Tablet for XCSOAR
Old June 9th 14, 03:02 PM posted to rec.aviation.soaring
whanson133@gmail.com
Default Tablet for XCSOAR
I have a Galaxy Tab - (it is so old it doesn't have a version number) - well being black and sitting in the sun is heating it up and making it shut down at the exact wrong times.
I like XCSOAR and I like a 7 inch screen - I like color - any suggestions?
I am thinking to get a white new Galaxy, but maybe there is something out there that works better. I also use it to keep occupied on my commute to work (retiring is not an option)
WH
Old June 9th 14, 06:42 PM posted to rec.aviation.soaring
Dan Marotta
Hmmmmmmmm...
I use Thunderbird as my email client and, just to see, I set up an
account on news.eternal-september.org and read it on Thunderbird. I
haven't seen any junk at all and, should I, I'll just set up some filters.
Give it a try!
Dan Marotta
On 6/9/2014 10:04 AM, George Ballantyne wrote:
At 15:28 09 June 2014, Dan Marotta wrote:
My wife uses a Nexus 7 (2012 version) and it works just fine in the
Pipistrel. I used it a couple of times in my LAK-17a and it worked
just fine.
Dan Marotta
shut
suggestions?
out
WH
Same here, this side of the pond: I use a Nexus 7 also. Reasonably good
screen, clear, bright, even with sunglasses on (though we haven't seen a
lot of sun lately over here...grrr!)
Battery life is not bad for short flights too, though external power would
be a better option.
BTW, your forum is of way more interest: we're having to endure an
incredible amount of garbage on uras and urasb these days...
Regards to all.
Old June 10th 14, 12:16 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
On Mon, 09 Jun 2014 10:42:03 -0600, Dan Marotta wrote:
Hmmmmmmmm...
filters.
I'd agree. I'm also using news.eternal-september.org as my news server,
but I don't think eternal september has anything to do with it being spam-
free - thats more to do with r.a.s, which IME has considerably less spam
and fewer trolls than most newsgroups.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old June 10th 14, 06:38 AM posted to rec.aviation.soaring
Mike C
WH
Pick up a Streak 7" off Ebay. Cheap, works well and very visible in full sunlight.
Old June 10th 14, 01:27 PM posted to rec.aviation.soaring
WH
Excellent info - Thank you all it is appreciated!
WH
Old June 11th 14, 10:49 AM posted to rec.aviation.soaring
Thermal
On Wednesday, June 11, 2014 2:22:54 AM UTC-5, Ian wrote:
suggestions?
I fly with a Dell Streak 5. My colleague at work has a Google Nexus 7
tablet. I have taken both out into the sun and done a comparison of the
displays, with and without my sunglasses on. The sunlight visibility of
the Nexus 7 is as least as good, if not better than the Streak 5.
I checked this both with the sun directly behind the PDA's (shadow of
the PDA on my face), and with the sun over my shoulder onto the screens
(shadow of my head just next to the PDA's, and a range of positions in
between. I put google maps on the screen during the test as I did not
want to install XCsoar on my colleague's new toy. I do this whenever I
get a chance to test a new device in the sun.
The 7" device is a bit big for my cockpit and I am on the lookout for a
4" to 5" equivalent. I know black and white e-readers will win this test
any day, but they don't have 3G to support Skylines live tracking.
Have fun
Ian
A Galaxy Note 3 is fairly readable in daylight. at full brightness it is about 600 nits. Plus it has a barometric sensor for the software vario. and the speaker does not face away from you like many devices.
Old June 11th 14, 04:50 PM posted to rec.aviation.soaring
Thanks - I definitely need to keep my 3G connectivity - the Skylines tracker is excellent and helps keep my "crew" (my wife) calm on those long XC flights I attempt.
So right now I am going to look at Nexus and Samsung - then maybe try to make a tunnel to keep them from getting cooked by the direct sun.
Saturday my Galaxy tablet shut of twice because it was over heating - both times we really inconvenient, final glide & as I got 3 miles from my turn around point
WH
GPS, Wx for Tablet PC Wiz Piloting 4 May 24th 07 07:11 PM
New tablet PC of interest? Jon Carlson Instrument Flight Rules 5 September 10th 05 04:39 PM
New tablet PC of interest? Jon Carlson Piloting 6 September 10th 05 04:39 PM
New tablet PC of interest? Jon Carlson Products 7 September 10th 05 04:39 PM
Homebrew EFB from Tablet PC blanche cohen Instrument Flight Rules 8 August 10th 03 08:28 PM
