1-34 Fuselage Drain Holes
Old May 12th 14, 04:09 PM posted to rec.aviation.soaring
vontresc
Default 1-34 Fuselage Drain Holes
Our club 1-34 lives outside, and during heavy rains will accumulate some water in the fuselage. There appear to be no drain holes in the bottom of the fuselage. Is there supposed to be a drain in there?
If not is there an approved method of adding these?
Peter
Old May 12th 14, 06:20 PM posted to rec.aviation.soaring
Peter
Using a step drill, create about 1/4 diameter drain hole in front of bulkhead where water collects. Do this off center line so as to not affect lap joint.
I doubt your inspector will have a concern about this. Ours didn't.
UH
Old May 12th 14, 06:48 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Or, behind if the water is moving forward to get to the bulkhead! I have seen gliders with drain holes in the fabric always to the right of the rib. I guess this was a "left wing low" glider!
But, yes, to Hank's advice. Add a small hole where appropriate. And quarter inch sounds about right to me, too.
Old May 12th 14, 07:33 PM posted to rec.aviation.soaring
Papa3[_2_]
And FWIW, make sure that the "maintenance guy/gal" for that ship keeps them clean. A number of our club gliders have drain holes in various places that get plugged up pretty regularly. Spoiler boxes on a particular glass two place leap to mind.
Old May 12th 14, 09:04 PM posted to rec.aviation.soaring
vontresc
Sounds like I'll need to talk to our A&P to put some carefully placed drain holes in there. Talked to Kyle at K&L when I ordered the replacement release return spring, and he said that they have no "official" method of doing this. So I guess it's a mod IAW AC43.13 then.
Peter
Curtis oil quick drain Mike Noel Owning 2 August 26th 09 11:04 PM
Drain holes under Schleicher seatpans Tuno Soaring 15 January 12th 09 08:50 PM
Limiting battery drain by using what? joesimmers Soaring 2 July 23rd 08 02:31 PM
Gordon's Pics : the B-24 wreckage bullet holes B24-fatal-upside-down-rear-fuselage Dave Kearton Aviation Photos 0 April 21st 07 11:49 PM
When Poorboys drill holes ...was: Drilling holes in steel tubing wright1902glider Home Built 4 November 4th 05 01:19 AM
