Van wrote an article in which he states "RV's are not well
suited for [snap rolls] because high G forces are needed to produce a brisk snap roll." When I do snap rolls in my Aerobat (perhaps that's an oxymoron) I do an accelerated stall at 75kts which is well below my Va of 105 kts so there is no possibility of over stressing the aircraft. If the Va for the RV-6 is 120kts and I do an accelerated stall at 80 kts, the max load on the aircraft should only be 2.7 G's. Obviously this is well below the 6 G limit so what am I missing? |
You don't really put much of a g load on the airplane in that sense but you
put some strong bending moments on the airframe which wouldn't show up on your g-meter. Snap rolls are easily controlled but could be classed as a violent maneuver. One Pitts pilot I talked to complained that his airplane seemed to take a semi-permanent "set" after snap rolls, assuming a slight left roll after left snaps and a slight right roll after right snaps. I also noticed that the paint on my Pitts started to crack on the tail only after I started learning how to do snaps. If the fuselage isn't stressed for those bending and torsional loads, it probably isn't a good idea to snap it. Which is a shame because snaps are a blast! Shawn "Ted Timmons" wrote in message ... Van wrote an article in which he states "RV's are not well suited for [snap rolls] because high G forces are needed to produce a brisk snap roll." When I do snap rolls in my Aerobat (perhaps that's an oxymoron) I do an accelerated stall at 75kts which is well below my Va of 105 kts so there is no possibility of over stressing the aircraft. If the Va for the RV-6 is 120kts and I do an accelerated stall at 80 kts, the max load on the aircraft should only be 2.7 G's. Obviously this is well below the 6 G limit so what am I missing? |
| Thread Tools | |
| Display Modes | |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | January 1st 05 08:29 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | May 1st 04 09:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | April 1st 04 09:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | March 1st 04 08:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | December 1st 03 07:27 AM |
