Oudie 2 + CAI 302 Utility
Old May 15th 14, 02:07 PM posted to rec.aviation.soaring
Nick Kennedy
Default Oudie 2 + CAI 302 Utility
Has anyone successfully loaded the 302 utility program on to a Oudie and make it function?
I would be grateful for information on how to do this.
Old May 15th 14, 02:26 PM posted to rec.aviation.soaring
Echo
Are you referring to Connect Me that comes preloaded?
Old May 15th 14, 04:34 PM posted to rec.aviation.soaring
Nick Kennedy
No
To adjust the 302 internal settings, pilot name, polar etc etc
you need to talk to the 302 with the CAI Utility software.
I've communicated with Naviter about adding the 302 Utility software to the
Oudie.
I don't know enough make it work; I tried to do it, without success.
Naviter claims it is possible..
So my question is;
Has anyone attached the 302 Utility to a Oudie?
Nick Kennedy
T
Old May 15th 14, 11:00 PM posted to rec.aviation.soaring
I have used Connect Me on the Oudie to do all my communication with my 302.
Old May 16th 14, 04:35 AM posted to rec.aviation.soaring
Paul Remde
Hi Nick,
I tried. It didn't work. It was quite a while ago, so I don't remember if
it didn't run at all (I think that was it) or didn't communicate.
I recommend using ConnectMe for flight log downloads and using SeeYou Mobile
for task declaration uploads. For editing the pilot data and polar data you
may need to use a PC or iPAQ - but that data is normally edited very rarely.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"Nick Kennedy" wrote in message
make it function?
Old May 16th 14, 05:08 PM posted to rec.aviation.soaring
Nick Kennedy
At 03:35 16 May 2014, Paul Remde wrote:
Hi Paul
Thanks for the reply.
I am using Connect me to up load waypoints and tasks to the 302/303. That
is working OK.
And I am using a Ipaq with a cable to use the 302 utility but it is a pain
to do that.
I'll post a note to Andjei [ sp? ] at Naviter again and see if they are up
to into putting a update on the list to do for the Oudie to allow other
programs to run on the Oudie
Regards
Nick
Hi Nick,
if
Mobile
you
rarely.
Best Regards,
Paul Remde
make it function?
Old May 16th 14, 09:26 PM posted to rec.aviation.soaring
Paul Remde
Hi Nick,
I don't think there is anything Naviter can do to get the 300 Utility
compiled to run on the Oudie's processor. Cambridge would need to do that.
That's not going to happen.
Therefore I recommend sending a friendly note to Naviter asking them to make
it possible to edit the parameters below on the 302:
- Pilot Name
- Logging Interval
- Polar Data
- cruise vario type
- etc.
SeeYou Mobile offers similar functionality for the V7 and LX1600.
However, since the 302 product line is not currently in production, I can't
imagine they will be too motivated to put a lot of work into supporting it.
But it doesn't hurt to ask.
Best Regards,
Paul Remde
Hi Paul
is working OK.
to do that.
Regards
Nick
Hi Nick,
if
Mobile
you
rarely.
Best Regards,
Paul Remde
make it function?
Old May 17th 14, 03:39 AM posted to rec.aviation.soaring
Richard[_9_]
Nick,
I tried on the Oudie with no success. I thought is might just require a couple of .dlls.
The CAI 302 Utility runs on the Ultimate Le and the Ultimate Le57, It requires an AutoCopy folder where gx.dll and the aygshell.dll are copied into the ram windows folder at startup. But no window folder in the Oudie.
Richard
www.craggyaero.com
Old May 20th 14, 06:12 AM posted to rec.aviation.soaring
Taylor Andy C
Hi,
On a slight tangent, is there a way to successfully declare a task into a
cai302
using an Oudie? I can upload the task ok using the task function on the
Oudie
but when I download the IGC file into See You after the flight it states
that no
task could be found.
Andy
At 02:39 17 May 2014, Richard wrote:
Nick,
couple of .dlls.
Oudie.
Richard
www.craggyaero.com
Old May 20th 14, 08:22 PM posted to rec.aviation.soaring
Andy Taylor
Hi
On a slight tangent, does anyone know how to get a task uploaded
successfully to a CAI302 using an Oudie? I can upload it OK using the
upload function but when I download the IGC file after the flight and view
it on See You, there is no task listed.
Andy
Nick,
couple of .dlls.
Oudie.
Richard
www.craggyaero.com
Cambridge 302 Utility app [email protected] Soaring 1 June 7th 12 03:59 PM
Cambridge Utility software Bob 7U Soaring 4 September 5th 11 06:18 PM
Simon Frasers utility Old Brew[_2_] Aviation Photos 0 May 13th 09 01:57 PM
Utility program for PDA Oscar Goudriaan Soaring 4 April 10th 08 07:11 PM
normal/utility category AINut Home Built 5 January 21st 05 06:53 AM
