Schleicher Power/Solar rotary switch specs?
Old July 7th 14, 05:59 PM posted to rec.aviation.soaring
kirk.stant
Default Schleicher Power/Solar rotary switch specs?
On Friday, July 4, 2014 1:38:47 AM UTC-5, Ian wrote:
On 04/07/2014 01:08, Steve Koerner wrote:
I think there's a better way to address the problem... Each item on
your panel has an associated double pole, center off power switch.
So every item can be individually connected to one battery or the
other. When you are powering up your panel, you assigned batteries
to the various gadgets in a way that pretty much balances the load.
I have this in my panel. But instead of a whole row of switches I just
have two. The instruments are in two groups, one group on each switch.
Each group can be powered of on or the other battery or isolated completely.
Exactly the system I've been using for the last 14 years, without problems. Even when switching one of the "busses" from a weak battery to the other one, my logger/flight computer hasn't had an issue with the momentary power loss.
Simple and easy to maintain.
Kirk
66
Old July 7th 14, 07:07 PM posted to rec.aviation.soaring
On Wednesday, July 2, 2014 10:26:53 PM UTC-4, John Carlyle wrote:
I took a switch like that out of a friend's ASW-27. The 6-position switch is made by Marquardt, is model 9030.01 and is labeled 4A 30V DC.
-John, Q3
On Wednesday, July 2, 2014 9:11:17 PM UTC-4, noel.wade wrote:
Hello,
Anyone out there have specs/measurements for the rotary switch that Schleicher installs in their newer gliders, to enable switching between batteries?
(see the lower-left part of the panel in this image, as an example: http://cdn-www.airliners.net/aviatio.../2/1272229.jpg )
Thanks!
--Noel
Switch available from Bürklin GmbH & Co. KG, Grünwalder Weg 30, 82041 Oberhaching, Germany
https://www.buerklin.com/en/catalog/...2-G357200.html
The Future Of Solar Power Erry Agung Soaring 0 November 21st 09 08:03 PM
The Future Of Solar Power Erry Agung Soaring 0 October 10th 09 07:51 PM
From AOPA: Team plans global jaunt on solar power Gig 601XL Builder Piloting 6 November 16th 07 04:46 PM
Rotary engines Don Pyeatt Aviation Photos 7 May 26th 07 06:39 PM
Rotary engines in WW1 Stuart Chapman Military Aviation 27 November 14th 03 07:47 PM
