For Brooks... The Superior Leopard 2
Old May 3rd 04, 12:45 AM
The Enlightenment
"Kevin Brooks" wrote in message ...
"The Enlightenment" wrote in message
"robert arndt" wrote in message
om...
http://www.fprado.com/armorsite/leo2.htm
Forecast International's and Jane's Best Tank in the World... three
years running.
Rob
A fine weapon, though there is not much gap between the M1A2 and the
latter Leopards. I believe the hyperbaric diesel of the Leopard
consumes 3/4 less fuel though the smoother power of the AGT 1500 might
help hill climbing.
What the Americans need, now that they are likely to invade countries
all over the world, is not American or German style tanks but Russian
ones.
The US German and other NATO MBTs are essentially defensive tanks;
heavily armored they trade mobility for the following.
You have never seen an M1 move across the countryside, eh?
Sure, in certain conditions of flat and solid ground it is not at a
big disadvantage.
However it will have problems in
1 Mud/Quagmire
2 Crossing bridges
3 A C17 and certainly a C5 Galaxy could carry two maybe three 42 ton
tanks.
1 NATO tanks are around 55-60 tons while Russian tanks are 42-45 tons.
And the NATO tanks actually tend to win every time they engage Russian
equipment, which while lighter (or maybe because of that) *does* exhibit the
ability to apparently acheive near low-earth-orbit with their turrets when
struck by western munitions...but I am not sure that is much to brag about.
That has everyting to do with the fact that frontline american tanks
are engaging second rate export version of the old soviet blok tanks
firing inferior munitions.
The same fire control system seen on a Leo or Abrams can fit into a
Russian style tank
2 NATO tanks have typically 5 crew while Russian tanks use an Auto
Loader to reduce crew to 3 (this reduces the rate of fire and reduces
the number of 'eyes')
What US tank has a crew of five? The M1 series has four crewmemebers--as did
the earlier M60 series vehicles. You have to go a LONG way back in history
to find a five-man crew in a US tank. The Russian autoloader has a rather
dismal record (unless you count its tendancy to periodically try to "load"
the gunner into the breach... :-)
The auto loaders have been improved an can functiopn without returning
to the zero elevation position. either way the safet deficiency was
more a matter of Indifference to guarding and interlocking the loader.
3 NATO tanks are taller and can depress their guns further; they were
designed for defensive operations behind parapets with only their
turret showing thus the greater depression.
Behind "parapets"?! You have any idea what a sabot round does when it
encounters an earthen "parapet"? It goes right through it, and then through
the tank behind it. What you are searching for here is the
hull-down/turret-down defilade position--not a "parapet" (which we used to
refer to as "MILES piles", becuase the only thing they would defeat was the
laser enagement training system, not real warrounds).
Either way the superior depression on NATO tanks was a defensive
positioning tactic.
4 Russian tanks are smaller targets. Because the are smaller they
need less Armor.
They seem to make plenty-big targets, as evidenced by their performance
against western tanks in various Middle Eastern engagements.
Given the same standard of composit armour, the same quality of fire
control and the same quality of barrel they would probably do better.
Given the US's need to operate offensive wars they need offensive
style tanks that are lighter, more mobile and require less fuel.
Or we could just proceed with FCS...
They need Russian style tanks.
That is the absolute *last* model I'd use. We want systems that can not only
be delivered to the TO, but can *win* when they get there--Russian systems
seem to be a bit lacking in that last requirement.
I said 'russian style' tanks by that i mean with westenised barrels,
Fire Control and Multilayer armour.
Brooks
Old May 3rd 04, 12:51 AM
Yeff
It's been a long time since I last read "King of the Killing Field", but
didn't the Army specifically *want* four crew members? Something about two
of them being able to repair a track while one other was dismounted as a
guard while the other stayed with the tank to man the radios and a machine
gun?
-Jeff B.
yeff at erols dot com
Old May 3rd 04, 12:53 AM
The Enlightenment
"Thomas J. Paladino Jr." wrote in message ...
"Scott Ferrin" wrote in message
On Sun, 2 May 2004 12:09:06 -0400, "Kevin Brooks"
om...
years running.
Rob
help hill climbing.
ones.
He's talking out of his ass. "Trading mobility. . ."? Maybe they
can't be towed by a heard of donkeys in a bind but under it's own
power it'll out drive the typical Russian POS any day of the week.
Maybe what he means by 'mobility' is it's airlift/sealift potential.
Quite, An Abrams is useless if it isn't there or is there is to small
a number or is consuming so much fuel and logistical resources you
can;t keep your forces supplied.
Weight will also effect cross country abiltiy and bridge crossing
abillity.
SNIP
One of the major arguments for 'transformation' to the lighter FCS forces is
that they will be able to deploy much faster than our current heavy armor. I
have to say that I am *highly* suspicious of trading our battle-proven heavy
armor for a set of 25-ton vehicles that admittedly will not be anywhere near
as survivable in direct combat as the M1, but will depend entirely on
high-technology and advanced tactics for survivability.
A Russian style tanks gets its ligher weight by being smaller. I
believe armour thickness should be about the same.
The light weight armour the US is trying to develop is I believe much
lighter again. I think a Russian style tank makes more sense since
these are more mobile than the defensive style NATO tanks.
It seems to me that the ultra light weiigh armour the US is working on
will be effective against HEAT style rounds but not so effectice
against kinetic rounds. I would expect US forces would have such air
superiority that en****ering an enemy MBT would be a rare event.
I don't care how
high-tech they are; computers crash, networks go down, and tactics can be
easily flawed or otherwise screwed up in any number of ways. We should
always maintain a dominant, overmatching force to fall back on.
The eagerness to rid our ground forces of this heavy armor is very
disconcerting to me. We should be developing a heavy follow-on to the M1 to
operate within the FCS. Perhaps it won't need to be produced in the same
numbers as the M1, but we should *always* maintain a heavy armor capability,
period. If deployment speed is such a concern (which it is), we should
absolutely develop more advanced heavy airlift and high-speed sealift as
well, so these heavy units can be deployed as quickly as the rest of the FCS
forces; there are several on the drawing boards.
when
about.
did
history
"load"
through
to
need less Armor.
Yeah the side that wins tank engagements 99.999% of the time needs to
trade it's tanks for the losings side's model. I think you need to
change your handle because "enlightened" you ain't.
Old May 3rd 04, 01:12 AM
Paul J. Adam
In message , The
Enlightenment writes
tanks.
How much fuel, ammunition, spare parts et cetera come with them? Tanks
are logistic-hungry beasts and need more support than most imagine.
Flying in a tank or three isn't that much help if you end up with an
immobile pillbox two days later.
Russian style tank
Sure, but that doesn't fix the catastrophic ammunition explosion
problem, or the hideously cramped interiors.
positioning tactic.
And a bloody useful one.
So, you're talking about "Soviet tanks blessed with all the advantages
of Western technology"? Except that the crews would mutiny if you tried
to use Western professionals...
(always the problem when you try to base your solution around technology
rather than people)
Why? Still not designed for survivability or crew endurance, which are
key factors for how the West fights.
When you have to kill a man, it costs nothing to be polite.
W S Churchill
Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk
Old May 3rd 04, 04:46 AM
Kevin Brooks
om...
om...
years running.
Rob
help hill climbing.
ones.
big disadvantage.
LOL! You need to visit NTC--it ain't all flat, and it ain't all "solid". Of
course, neither was the countryside that the US moved through not once, but
twice against Mr. Hussein's forces. Where did you get this strange idea that
the M1 can only operate effectively in flat/open/solid terrain?
1 Mud/Quagmire
Most tanks do. That said, the M1's handled the Iraqi desert, with its salt
ponds in some areas, quite well.
2 Crossing bridges
Which is why our bridges have to have, generally, a Class 70T/105W rating.
Which they do. It would be nice to have even better tactical bridge systems
available, but other than HDSB, we seem to be saddled with what we now have,
which is sufficient to handle the M1. Remember, your bridges have to be able
to handle the maximum load vehicle, and newsflash--the M1A1 ain't it.
Probably the worst would be a HET with a M1A1, but that is not a required
laod capability for tactical bridges; their worst would more likely be heavy
tractor/trailer combo (point loads generally being worse than the spread
loads of the tracked vehicles, not to mention less forgiving of approach
conditions).
tanks.
Which are of little value if they quickly die when you get them there, as
russian equipment has been proven to do. If the need is for heavy armor, go
with the best, which would be something in the M1A2/Challenger class. If you
are going somewhere where you don't absolutely have to have "the best", and
air transportability rules, go with the LAV or Stryker.
when
about.
Balderdash. That has to do with the western systems being plain ol' superior
products. The Russians cut a few corners in building the T-54 through T-72
classes, and their performance in combat has *always* been substandard
compared to western systems, from the M48A5 and Centurion forward. Less
capable fire control and target detection equipment (that means less weight,
doncha know?), inefficient autoloaders in later models, poor design of the
turret ring area (*pop* goes the weasel!), etc., ad nauseum.
Russian style tank
And weighs more, not to mention the fact that the statement is not quite
true--if it were, all of those nations looking at the time consuming and
costly retrofit of western subsystems to their old Soviet era tanks 9and in
some cases post-Soviet tanks) would snap their fingers and it would be done.
There is not a lot of spare *space* inside those wonderfully smaller Russian
tanks of your's, right?
did
history
rather
"load"
Again, what western tanks have five man crews? Any? Come on, you rolled out
your tongue--now either retract it, or let it get walked on, with
golfspikes.
And the autoloaders still suck, the last I read--which is maybe why none of
the western (or far eastern) designs have adopted such a system.
through
to
positioning tactic.
"I have no earthly idea what i am talking about, but I am right anyway..."?
If the height of a tank was so important to us USians, why did we spend so
much time digging *turret* (not just hull) defilade positions for them at
NTC? Yes, ours are taller--and more roomy inside, making for greater crew
comfort, and in the long run improved crew performance. How many glowing
reports of crew comfort have you seen regarding russian tank designs?
need less Armor.
That is like sayin, "Hey, if they were the same as western tank designs,
they'd do better!" Duh.
only
systems
So you want to take a lightweight, small vehicle, cram a bit more in the
line of subsystems into it, increase the armor effectiveness, change it to a
new gun (and ammo, meaning you'd have to rework the ammo storage system),
etc.? Yeah, riiight...Thank goodness you are NOT involved in the procurement
process for US armored systems--the tankers would likely string you up.
Brooks
Brooks
Old May 3rd 04, 07:34 AM
Eunometic
"Tex Houston" wrote in message ...
om...
years
running.
Rob
Let me know the next time that either source gains some actual combat
experience with those parade-ground-wonder-weapons, OK? Till then,
preaching
its unsurmounted superiority is a bit premature...
Brooks
What is this fascination (obsession?) with tanks in a newsgroup labeled
rec.aviation.military?
Two words:
airlift logistics.
Tex
Old May 3rd 04, 07:43 PM
Alan Minyard
om...
years
running.
Rob
preaching
Brooks
Tex
It is our little nazi Rob ranting about aryan (read German) superiority in all
fields, with the rest of the world just tagging along.
Al Minyard
Old May 3rd 04, 09:17 PM
robert arndt
You Abrams fanboys really need to look beyond 30yr old obsolete Iraqi junk
that hasn't been serviced since 1991 for your comparisons.
True. It would be amazing to see a Leopard 2A6 face off against the
current M-1A2 upgrade. Of course the new German L55 main gun with DM
53 ammo would pick it right off IMO. The Germans have a range of
studies and prototypes being tested for their future MBT. Among those
are the DB wheeled 8x8 50 ton tank, the EGS demonstrator built with
Merkava-type architecture but more advanced German techology (stealth,
EM armor, anti-helo/aircraft missiles, mine detection and destruction
equipment, protection from top-attack missiles, engine up front with
the exhaust cold-filtered below the vehicle, and reduced crew to 3 men
and probably the 140mm main gun tested on the Leopard 2), the RakJpz
Panther crane-tank, and small purely autonomous killing robotic AFVs.
And you might look to what is actually IN service for your
comparisons. Face it. Russian tanks are junk.
Not so. Both the Ukraine and Russia are working on newer, deadlier
MBTs that have weapon systems and defensives aids that have no Western
equivalent like dazzlers, Arena defense system, active armor,
anti-helo missiles, 152mm main gun that can also fire ATGWs, higher-hp
gas turbines,etc... but still keeping the weight down to 45-50 tons,
crew of 3, autoloader. Check out their T-80UM-2, Ukrainian T-84
upgrades, T-95, and Black Eagle. They definately have the technology
but lack funding. Besides, try fighting Russia on their territory with
the M-1. I don't care if the people had Molotov cocktails alone- they
would beat US the same way they beat Germany. An elephant can kill
thousands of tiny ants with its bulk but eventually the ants will
swarm over the elephant and strip it alive. So far the M-1 is good at
attacking puny Third World nations with rusting import FSU MBT's
manned by conscript soldiers that live like animals. Some
comparison...
The same report that got this thread started had the T-80 and T-90 as
WAY down the list. IIRC it went something like
Leopard II A6
M1A2
Merkava IV
Challanger II
South Korean Type 88 K1A1 "mini M-1"
Japanese Type 90
*then* the two Russian (or Russian/Ukraine) tanks. Come to think of
it, even the LeClerc might be ahead of them.
(BTW is someone has a link to that report I'd appreciate it. I can't
seem to find it)
No, the order was:
Leopard 2A6EX
M1A2
Type 90
Merkava 4
Challenger 2
LeClerc
From Forecast Internation report 2002/3.
Rob
Old May 3rd 04, 10:53 PM
Scott Ferrin
Of course, you'd be wrong. The M-1 doesn't need the longer gun
because it's got much better ammo available to it than the DM53
(M829E3) not to much the much better armor of the M-1A2.
Whoopie. Which part of "working on" equates to "in service"? The US
is working on EM guns, laser self-defenses etc. And those tanks you
mention are the ones that suck according to the paper that ranked the
Leopard II A6 number 1. Black Eagle and T-84 were specifically
mentioned.
Well, you keep living in your fantasy world.
Fortunately we're not talking about elephants and ants but tanks.
comparison...
Some comparison. . . .?? And??
Leopard II A6
M1A2
Merkava IV
Challanger II
Japanese Type 90
seem to find it)
No, the order was:
Leopard 2A6EX
M1A2
Type 90
Merkava 4
Challenger 2
LeClerc
Rob
So where do your vaunted Russian tanks fall? That Type 90 they're
talking about is the JAPANESE tank. I'm willing to be proved wrong
though. Just send me the link to that report if you would.
