directed towards the hubcaps. -- Jim Yanik jyanik-at-kua.net |
![]() "Jim Yanik" wrote in message .. . "Kevin Brooks" wrote in : "Jim Yanik" wrote in message .. . "Kevin Brooks" wrote in : "Jim Yanik" wrote in message .. . Glenfiddich wrote in : On Tue, 20 Apr 2004 15:52:44 -0400, Yeff wrote: I've seen it suggested on some web pages that the Israelis are using smaller Hellfire warheads for their anti-terror strikes than come standard. Is this true and, if so, does anyone have a good cite? Highly likely - if it *was* a Hellfire. Check the early pictures of the last airstrike - the blast didn't even remove the car's hubcaps. Ignore later pictures - reports say the car was vandalised by souvenir seekers. Well,Hellfire uses a shaped charge warhead,so it makes a "jet' of penetrating metal,tearing through the car's interior and the blast may occur outside the car,and it would not affect the hubcaps/wheelcovers. Think about what you just said. The fact that the standard Hellfire uses a HEAT warhead does not really greatly affect the blast effect; it only means that a portion of the blast has been used (as it expands outward) to invert the liner and turn it into a stream of really hot metal and gas focused on a small area. The explosive still exhibits a generally spherical blast pattern overall. Set a fifteen pound demo shaped charge against the average passenger vehicle and you'll see that it does not *need* the shaped charge effect to do a pretty good number on the target; that much HE going off in close contact to the car will tend to ruin everyone's day if they were unfortunate enough to be inside it. Brooks -- Jim Yanik jyanik-at-kua.net I *did* think about what I wrote. The blast is going to occur in a place where the roughly spherical blast front is not likely to affect wheel covers or hubcaps. The jet will not do much damage in itself,the majority of damage inside - will- be caused by the blast. My guess is you have never seen these kind of warheads go off in proximity to a thin-skinned vehicle--they do tend to do a lot more than you seem to think against that kind of target. Brooks -- Jim Yanik jyanik-at-kua.net Sure,the blast will blow in the car's glass,and frags shred the metalwork. But the pressure wave would be directed such that wheel covers or hubcaps would be pushed ON,not blown off.It may not even be directed towards the hubcaps. You seem mighty sure of yourself on this. I could care less what happens to the freakin' hubcaps--the point is that eight or so pounds of very energetic HE going off in intimate contact with a friggin' sheet-metal/fiberglass/plastic carbody will tend to do a LOT of damage. That HEAT effect is almost an inconsequential byproduct when targeting a thin-skinned vehicle. If you doubt that, then take a gander at what the bigger off-route IED's are doing to our troops in Iraq. Or take the example of an M21 AT mine set to go off *not* in intimate contact with a vehicle (M21's use the platter charge, or IIRC Miznay-Schardin effect, and I doubt they have much more HE in them than a Hellfire does)--we did that with an old M880 pick-up truck and physically relocated that puppy (and that penetrator had little to do with accomplishing *that*) (and we sort of ****ed off the range control guys in the process...). Brooks -- Jim Yanik jyanik-at-kua.net |
writes: [snip] There was at least one case when a terrorists leader remained alive because he was sitting in a front seat while the missile hit the back seat. So it seems the blast effect is far from spherical. I'd think it more likely that he was rather lucky, or had the benefit of some armor protection, or a combination of both. Then again, did the missile actually strike the vehicle, or was it a near miss? Eight or ten pounds of Comp B (or whatever they are using as a filler) going off in intimate contact with the side of the average POV is going to be an experience that only the lucky occupants survive. Brooks Yes, the missile DID hit the car, only the wrong seats row. ************************************************** **************************** * Arie Kazachin, Israel, e-mail: * ************************************************** **************************** NOTE: before replying, leave only letters in my domain-name. Sorry, SPAM trap. ___ .__/ | | O / _/ / | | I HAVE NOWHERE ELSE TO GO !!! | | | | | | | /O\ | _ \_______[|(.)|]_______/ | * / \ o ++ O ++ o | | | | | \ \_) \ | \ | \ | \ | \ | \ | \ | \_| |
In message - "Ragnar"
writes: "Arie Kazachin" wrote in message ... In message - "Kevin Brooks" writes: For some reason, people like Hitler or Arafat tend to by lucky enough to be saved from a bomb by a heavy table or to walk away from a plane crash... Well, in Arafat's case, the Israeli government has made a conscious decision NOT to target him for years. He could have been easily whacked on a number of occasions. I was talking about a plane crash that happened to Arafat many years ago which killed few of his guards but he got out alive, unfortunately... ************************************************** **************************** * Arie Kazachin, Israel, e-mail: * ************************************************** **************************** NOTE: before replying, leave only letters in my domain-name. Sorry, SPAM trap. ___ .__/ | | O / _/ / | | I HAVE NOWHERE ELSE TO GO !!! | | | | | | | /O\ | _ \_______[|(.)|]_______/ | * / \ o ++ O ++ o | | | | | \ \_) \ | \ | \ | \ | \ | \ | \ | \_| |
