Asw20 vs Discus
Old May 11th 14, 07:44 PM posted to rec.aviation.soaring
rhoan.birch@googlemail.com
Default Asw20 vs Discus
Hi,
I am looking for any advice as to which had a higher performance out of these two gliders. I realise it will be pretty similar as they have the same handicap, but anything you can tell me such as:
Strong vs weak conditions?
How well does each carry water?
Anything else you can offer.
I realise they are hard to compare as they are from different classes.
Thanks
RB
Old May 11th 14, 09:42 PM posted to rec.aviation.soaring
Al McNamara[_2_]
I think it's a really interesting question, made more complex by the
various versions of the ASW 20. The UK handicaps suggest the b,c and 16.6m
versions are better than the Discus (a,b, c or cs) and I think in terms of
pure performance that is probably right.
The main difference for me is that the Discus is a generation newer. It
has self connecting controls, achieves similar performance without the
complexity of flaps, is easier to get water into and probably easier to fly
for a less experienced pilot. Older ASW20's will probably come with
problems (e.g. water systems not working properly, poor gel) and might need
a bit of work to get to the same standard.
In Europe, a 20 'a' (same handicap as Discus) will probably cost
significantly less than a Discus, and the later versions (probably better
performance) about the same.
Overall, I find myself wondering which I would choose. I think with the
time to find the right 20, or flexibility to refurbish one, that is
probably the better option, but a close call and a decision which might not
be the same for everyone.
At 18:44 11 May 2014, wrote:
Hi,
Thanks
RB
Old May 12th 14, 01:28 PM posted to rec.aviation.soaring
Al McNamara
Reply re-posted without the typo's:
The main difference for me is that the Discus is a generation newer. It has
time to find the right 20, or flexibility to refurbish one, that the 20 is
Hi,
Thanks
RB
Old May 13th 14, 09:42 AM posted to rec.aviation.soaring
krasw
On Sunday, 11 May 2014 21:44:07 UTC+3, wrote:
Hi,
Thanks
RB
I've flown over 500 hrs both (Discus b/WL and ASW20 "A"). Performance is pretty much the same. If you fly a lot without water ballast, ASW goes better in strong conditions. Discus can be ballasted to 70kg more so that evens it out (fully ballasted ASW20 climbs better, though). Both suffer from rain and bugs. ASW is a bit more complex because of flaps, but it is nicer to fly and accelerates better, plus you can land it in tighter spot. With Discus you have to get used to thermalling with controls crossed (it requires counter-aileron when turning). Directional stability is better in Discus (more so with winglets), with ASW you have to be more sensitive with rudder. Both have roomy cockpits, back rest can be removed for long pilots.
Discus is much easier to rig, ASW has heavier wings and manual connections. *This is the only part where you notice the Discus is newer generation*. Original gelcoat is probably long gone in both of them. You can put jet engine to ASW, but on the other hand buy a used Turbo Discus.
I have had water system issues both with Discus (those leaking S-H valves....) and ASW (leaking bag). Minor things.
Both are very good gliders, but ASW gives you same performance little bit cheaper.
Old May 13th 14, 11:13 AM posted to rec.aviation.soaring
Chris Rollings[_2_]
Hi,
=20
=20
=20
t=
same=
=20
=20
=20
=20
=20
=20
=20
=20
=20
Thanks
=20
RB
pr=
better=
i=
rain
fl=
Discus=
cou=
(more=
Bot=
connections.=
O=
engi=
valves..=
c=
heaper.
Agree with all of the above, based on a fair amount of experience in both.
the only thing I would add is that, at more or less equal wing-loadings,
the ASW20 starts to do considerably better as you get above 80 - 90 knots.
Old May 13th 14, 04:02 PM posted to rec.aviation.soaring
JS
As previously stated plus:
It's likely a Discus has a better trailer than a 20 "A" or most B, for example Cobra with single-piece Al floor and captive 4-wheel dollies.
The 20C is new enough to have the same.
But my vote is always with flaps, as Chris points out re the high end of the polar.
Old May 14th 14, 02:11 PM posted to rec.aviation.soaring
rlovinggood
One other "plus" in the column for the Discus over the 20: It won't self-immolate when the canopy is open and positioned "just right" to catch the sun and focus the beam of light on the glare shield...
Ray
PS: If anyone has a Discus or 20 they would like to toss out, I'll be glad to come and tote it away for you!
Old May 15th 14, 04:52 PM posted to rec.aviation.soaring
On Sunday, 11 May 2014 19:44:07 UTC+1, wrote:
Hi,
Thanks
RB
Thanks for the replies, very helpful!
ASW20 and Discus in Club Class next year. Nick Olson Soaring 8 October 20th 07 10:58 PM
ASW20 and Discus in Club Class next year. Nick Olson Soaring 5 October 19th 07 04:26 PM
ASW20 and Discus in Club Class next year. Nick Olson Soaring 0 October 18th 07 12:59 PM
Discus CS and Duo Discus Wing Inspections Nolaminar Soaring 0 October 24th 03 01:15 AM
[LBA] Schempp-Hirth - Discus bT - Discus Frederic FUCHS Soaring 0 September 17th 03 08:42 AM
