Tire Access for ASK-21
Old July 11th 14, 06:21 PM posted to rec.aviation.soaring
NG[_2_]
Default Tire Access for ASK-21
Anybody have a suggestion for how to easily get at the valve stem on an ASK-21 main wheel without dropping the shroud? Would like to make checking the pressure part of our club's daily routine, but hard to enforce if we have to unscrew the main gear fairing every time. Thanks...
Old July 11th 14, 07:04 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Marks on the tire and fairing. When they are lined up, the valve stem is pointed at the hole (you maybe have just added) in the fairing.
Old July 11th 14, 07:25 PM posted to rec.aviation.soaring
Terry Walsh[_2_]
A=
t=
hav=
p=
Our club and many others leave the shroud off permanently as it jams the
wheel when filled with grass. I do not believe there is a marked
deterioration in peformance.
Terry Walsh
Old July 11th 14, 10:32 PM posted to rec.aviation.soaring
We cut the fairing in half and added a splice plate bonded to the front half that has 3 nut plates per side to screw the rear half to the front. This makes it removable fairly easily.
UH
Old July 11th 14, 11:07 PM posted to rec.aviation.soaring
[email protected][_1_]
Drill a hole in the fairing that aligns with the stem and use valve extender. Or remove it so you can truly inspect the tire/gear.
ACCESS GRANTED! GARY BOGGS Soaring 2 May 24th 08 04:23 PM
newsserver access Martin Hotze Piloting 7 April 21st 07 04:35 PM
OLC Access [email protected] Soaring 2 March 24th 06 06:08 PM
GA Access to DCA john smith Piloting 0 August 20th 05 10:25 PM
ng access Stu & Kathy Fields Home Built 4 April 1st 04 06:09 PM
