Sale - Used PowerFLARM Core v1
This is a great deal on a slightly used PowerFLARM Core v1. It looks almost perfectly new, other than the scratches on the mounting feet. Version 1 Core units are exactly the same as the current version 2 PowerFLARM Core units with the exception that the Audio Output hardware is not built-in. The Audio Output hardware is only used to send beeps to an aviation headset when the unit is used in a motorglider. Glider pilots would not need the Audio Output because they will hear the traffic warnings from their remote FLARM display or PDA. This unit comes complete with all new accessories: - PowerFLARM Core Manual - PowerFLARM Tips document - PowerFLARM Antenna Mounting Tips Application Note - GPS antenna - FLARM Dipole Antenna - ADS-B Dipole Antenna - DB-9 cable for power connection - USB extension cable The accessories are new because the owner needed the Audio Output capabilities for use in his motorglider. I sent him the new version 2 PowerFLARM Core but kept the accessories for use with this version 1 Core unit. The latest PowerFLARM Core firmware version 3.4 has been installed. I will also create and load a custom configuration file for you before shipment. New PowerFLARM Core units sell for $1460. This unit has the optional IGC Enable ($98), ENL Enable ($147), and FLARM B Antenna Enable ($54) keys entered. The total value is $1759. This system is available for $1395. A logger altimeter calibration is available as a $75 option. A remote FLARM display is not included. Several options are available. The most popular option is the LXNAV FlarmView for $280. Photos of this particular unit are available he https://www.flickr.com/photos/remde/...7644500810257/ Best Regards, Paul Remde Cumulus Soaring, Inc. |
The used PowerFLARM Core has been sold.
Best Regards, Paul Remde "Paul Remde" wrote in message ... Sale - Used PowerFLARM Core v1 This is a great deal on a slightly used PowerFLARM Core v1. It looks almost perfectly new, other than the scratches on the mounting feet. Version 1 Core units are exactly the same as the current version 2 PowerFLARM Core units with the exception that the Audio Output hardware is not built-in. The Audio Output hardware is only used to send beeps to an aviation headset when the unit is used in a motorglider. Glider pilots would not need the Audio Output because they will hear the traffic warnings from their remote FLARM display or PDA. This unit comes complete with all new accessories: - PowerFLARM Core Manual - PowerFLARM Tips document - PowerFLARM Antenna Mounting Tips Application Note - GPS antenna - FLARM Dipole Antenna - ADS-B Dipole Antenna - DB-9 cable for power connection - USB extension cable The accessories are new because the owner needed the Audio Output capabilities for use in his motorglider. I sent him the new version 2 PowerFLARM Core but kept the accessories for use with this version 1 Core unit. The latest PowerFLARM Core firmware version 3.4 has been installed. I will also create and load a custom configuration file for you before shipment. New PowerFLARM Core units sell for $1460. This unit has the optional IGC Enable ($98), ENL Enable ($147), and FLARM B Antenna Enable ($54) keys entered. The total value is $1759. This system is available for $1395. A logger altimeter calibration is available as a $75 option. A remote FLARM display is not included. Several options are available. The most popular option is the LXNAV FlarmView for $280. Photos of this particular unit are available he https://www.flickr.com/photos/remde/...7644500810257/ Best Regards, Paul Remde Cumulus Soaring, Inc. |
Oudie2 - V7 - PowerFlarm Core setup (cabling question) | ES | Soaring | 4 | March 3rd 14 12:29 AM |
Powerflarm Brick/Core ADSB Range | Sean F (F2) | Soaring | 3 | September 5th 13 03:10 PM |
PowerFLARM core external display software update | kirk.stant | Soaring | 5 | January 28th 13 08:56 PM |
powerflarm portable for sale | markmocho53@gmail.com | Soaring | 0 | October 23rd 12 03:32 PM |
For Sale PowerFLARM Portable (USA) | Andy[_1_] | Soaring | 0 | September 17th 12 12:28 AM |
