wing tape
Old April 29th 14, 11:47 AM posted to rec.aviation.soaring
Colin Roney
Default wing tape
Where and what product is the best white wing tape to be bought?
Old April 29th 14, 12:56 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default wing tape
I use Maplins electrical white insulation tape. At 19mm x 33m long its
wide enough if put on with care and 7.54 p/m and the shop is on my way to
the airfield.
I notice that Severn Valley Sailplanes also sell 19mm x 33m wing tape at
6.79 p/m but of course there will be P&P added. What's the betting its
the same stuff as Maplins sell? SVS also supply tape in 25mm and 38mm
widths. Maplins only do 19mm tape.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old April 29th 14, 02:12 PM posted to rec.aviation.soaring
Chris Rollings[_2_]
Default wing tape
I wonder how long before EASA require us to use only wing tape that comes
with an EASA Form 1?
the airfield.
org |
Old April 29th 14, 02:33 PM posted to rec.aviation.soaring
John Carlyle
Default wing tape
I use Scotch 3M 35 White Vinyl Electrical Tape at $3 per roll, which I think is the US equivalent to what Martin described.
-John, Q3
the airfield.
Old April 29th 14, 05:30 PM
jherzog jherzog is offline
Junior Member
First recorded activity by AviationBanter: Oct 2011
It's pricey, but I really like Bowlus Maxi, sold by Cumulus Soaring:
http://www.cumulus-soaring.com/bowlus.htm
It adheres well and is stretchy enough to smoothly follow curves and make it easy to apply.
Old April 29th 14, 06:48 PM posted to rec.aviation.soaring
Default wing tape
comes with an EASA Form 1?
Just hope they don't read RAS and in the meantime be afraid, be very
afraid....
org |
Old April 30th 14, 09:36 AM posted to rec.aviation.soaring
Default wing tape
3M 483 - but it's horrifically expensive. Wings And Wheels dropped it for this reason so I had to get it from ULINE. I've tried all the others but I like 483 best. I feel like I'm setting fire to $5 bills whenever I use it though.
Old May 1st 14, 01:57 AM posted to rec.aviation.soaring
Dan Marotta
Default wing tape
I can put up with tape that's a bit less stretchy for a difference of $10+
per roll. What's it take, 10 minutes of your soaring day to tape your ship?
though.
Old May 1st 14, 02:40 AM posted to rec.aviation.soaring
Mark628CA
Default wing tape
I find it laughable when I see somebody using cheap crappy tape on their $60,000+ glider after they drive up in the $40,000+ SUV. What are you saving? Maybe a nickel a flight? Oh, and don't forget the real misers who SAVE said crappy tape to use the next day, with the additional benefit of the dirt that collects on the sticky side.
I prefer the Bowlus Maxi-Tape. It is by far the best stuff out there, and I saved my money by building a $75,000 hangar. Since I only have to tape up two or three times a year, I expect my investment to pay off about the time the Sun burns out.
Old May 1st 14, 03:37 AM posted to rec.aviation.soaring
Tony[_5_]
Default wing tape
I like bright red 3M electrical tape.
Wing Tape Craig[_2_] Soaring 0 May 5th 11 05:09 PM
Books on Military Rotary Wing to Civilian Fixed Wing Transition? Greg Copeland Piloting 5 May 2nd 07 03:23 AM
Wing Tape - Does Thickness Affect Performance? ContestID67 Soaring 87 February 1st 07 03:24 PM
Wing Tape - Does Thickness Affect Performance? Charles McLaurin Soaring 2 January 30th 07 06:00 PM
Mylar tape wing seals - effect on wing performance Simon Waddell Soaring 8 January 1st 04 03:46 PM
