BMapper runtime error 75?
Old May 18th 14, 12:03 PM posted to rec.aviation.soaring
Default BMapper runtime error 75?
Hi,
I have recently upgraded to a Win7 64 bit laptop, and I'm having some trouble with Dale Kramer's wonderful BMapper program. When I try to download Dr.. Jack data for a site, I get a few of the data points, and then BMapper crashes with a 'Run-time error 75 - Path/file access error"
Has anyone else seen this and/or have a fix for the problem?
TIA,
Frank (TA)
Old May 18th 14, 01:17 PM posted to rec.aviation.soaring
No problems on my Win7 64 bit system.
Where in the file system did you install the SW? Could it be that you've installed to a protected location in your directory structure? Mine is installed in the default C:\BMapper folder and works fine. If you forced the install to C:\Program Files (x86) it's probably a permissions issue.
Robert
On Sunday, May 18, 2014 6:03:43 AM UTC-5, wrote:
Hi,
I have recently upgraded to a Win7 64 bit laptop, and I'm having some trouble with Dale Kramer's wonderful BMapper program. When I try to download Dr. Jack data for a site, I get a few of the data points, and then BMapper crashes with a 'Run-time error 75 - Path/file access error"
TIA,
Frank (TA)
Old May 18th 14, 05:51 PM
Brad Alston Brad Alston is offline
Member
First recorded activity by AviationBanter: Jun 2011
Quote:
Try right-clicking the .exe file and select "Run as Administrator".
Brad.
Old May 19th 14, 02:55 AM posted to rec.aviation.soaring
Brad.
Brad Alston
Brad,
Good idea, but it didn't work :-(. Interestingly, it appears that BMapper will get one or even several of the Dr. Jack files before the error appears.. I've seen it get six or seven, or just one or two. There doesn't seem to be any rhyme or reason to it. Is it possible I have a Dr. Jack problem instead of a BMapper problem?
Frank (TA)
Old May 19th 14, 02:56 AM posted to rec.aviation.soaring
Nice thought, but it's installed in C:\BMapper, just as it was on my XP system.
Frank (TA)
Robert
Hi,
TIA,
Frank (TA)
Old May 19th 14, 03:38 AM posted to rec.aviation.soaring
Frank (TA)
Robert
Hi,
TIA,
Frank (TA)
Another longshot - you might try going to Microsoft and downloading the latest visual C runtime library. I've seen instances where old libraries will still allow the .exe to run but throw very strange errors.
BMapper/BlipMap down? [email protected] Soaring 3 March 2nd 14 03:34 PM
BMapper back - YAY!! [email protected] Soaring 1 May 27th 12 08:16 PM
Bmapper map Robert Fidler[_2_] Soaring 0 May 4th 10 05:30 PM
BMapper sierra Soaring 1 May 2nd 10 05:09 PM
Bmapper Map Capture Dave White Soaring 1 April 23rd 10 01:34 AM
