LAK-12 polar for SN10B
Old May 7th 14, 05:18 AM posted to rec.aviation.soaring
GE
Default LAK-12 polar for SN10B
Hello,
Anyone have a good set of points to indoctrinate an SN10B on the ways of a LAK-12?
I cannot quite get the numbers I need from the LAK owner's manual, and the polar is not included in the canned bunch that comes with the ILEC. Nimbus II is close, I suppose, but I'd like to get it right.
Many thanks,
-GE
Old May 7th 14, 02:48 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
If you are a member of SSA, go to www.ssa.org. Under "The SSA", find "Soaring Magazine", then "Johnson Reports". Select the link to the flight test report. You will have to log in to see it. Should have everything you need to know.
Happy Flying!
Steve
Old May 14th 14, 12:23 AM posted to rec.aviation.soaring
Thank you, Steve, I will try that.
Regards,
-GE
Happy Flying!
Steve
Old May 14th 14, 05:00 AM posted to rec.aviation.soaring
Robert M
You should be aware that the designer of the LAK-12 read the Johson report and strongly disputed the 50-1 L/D Johnson claimed for the glider. Klemas Juocas the head of the design team at Sportine Aviacija did not believe the LAK-12 was better than 48-1.
Robert Mudd
Moriarty, N.M.
Regards,
-GE
Happy Flying!
Steve
For Sale: SN10B Britton Soaring 5 November 2nd 12 03:32 PM
Looking for used SN10B Edit yankeegolf Soaring 0 March 15th 10 12:25 PM
Looking for used SN10B yankeegolf Soaring 0 March 15th 10 12:21 PM
SN10B for sale Dick[_3_] Soaring 0 June 6th 09 09:05 PM
SN10B Wanted fulda304 Soaring 1 January 28th 08 02:51 PM
